POV-Ray : Newsgroups : povray.binaries.images : Cloudscape Server Time
14 Jul 2025 17:59:05 EDT (-0400)
  Cloudscape (Message 31 to 40 of 42)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Cloudscape
Date: 17 Dec 2019 08:05:01
Message: <web.5df8d1ae5bb70f0810bd9e2b0@news.povray.org>
> Op 16/12/2019 om 17:51 schreef And:
> > "And" <49341109@ntnu.edu.tw> wrote:
> >> Your cloud do have some great properties. Although it is unexpected simple(the
> >> pov-code). The fluffy appearance is what I want. And the coverage is moderate.
> >> But in fact the real geometry shows the top and bottom are truncated by the
> >> boundary(800m~1200m). I will think how to solve this in the future, but if you
> >> have idea I think it will be nice.
> the truncation by the container is indeed a problem I also experience.
> Gilles Tran solved this by using df3 as containers. Very effective! See:
> http://www.oyonale.com/modeles.php?lang=en&page=36
> Thomas
I must take a while, but I'm curious how this can avoid that phenomenon.
Date: 17 Dec 2019 13:52:50
Message: <5df92402$1@news.povray.org>
You may use a planar pattern to hide that. Just scale and translate it
properly, and add a map or use an alternate wave type to control how it
need to fade near the container's edges.
Date: 18 Dec 2019 02:30:00
Message: <web.5df9d4525bb70f08c656b9e00@news.povray.org>
How do you combine these two(The original and the planar pattern)? I can't spend
time to try it right now, but I wish to look your code (even a simple example).
Date: 18 Dec 2019 05:25:00
Message: <web.5df9fd925bb70f0828607b160@news.povray.org>
I think the planar (or equivalent) pattern can be used as an additional density
function (that will multiply with the main one). I did use this for some other
clouscapes atempts.
Date: 19 Dec 2019 01:15:00
Message: <web.5dfb14bc5bb70f08c656b9e00@news.povray.org>
> clouscapes atempts.
Multiply is a straightforward idea that combine these functions. I have doubts
about it because it seem change the original pattern (unnatural) ....but I
hardly ever try it. You said that you have used it. Is the effect fine?
Date: 19 Dec 2019 17:27:59
Message: <5dfbf96f$1@news.povray.org>
>> clouscapes atempts.
The planar pattern start at 1 on the X-Z plane and drop to zero 1 unit
above and under it.
There is no distortion involved.
Date: 20 Dec 2019 02:26:05
Message: <5dfc778d$1@news.povray.org>
Op 19/12/2019 om 23:27 schreef Alain Martel:
>>>>>> is moderate.
>>>>>> truncated by the
>>>>>> future, but if you
>>>>> how it
>>>> can't spend
>>>> simple example).
>>> additional density
>>> some other
>>> clouscapes atempts.
>> have doubts
>> ....but I
> above and under it.
Also, do not forget the spherical and boxed patterns which work
according to the same principles as planar!! I use them regularly for
atmospheric or cloudscape business.
Date: 20 Dec 2019 03:45:00
Message: <web.5dfc88315bb70f0828607b160@news.povray.org>
simple(the
moderate.
you
> > clouscapes atempts.
I once could get this, and IIRC, the truncation was mitigated with such a
function. Alas, I lost the code after a USB stick corruption. But the principle
seems OK, provided  the parameters are properly tweaked (tricky).
B.
Date: 20 Dec 2019 06:50:01
Message: <web.5dfcb5515bb70f08210a7b6d0@news.povray.org>
simple(the
moderate.
the
you
spend
example).
> > > clouscapes atempts.
> B.
Thank you.
Date: 20 Dec 2019 12:28:04
Message: <5dfd04a4$1@news.povray.org>
>>> clouscapes atempts.
> B.
Lesson :
Backup !
NEVER EVER leave your code and ANY important file in only one location.
Backup !
Several partitions on a single drive is still only a single location.
Backup !
