clipka <ano### [at] anonymous org> wrote:
> Am 25.11.2017 um 13:53 schrieb And:
> >> Am 25.11.2017 um 05:06 schrieb And:
> >>> subsurface material cloud:
> >> Hm... I didn't think of using an isosurface to give shape to the cloud.
> >> Might actually work.
> >> Make sure to use an ior of 1.0. That's more realistic, and might reduce
> >> those bright blue band artifacts.
> > Um, I didn't add ior, should 1.0 be a default?
> Yes, if you don't specify an interior, or don't specify a refractive
> index in the interior, it should default to 1.0 (or, more precisely, to
> the same value as the atmosphere's refractive index, which currently
> happens to be hard-coded to 1.0).
> If the refractive index is at 1.0 already, then I haven't a clue where
> the bright blue band artifacts might be coming from.
My sky (sky sphere) is blue. That's radiosity
Sven Littkowski <I### [at] SvenLittkowski name> wrote:
> Thank you, all these images are interesting. Especially
> "interior_3f_scene 7_5 sss6 20m42s.png" looks like what I want.
> Can you provide the source code for it? That would allow me to make some
> test renders, to check out some more attributes of these clouds. Thank you.
> http://www.avg.com
.. alright:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5a1aa6b6d28a8fb9dc963d550%40news.povray.org%3E/
"Bald Eagle" <cre### [at] netscape net> wrote:
> Wow - that's not a cloud - that's a beautiful piece of snow/ice!
> Thanks for posting that - it look great! :)
Thank you
OK. This is an update of your scene. Note the following:
- do not set default diffuse to 0 as your colour will come out black if
you do not use radiosity. This happened to your ground plane for
instance and forced you probably to use ambient for your planet. Set to 1;
- never use ambient! always prefer radiosity;
- discard the fogs and use media instead;
- I shall come back later for the cloud media where things can be
improved. In particular be careful with non-uniform scaling of the media
container as this changes the colour/aspect of the media.
Here is the corrected scene:
#version 3.7;
global_settings {
assumed_gamma 1.0
#default {
finish { ambient 0.0 diffuse 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
/*ultra_wide_angle*/ angle 20
location < -35.0 , 11.0 , 0.0 >
look_at < 0.0 , 5.0 , 0.0 >
// sun -------------------------------------------------------------------
light_source {
< 50, 100, -250 >*10e4
color < 1.0, 0.62353, 0.46667 >*2
// sky -------------------------------------------------------------------
background { color rgb 0 }
sky_sphere {
gradient < 0, 1, 0 >
color_map {
[ 0.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
[ 0.4 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 0.6 color rgb < 0.64706, 0.30588, 0.59608 > ] // Purple
[ 1.0 color rgb < 1.00000, 0.62353, 0.46667 > ] // Pink
scale 2
// ground -----------------------------------------------------------------
disc {
< 0, 1, 0 >, 0, 50
texture { pigment { color rgb < 0.24706, 0.38431, 0.058824 > *1.0 }
finish {diffuse 1.0 } }
rotate< 0, 0, 0 >
//---------------------------- objects in scene -------------------
//cloud layer:
cylinder {
< 0.0, -0.5, 0.0 > < 0.0, 1.0, 0.0 > 10.0
pigment{ rgbt 1 }
hollow
interior {
media {
emission < 0.9, 0.9, 1.0 > *0.15
absorption < 0.0, 0.0, 0.5 >
scattering {
3, < 1.0, 1.0, 1.0 >
extinction 2.0
density {
gradient < 1.0, 0.25, 0.5 > //controls the cloud formation
turbulence 0.5
frequency 5
color_map {
[ 0.0 rgb 0.0 ]//border
[ 0.5 rgb 0.1 ]
[ 1.0 rgb 1.0 ]//center
} // end color_map
} // end of density
} // end of media ----
} // end of interior
translate < 0.0, 1.0, 0.0 >
scale < 5.0, 1.5, 5.0 >
//atmosphere:
#local Scale = 5;
sphere {
<0.0, 0.0, 0.0 >, 10.0
pigment {rgbt 1}
hollow
interior {
media {
scattering {1, <1, 1, 1,>*0.3/Scale extinction 1}
density {
gradient y
color_map {
[0.00 rgb 1.00] //base ground fog
[0.07 rgb 0.80] //top ground fog
[0.08 rgb 0.02] //base atmospheric haze
[1.00 rgb 0.01] //top atmospheric haze
scale Scale*2*y
scale Scale
//artefact:
union {
cylinder {< 0.0, 0.0, 0.0 > < 0.0, 8.0, 0.0 > 0.25}
sphere {< 0.0, 8.0, 0.0 > 0.25}
texture { T01 }
texture { T_Copper_1A }
// Planet:
union {
sphere {
<0.0, 0.0, 0.0> 7.0
difference {
cylinder { < 0.0, -0.00001, 0.0 > < 0.0, 0.00001, 0.0 > 13.0 }
cylinder { < 0.0, -0.00002, 0.0 > < 0.0, 0.00002, 0.0 > 10.0 }
rotate < 20.0, 0.0, 4.0 >
texture {pigment {White}}
translate <80.0, -2.0, 13.0>
Download 'sven_cloud surface_test.png' (339 KB)
Preview of image 'sven_cloud surface_test.png'
You might be interested to also try out the following cloud surface
media (replace with the one in the scene):
#local Scale = 5;
cylinder {
< 0.0, 0.0, 0.0 > < 0.0, 0.45, 0.0 > 10.0
pigment {rgbt 1}
hollow
interior {
media {
samples 20
emission <1.0, 1.0, 1.0>*0.1
absorption <1.0, 1.0, 1.0>*1
scattering {1, <1, 1, 1>*1/Scale extinction 1.0 }
density {
ripples // controls the cloud formation
frequency 3
color_map {
[0.5 rgb 0.02]
[0.5 rgb 1.00]
scale <3, 1, 10>*1
warp {turbulence <2.5, 1.0, 1.6>}
scale Scale
translate <0, 1, 0>
> On 25.11.2017 06:35, clipka wrote:
>> Those defaults are still valid for the newer versions with all the fancy
>> media fixes (late v3.7.1 development versions and v3.8).
> Can version 3.8 be downloaded already, even as beta?
> http://www.avg.com
Yes, from github
> UPDATE
> See the three attached images.
> The first image shows, how the scene is right now.
> The second (photoshopped) image shows, how I want it.
> The third image shows the horizon features (not colors) I want.
> The ground fog should not reach so high. It should reach up to short
> above the clouds (Y=1.0) only and then be faded away at height Y=2.0.
> Also, the clouds seem to have a brighter edge at the horizon. Thus I
> wonder, if a media item can take that away and create an "atmospheric
> layer" as seen on image 3 in pink (between the blue sky and the lilac
> clouds).
> See below the current scene code. Please feel free to make changes, to
> demonstrate to me how to get those features. Big thanks.
First : Remove all fogs.
Next : Also remove that emissive media.
Those two are hiding the shadow.
Try the following :
cylinder
pigment{ rgbt < 0.20784, 0.19216, 0.25098, 1.0 > }
hollow
interior
media
//Also try without the above
scattering
extinction 1.0
density
gradient < 1.0, 0.25, 0.5 > // controls the cloud formation
turbulence 0.5
frequency 5
color_map
[ 0.5 rgb <0.2, 0.2, 0.25> ]
[ 1.0 rgb <2, 2, 3> ]//center
//This makes the media blueish.
//You are not limited to the 0..1 range.
} // end color_map
} // end of density
cylinder
texture { T01 }
The reason you need to remove the emissive media : Emissive media goal
is to simulate GLOWING gaz that actually emit light by itself, like a
flame or some plasma.
Clouds only scatter light, they don't emit any.
On 26.11.2017 11:15, Alain wrote:
> Yes, from github
Thanks.
http://www.avg.com
UPDATE
I tried out the And-clouds. Their shape is nice, but the tower does not
fade into them but they have hard edges. I wonder, if if they can be
filled with a media that accumulates only by increased density, meaning
that the cloud edges are fading. And it takes longer to render.
I also replaced my fogs with those I found inside a POV-Ray tutorial
file. They give me the thin fog line between clouds and sky. But the fog
is not yet the way I want it, it does not yet hide the distant clouds. I
want that the fog hides the edge of the cloud area. I am just not good
in using fogs and media and isosurfaces. Over all the past 25 years, I
only worked with regular shapes and differences.
I would like o replace the fog with a media, if that can do what I want.
#version 3.7;
#declare MyRadiosity = on;
global_settings
max_trace_level 3
assumed_gamma 1.0
adc_bailout 0.007
mm_per_unit 1000 //important for subsurface
#if(MyRadiosity)
radiosity
pretrace_start 64/image_width
pretrace_end 4/image_width
count 60
nearest_count 6
error_bound 0.64
recursion_limit 8
low_error_factor 0.5
gray_threshold 0.0
brightness 1
subsurface
samples 8, 8
radiosity off
#default
finish { ambient 0.0 diffuse 0.0 }
#include "functions.inc"
camera
location < -35.0 , 11.0 ,-00.0 >
light_source { < 250, 100, -250 > color < 1.0, 0.62353, 0.46667 > *3.0 }
// sky
sky_sphere
pigment
color_map
[ 0.4 color rgb < 1.00000, 0.62353, 0.46667 > ] // Purple <
[ 0.6 color rgb < 1.00000, 0.62353, 0.46667 > ] // Purple
scale 2
background { color rgb < 0.47059, 0.71373, 0.80392 > }
//---------------------------------<<< settings of squared plane dimensions
plane
< 0, 1, 0 >, 0
finish { ambient 0.0 diffuse 0.0 } }
rotate< 0, 0, 0 >
//------------------------------------------------ end of squared plane XZ
//---------------------------- objects in scene ----------------------------
cylinder
hollow
interior
media
scattering
extinction 2.0
density
turbulence 0.5
frequency 5
color_map
[ 0.5 rgb 0.1 ]
} // end color_map
} // end of density
//--------------------cloud----------------------
#declare f_test = function(x,y,z)
//sqrt(x*x + y*y) - 0.4
+0.36*sum(i, 0, 4, pow(abs(f_noise3d(x*pow(2, i)/0.2, y*pow(2, i)/0.2,
z*pow(2, i)/0.2)), 2.5)/pow(2.0, i) )
isosurface
function
0.5 - f_test(x,y,z)*3*3*z*exp(-3*z) - 0.36*3*3*z*exp(-3*z)
contained_by { box { < -2.5, -2.5, 0.0 > < 2.5, 2.5, 1.0 > } }
threshold 0.0
accuracy 0.001
max_gradient 2
//all_intersections
//open
material
texture
pigment { rgb < 1.0, 1.0, 1.0 > }
finish
diffuse 1.0
subsurface
translucency rgb<1,1,1>*6
scale < 1.6, 1.6, 1.0 >
rotate < -90.0, 0.0, 0.0 >
scale < 12.0, 1.5, 12.0 >
translate < 0.0, 1.5, 0.0 >
#local Scale = 5;
cylinder
pigment {rgbt 1}
hollow
interior
media
samples 20
density
frequency 3
color_map
[0.5 rgb 0.02]
[0.5 rgb 1.00]
scale <3, 1, 10>*1
warp { turbulence <2.5, 1.0, 1.6> }
scale Scale
translate < 0, 1, 0 >
fog
fog_type 2
distance 300
color rgb < 0.20784, 0.192160, 0.2509800 > *0.8 // Purple
color rgb < 0.7451, 0.50196, 0.42745 > *0.8 // Pink
fog_offset 1.1
fog_alt 2.25
turbulence 1.8
fog
distance 15
color rgb<0.3, 0.5, 0.2>
fog_type 2
fog_offset 2.5
fog_alt .1
turbulence 0.01
turb_depth 0.02
fog
distance 15
color rgb<0.5, 0.1, 0.1>
fog_type 2
fog_offset 1.5
fog_alt .4
turbulence 0.02
turb_depth 0.02
fog
distance 15
color rgb<0.1, 0.1, 0.6>
fog_type 2
fog_offset 1.0
fog_alt .2
cylinder
texture { T01 }
texture
Polished_Chrome
//pigment{color rgb< 1, 0.6, 0> }
//normal {bumps 0.5 scale 0.10}
finish { phong 1 phong_size 50}
sphere
texture { T01 }
texture
Polished_Chrome
// Planet
sphere
< 80.0, -2.0, 13.0 > 7.0
texture { T01 }
difference
texture { T01 }
finish { ambient 0.85 }
translate < 80.0, -2.0, 13.0 >
http://www.avg.com
Download 'sl - cloud cities 3.jpg' (393 KB)
Preview of image 'sl - cloud cities 3.jpg'
This is how it looks without scattering and emission. :-)
Both seem to be required for correct colors. But look to the lowest
posting in this thread, that is an update and I try out an isosurface there
My need now is, instead of fog, a media that can give me what I need.
See the 2nd attached image, it shows the different atmospheric layers I
need:
- ground fog just reaching above clouds
- orange distant layer, hiding the edges of my clouds
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.6
http://www.avg.com
Download 'sl - cloud cities - no scattering no emission.jpg' (218 KB)
Download 'tutimgmultifog.png' (66 KB)
Preview of image 'sl - cloud cities - no scattering no emission.jpg'
Preview of image 'tutimgmultifog.png'
