POV-Ray : Newsgroups : povray.binaries.images : creepy figures Server Time
19 Apr 2026 20:28:26 EDT (-0400)
  creepy figures (Message 15 to 24 of 24)
Subject: Re: creepy figures
Date: 11 Feb 2018 12:25:06
Message: <web.5a807bce2200fd9e5cafe28e0@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> I used the surface normal.
> A test file was uploaded to pbs-f.
> But - it's not very fast...
I wondered if there was a way to fill the space with connected links - like a 3D
chainmail.
I would also LOVE to understand how to construct and use an octtree and do
something along the lines of this:
http://www.imagico.de/fast_iso/grid7.png
from  http://www.imagico.de/fast_iso/patch.php
but obviously without the object.
Date: 11 Feb 2018 13:00:01
Message: <web.5a8083aa2200fd9ec80f56880@news.povray.org>
> chainmail.
Look at a post done by Robert McGregor regarding a Octree space partitioning
experiment -
http://news.povray.org/povray.binaries.images/thread/%3C4f26eaa2%241%40news.povray.org%3E/
and
http://news.povray.org/povray.text.scene-files/message/%3Cweb.4f2a0580cf27ae8a94d713cc0%40news.povray.org%3E/#%3Cweb.4f
Use his code - but first define two objects (a mesh or something else and a
difference of a bigger cube and the first object) and replace spheres by
cube_frames.
Norbert
Date: 11 Feb 2018 14:25:00
Message: <web.5a8098112200fd9ec80f56880@news.povray.org>
> Well, The dark color of the figures on the light, hazy background, and the
> elongated proportions of the figures combined with the transparent/mesh
> construction all give the same impression as the style of the Three Brothers as
> drawn for the animated movie scene.
> I like it very much, and you should do more!
> (as applies to all of your work  :)  )
Thank you very much.
Testrals are another HP figures with similar look.
Some Picasso works remind me of such creepy figures too.
Norbert
Date: 11 Feb 2018 16:15:00
Message: <web.5a80b12b2200fd9e5cafe28e0@news.povray.org>
> experiment -
Hmmm.   I must have missed this. Thank you very much for bringing that to my
attention!  :)
> cube_frames.
> Norbert
So, I have read about the octree algorithm, and I can follow along and make
sense of what's going on, however -
(and maybe I need to go through it in a much more detailed level)
One of the interesting things about an octree is "saving" the leaves and
rejecting the empty voxels so that later you can quickly traverse the octree.
Maybe that's what he had developed later, before the HDD crash, but I think
that's a tool that a lot of Povvers could use, and I'm interested in learning
about that aspect of it, and coding it up as time permits.
Also, I don't see that Robert used a difference{}, and so I'm unsure how you're
suggesting I implement that second object and where it gets referenced.
But once again - thanks for that!   It's a major step forward for me to study
that code and get a jump-start on fully understanding how to implement octree
data structures.
Date: 11 Feb 2018 16:25:01
Message: <web.5a80b47f2200fd9e5cafe28e0@news.povray.org>
Any time  :)  It's always good to see what you and others pull out of your
POV-Ray magic hats after all these years, and inspire the rest of us to push a
particular project forward that last little bit, or dust off an old WIP and
bring it to fruition with new insight and inpiration.
> Norbert
Yes!   I was searching for "horse" in my memory - but "Thestrals" didn't come to
mind, even though it should have been bloody obvious.   And for whatever reason,
I had it in my mind that they were called "Kestrals" - now I'll have to go watch
a HP movie to check...  damn.
https://images.pottermore.com/bxd3o8b291gf/6HjasiK8zmeIkso2k6YYss/f6c9e16870450817cb5816b6cd827a1c/Thestrals_WB_F5_Thes
tralPortrait_Illust_100615_Port.jpg?w=1200
As a related aside, I'm currently reading "Fablehaven" for my son, and it's a
good story, very readable, and I can see parallels between it and HP as well as
other stories, just as I can see clear influences of LOTR in HP.
I mention this only because it would be amazing to see someone adapt this
figure-filling method to something like a Dementor, a Death-Eater, or Ephira -
to get that long, flowing cloth / shadow / ribbon / smoke effect.
Date: 12 Feb 2018 03:14:01
Message: <5a814cc9$1@news.povray.org>
On 11-2-2018 17:46, Norbert Kern wrote:
>> This is... creepy! Very well done indeed. I need to ponder the method:
>> you choose a random point /on/ the mesh surface, then, from that random
>> point, you traced /inside/ the mesh to the opposite side I suppose, but
>> in what direction? randomly? along the surface normal at that point? I
>> am a bit lost I confess.
>> Thomas
> I included a method for using the method for spikes a la Gormley.
> Norbert
Thank you! I shall have something to do the coming days! ;-)
Date: 12 Feb 2018 12:35:08
Message: <web.5a81cf372200fd9e254f29550@news.povray.org>
Here is a test scene to play with.
#version 3.7;
#declare RAD = 4;
global_settings {
        #declare a_g = 2.2;
        assumed_gamma a_g
        max_trace_level 5
        noise_generator 2
        #if(RAD > 0)
                radiosity {
                        pretrace_start 0.08
                        pretrace_end 0.04/RAD
                        count 30*RAD
                        nearest_count min (20, RAD)
                        error_bound 2/RAD
                        low_error_factor 0.5
                        recursion_limit 1
                        gray_threshold 0
                        minimum_reuse 0.015
                        brightness 1
                        adc_bailout 0.005
                        normal on
                        media on
#include "stdinc.inc"
sky_sphere {
                average
                pigment_map {
                        [1      function {max (min (y, 1), 0)}
                                color_map {
                                        [0      rgb 2.35]
                                        [0.96   rgb 4.5]
                                        [1      rgb 13.5]
                                turbulence 0.2
                                color_map {
                                        [0      rgbt 1]
                                        [0.5    rgbt <0.385,0.77,1.1,1>]
                                rotate z*-45
        location <2,2,-4>
        look_at <0.1,0,0>
        up y
        angle 82
light_source {
        <-80000,50000,-50000>,
        color rgb <2.42,2.23,1.87>
plane {y, -1.6 finish {reflection {0, 1}}}
//______________________________________________________________________________
#declare obj_ =
isosurface {
 function {f_sphere (x,y,z,1)-f_noise3d (x*2.5,y*2.5,z*2.5)*0.6}
 contained_by {sphere {0, 1.6}}
 max_gradient 2.5
 hollow
         pigment {color rgb <0.35,0.32,0.55>}
object {obj_}
#declare rootObj =
difference {
        object {obj_ scale <2.5, 1.4,1.4>}
        object {obj_}
#declare thin = 0.02;
#declare frame =
union {
        cylinder {<-1,-1,-1>, <-1,1,-1>, thin}
        cylinder {<-1,-1,1>, <-1,1,1>, thin}
        cylinder {<1,-1,-1>, <1,1,-1>, thin}
        cylinder {<1,-1,1>, <1,1,1>, thin}
        cylinder {<-1,-1,-1>, <1,-1,-1>, thin}
        cylinder {<1,-1,-1>, <1,-1,1>, thin}
        cylinder {<1,-1,1>, <-1,-1,1>, thin}
        cylinder {<-1,-1,1>, <-1,-1,-1>, thin}
        cylinder {<-1,1,-1>, <1,1,-1>, thin}
        cylinder {<1,1,-1>, <1,1,1>, thin}
        cylinder {<1,1,1>, <-1,1,1>, thin}
        cylinder {<-1,1,1>, <-1,1,-1>, thin}
        sphere {<-1,-1,-1>, thin}
        sphere {<1,-1,-1>, thin}
        sphere {<-1,1,-1>, thin}
        sphere {<-1,-1,1>, thin}
        sphere {<-1,1,1>, thin}
        sphere {<1,-1,1>, thin}
        sphere {<1,1,-1>, thin}
        sphere {<1,1,1>, thin}
#declare MAX_DEPTH = 8;
#declare R = seed (0);
#declare OUTSIDE = 0;
#declare PARTIAL = 1;
#declare INSIDE  = 2;
#declare _nDepth = 0;
#declare _nBoxes = 0;
#declare _nNullBoxes = 0;
#macro GAUSS (X)
((rand (X)+rand (X)+rand (X)+rand (X)+rand (X)+rand (X)-3)*1)
#macro GetBoxState (obj_, bbox)
#local bmin = min_extent (bbox);
#local bmax = max_extent (bbox);
#local n = 0;
#if (inside (obj_, <bmin.x,bmin.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmax.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmax.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmax.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmin.y,bmin.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmin.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmin.x,bmax.y,bmax.z>)) #local n = n+1; #end
#if (inside (obj_, <bmax.x,bmin.y,bmax.z>)) #local n = n+1; #end
#switch (n)
        #case (0)
                #local state = OUTSIDE;
        #break
        #case (8)
                #local state = INSIDE;
        #break
        #else
                #local state = PARTIAL;
        #break
state
#macro BuildDisplayVoxel (bbox)
#local clr1 = srgb <225,180,105>/255;
#local clr2 = srgb <105,90,30>/255;
#local gry  = RRand (0.1, 0.9, R);
#local ctr  = (bmin+bmax)*0.5;
union {
        object {frame}
        rotate y*90
        scale _rootScale
        pigment {color rgb <1,0,0>}
        scale vlength (ctr-bmax)
        translate ctr
#declare _nBoxes = _nBoxes+1;
#macro SubdivideVoxel (root, bbParent)
#declare _nDepth = _nDepth+1;
#if (_nDepth <= MAX_DEPTH)      // break into 8 sub-boxes
        #local aBox = array [8];
        #local bmin = min_extent (bbParent);
        #local bmax = max_extent (bbParent);
        #local midX = (bmin.x+bmax.x)*0.5;
        #local midY = (bmin.y+bmax.y)*0.5;
        #local midZ = (bmin.z+bmax.z)*0.5;
        #local aBox [0] = box {<bmin.x,bmin.y,bmin.z>,<midX,  midY,  midZ>}
        #local aBox [1] = box {<bmin.x,midY,  bmin.z>,<midX,  bmax.y,midZ>}
        #local aBox [2] = box {<midX,  bmin.y,bmin.z>,<bmax.x,midY,  midZ>}
        #local aBox [3] = box {<midX,  midY,  bmin.z>,<bmax.x,bmax.y,midZ>}
        #local aBox [4] = box {<bmin.x,bmin.y,midZ>,  <midX,  midY,  bmax.z>}
        #local aBox [5] = box {<bmin.x,midY,  midZ>,  <midX,  bmax.y,bmax.z>}
        #local aBox [6] = box {<midX,  bmin.y,midZ>,  <bmax.x,midY,  bmax.z>}
        #local aBox [7] = box {<midX,  midY,  midZ>,  <bmax.x,bmax.y,bmax.z>}
        #local n = 0;
        #while (n < 8)
                #if (INSIDE = GetBoxState (root, aBox [n]))
                        BuildDisplayVoxel (aBox [n])
                #else
                        #if (PARTIAL = GetBoxState (root, aBox [n]))
                                SubdivideVoxel (root, aBox [n])
                        #else
                                #declare _nNullBoxes = _nNullBoxes+1;
                                #local isect =
                                intersection {
                                        object {root}
                                        object {aBox [n]}
                                #local bmin = min_extent (isect);
                                #if (bmin.x > -10000000000)
                #local n = n+1;
#declare _nDepth = _nDepth-1;
#macro SubdivideVoxelMain (root, bbParent)
#local n = 0;
#while (n < 8)
        #else
                #else
        #local n = n+1;
#declare bmin = <-40,-40,-40>; //min_extent (rootObj);
#declare bmax = <40,40,40>; //max_extent (rootObj);
#declare ctr = (bmin+bmax)*0.5;
#declare bbRoot =
box {
        vtransform (ctr, transform {translate -bmax}),
        vtransform (ctr, transform {translate bmax})
#declare _rootScale = 20/vlength (ctr-bmax)*2;
union {
        SubdivideVoxelMain (rootObj, bbRoot)
// end of code
Norbert
Download 'octree_test_scene.jpg' (614 KB)
Preview of image 'octree_test_scene.jpg'
Date: 12 Feb 2018 12:55:00
Message: <web.5a81d3d52200fd9ec437ac910@news.povray.org>
Excellent - that looks nice.
I experimented with the original code for a while, and got things to 'work'
after a bit of fiddling.
I tried using a Wire_Box object instead of a sphere with unit edges, and that
was way too small.  7-10 units seemed to work much better for some reason.
I had to crank up the subdivision level to 7 to get good coverage of "Jack".
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a1f60f72471086b5cafe28e0%40news.povray.org%3E/#%3Cweb.5a1
It also didn't really seem to be doing quite what I thought it might, based on
the size and placement of the boxes.  I might need to do a progressively finer
subdivision like in the original post, and color code the inside, partial, and
outside states of the bounding boxes.
Thanks again for the test scene - I'll try to look at it in detail tonight.  :)
Date: 19 Feb 2018 04:50:00
Message: <web.5a8a9d862200fd9e16086ed00@news.povray.org>
> Hello,
> here is a way to modificate meshes of humans or animals to creepy figures.
> After finding a random point on a mesh surface another trace was done inside the
> mesh. A box was then placed between the two points.
> Each of the two figures consists of 990.000 boxes.
> Texture uses a proximity technique described in
http://news.povray.org/povray.binaries.images/thread/%3Cweb.59d38d1358cfc649f2ea585a0%40news.povray.org%3E/.
> Background is from Margus Ramst.
> Scene uses assumed_gamma 1 as in my last pictures.
> Norbert
Amazing result ! Giacometti-like figures over a Magritte background, gracious
postures and anatomy.
Date: 19 Feb 2018 18:00:01
Message: <web.5a8b56c92200fd9ea47873e10@news.povray.org>
> several years before I stopped working on an image because of the disturbing
> river rock distribution...
This is gorgeous. There si so much to like in the scene-- the warm afternoon
sunlight, the composition, the flowers and weeds and their colors. The scene has
a nice *choice* of colors, too-- not *every color in the rainbow* but a
restricted palette. (Personally, I think that's an attribute of some of the best
paintings.)
I think many of the rocks are a bit too 'flat'-- several look like turtles (uh,
maybe they ARE turtles!) But as Thomas noted, sinking them further into the mud
would be a choice, along with fattening them up along the y-axis. Although I
really like your rough-looking rock and stone textures in most of the scene,
river rocks have a tendency to be smoother.
