POV-Ray : Newsgroups : povray.binaries.images : Re: Cloud Surface Server Time
17 Mar 2026 23:09:56 EDT (-0400)
  Re: Cloud Surface (Message 30 to 39 of 109)
Subject: Re: Cloud Surface
Date: 26 Nov 2017 04:50:01
Message: <web.5a1a8dea9a2a53c1dc963d550@news.povray.org>
> Am 25.11.2017 um 13:53 schrieb And:
> > clipka <ano### [at] anonymousorg> wrote:
> >> Am 25.11.2017 um 05:06 schrieb And:
> >>> subsurface material cloud:
> >> Hm... I didn't think of using an isosurface to give shape to the cloud.
> >> Might actually work.
> >> Make sure to use an ior of 1.0. That's more realistic, and might reduce
> >> those bright blue band artifacts.
> > Um, I didn't add ior, should 1.0 be a default?
> Yes, if you don't specify an interior, or don't specify a refractive
> index in the interior, it should default to 1.0 (or, more precisely, to
> the same value as the atmosphere's refractive index, which currently
> happens to be hard-coded to 1.0).
> If the refractive index is at 1.0 already, then I haven't a clue where
> the bright blue band artifacts might be coming from.
My sky (sky sphere) is blue. That's radiosity
Date: 26 Nov 2017 06:45:00
Message: <web.5a1aa9029a2a53c1dc963d550@news.povray.org>
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> Thank you, all these images are interesting. Especially
> "interior_3f_scene 7_5 sss6 20m42s.png" looks like what I want.
> Can you provide the source code for it? That would allow me to make some
> test renders, to check out some more attributes of these clouds. Thank you.
> http://www.avg.com
..     alright:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.5a1aa6b6d28a8fb9dc963d550%40news.povray.org%3E/
Date: 26 Nov 2017 06:50:00
Message: <web.5a1aa98b9a2a53c1dc963d550@news.povray.org>
> Wow - that's not a cloud - that's a beautiful piece of snow/ice!
> Thanks for posting that - it look great!  :)
Thank you
Date: 26 Nov 2017 07:13:47
Message: <5a1aaffb@news.povray.org>
OK. This is an update of your scene. Note the following:
- do not set default diffuse to 0 as your colour will come out black if
you do not use radiosity. This happened to your ground plane for
instance and forced you probably to use ambient for your planet. Set to 1;
- never use ambient! always prefer radiosity;
- discard the fogs and use media instead;
- I shall come back later for the cloud media where things can be
improved. In particular be careful with non-uniform scaling of the media
container as this changes the colour/aspect of the media.
Here is the corrected scene:
#version 3.7;
global_settings {
   assumed_gamma 1.0
#default {
  finish { ambient 0.0 diffuse 1.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
   /*ultra_wide_angle*/ angle 20
   location  < -35.0 , 11.0 , 0.0 >
   look_at   < 0.0 , 5.0 , 0.0 >
// sun -------------------------------------------------------------------
light_source {
   < 50, 100, -250 >*10e4
   color < 1.0,  0.62353,  0.46667 >*2
// sky -------------------------------------------------------------------
background { color rgb 0 }
sky_sphere {
     gradient < 0, 1, 0 >
     color_map {
       [ 0.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
       [ 0.4 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
       [ 0.6 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
       [ 1.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
     scale 2
// ground -----------------------------------------------------------------
disc {
  < 0, 1, 0 >, 0, 50
  texture { pigment { color rgb < 0.24706,  0.38431,  0.058824 > *1.0 }
  finish {diffuse 1.0 } }
  rotate< 0, 0, 0 >
//---------------------------- objects in scene -------------------
//cloud layer:
cylinder {
   < 0.0, -0.5, 0.0 > < 0.0, 1.0, 0.0 > 10.0
   pigment{ rgbt 1 }
   hollow
   interior {
     media {
       emission < 0.9, 0.9, 1.0 > *0.15
       absorption < 0.0, 0.0, 0.5 >
       scattering {
         3, < 1.0, 1.0, 1.0 >
         extinction  2.0
       density {
         gradient < 1.0, 0.25, 0.5 > //controls the cloud formation
         turbulence 0.5
         frequency 5
         color_map {
           [ 0.0 rgb 0.0 ]//border
           [ 0.5 rgb 0.1 ]
           [ 1.0 rgb 1.0 ]//center
         } // end color_map
       } // end of density
     } // end of media ----
   } // end of interior
   translate < 0.0, 1.0, 0.0 >
   scale < 5.0, 1.5, 5.0 >
//atmosphere:
#local Scale = 5;
sphere {
   <0.0, 0.0, 0.0 >, 10.0
   pigment {rgbt 1}
   hollow
   interior {
     media {
       scattering {1, <1, 1, 1,>*0.3/Scale extinction 1}
       density {
         gradient y
         color_map {
           [0.00 rgb 1.00] //base ground fog
           [0.07 rgb 0.80] //top ground fog
           [0.08 rgb 0.02] //base atmospheric haze
           [1.00 rgb 0.01] //top atmospheric haze
         scale Scale*2*y
   scale Scale
//artefact:
union {
   cylinder {< 0.0, 0.0, 0.0 > < 0.0, 8.0, 0.0 > 0.25}
   sphere {< 0.0, 8.0, 0.0 > 0.25}
   texture { T01 }
   texture { T_Copper_1A }
// Planet:
union {
   sphere {
     <0.0, 0.0, 0.0> 7.0
   difference {
     cylinder { < 0.0, -0.00001, 0.0 > < 0.0, 0.00001, 0.0 > 13.0 }
     cylinder { < 0.0, -0.00002, 0.0 > < 0.0, 0.00002, 0.0 > 10.0 }
     rotate < 20.0, 0.0, 4.0 >
   texture {pigment {White}}
   translate <80.0, -2.0, 13.0>
Download 'sven_cloud surface_test.png' (339 KB)
Preview of image 'sven_cloud surface_test.png'
Date: 26 Nov 2017 08:02:35
Message: <5a1abb6b$1@news.povray.org>
You might be interested to also try out the following cloud surface
media (replace with the one in the scene):
#local Scale = 5;
cylinder {
   < 0.0, 0.0, 0.0 > < 0.0, 0.45, 0.0 > 10.0
   pigment {rgbt 1}
   hollow
   interior {
     media {
       samples 20
       emission <1.0, 1.0, 1.0>*0.1
       absorption <1.0, 1.0, 1.0>*1
       scattering {1, <1, 1, 1>*1/Scale extinction 1.0 }
       density {
         ripples   // controls the cloud formation
         frequency 3
         color_map {
           [0.5 rgb 0.02]
           [0.5 rgb 1.00]
         scale <3, 1, 10>*1
         warp {turbulence <2.5, 1.0, 1.6>}
   scale Scale
   translate <0, 1, 0>
Date: 26 Nov 2017 11:14:12
Message: <5a1ae854$1@news.povray.org>
> On 25.11.2017 06:35, clipka wrote:
>> Those defaults are still valid for the newer versions with all the fancy
>> media fixes (late v3.7.1 development versions and v3.8).
> Can version 3.8 be downloaded already, even as beta?
> http://www.avg.com
Yes, from github
Date: 26 Nov 2017 11:28:47
Message: <5a1aebbf$1@news.povray.org>
> UPDATE
> See the three attached images.
> The first image shows, how the scene is right now.
> The second (photoshopped) image shows, how I want it.
> The third image shows the horizon features (not colors) I want.
> The ground fog should not reach so high. It should reach up to short
> above the clouds (Y=1.0)  only and then be faded away at height Y=2.0.
> Also, the clouds seem to have a brighter edge at the horizon. Thus I
> wonder, if a media item can take that away and create an "atmospheric
> layer" as seen on image 3 in pink (between the blue sky and the lilac
> clouds).
> See below the current scene code. Please feel free to make changes, to
> demonstrate to me how to get those features. Big thanks.
First : Remove all fogs.
Next : Also remove that emissive media.
Those two are hiding the shadow.
Try the following :
cylinder
  pigment{ rgbt < 0.20784,  0.19216,  0.25098, 1.0 > }
  hollow
  interior
   media
//Also try without the above
    scattering
     extinction  1.0
    density
     gradient < 1.0, 0.25, 0.5 >  // controls the cloud formation
     turbulence 0.5
     frequency 5
     color_map
      [ 0.5 rgb <0.2, 0.2, 0.25> ]
      [ 1.0 rgb <2, 2, 3> ]//center
//This makes the media blueish.
//You are not limited to the 0..1 range.
     } // end color_map
    } // end of density
cylinder
  texture { T01 }
The reason you need to remove the emissive media : Emissive media goal
is to simulate GLOWING gaz that actually emit light by itself, like a
flame or some plasma.
Clouds only scatter light, they don't emit any.
Date: 26 Nov 2017 19:33:47
Message: <5a1b5d6b$1@news.povray.org>
On 26.11.2017 11:15, Alain wrote:
> Yes, from github
Thanks.
http://www.avg.com
Date: 26 Nov 2017 19:40:02
Message: <5a1b5ee2@news.povray.org>
UPDATE
I tried out the And-clouds. Their shape is nice, but the tower does not
fade into them but they have hard edges. I wonder, if if they can be
filled with a media that accumulates only by increased density, meaning
that the cloud edges are fading. And it takes longer to render.
I also replaced my fogs with those I found inside a POV-Ray tutorial
file. They give me the thin fog line between clouds and sky. But the fog
is not yet the way I want it, it does not yet hide the distant clouds. I
want that the fog hides the edge of the cloud area. I am just not good
in using fogs and media and isosurfaces. Over all the past 25 years, I
only worked with regular shapes and differences.
I would like o replace the fog with a media, if that can do what I want.
#version 3.7;
#declare MyRadiosity = on;
global_settings
 max_trace_level 3
 assumed_gamma 1.0
 adc_bailout 0.007
 mm_per_unit 1000 //important for subsurface
 #if(MyRadiosity)
  radiosity
   pretrace_start 64/image_width
   pretrace_end   4/image_width
   count 60
   nearest_count 6
   error_bound 0.64
   recursion_limit 8
   low_error_factor 0.5
   gray_threshold 0.0
   brightness 1
 subsurface
  samples 8, 8
  radiosity off
#default
 finish { ambient 0.0 diffuse 0.0 }
#include "functions.inc"
camera
 location  < -35.0 , 11.0 ,-00.0 >
light_source { < 250, 100, -250 > color < 1.0,  0.62353,  0.46667 > *3.0 }
// sky
sky_sphere
 pigment
  color_map
   [ 0.4 color rgb < 1.00000,  0.62353,  0.46667 > ] // Purple <
   [ 0.6 color rgb < 1.00000,  0.62353,  0.46667 > ] // Purple
  scale 2
background { color rgb < 0.47059,  0.71373,  0.80392 > }
//---------------------------------<<< settings of squared plane dimensions
plane
 < 0, 1, 0 >, 0
 finish { ambient 0.0 diffuse 0.0 } }
 rotate< 0, 0, 0 >
//------------------------------------------------ end of squared plane XZ
//---------------------------- objects in scene ----------------------------
cylinder
 hollow
 interior
  media
   scattering
    extinction  2.0
   density
    turbulence 0.5
    frequency 5
    color_map
     [ 0.5 rgb 0.1 ]
    } // end color_map
   } // end of density
//--------------------cloud----------------------
#declare f_test = function(x,y,z)
 //sqrt(x*x + y*y) - 0.4
 +0.36*sum(i, 0, 4, pow(abs(f_noise3d(x*pow(2, i)/0.2, y*pow(2, i)/0.2,
z*pow(2, i)/0.2)), 2.5)/pow(2.0, i) )
isosurface
 function
  0.5 - f_test(x,y,z)*3*3*z*exp(-3*z) - 0.36*3*3*z*exp(-3*z)
 contained_by { box { < -2.5, -2.5, 0.0 >  < 2.5, 2.5, 1.0 > } }
 threshold 0.0
 accuracy 0.001
 max_gradient 2
 //all_intersections
 //open
 material
  texture
   pigment { rgb < 1.0, 1.0, 1.0 > }
   finish
    diffuse 1.0
    subsurface
     translucency rgb<1,1,1>*6
 scale < 1.6, 1.6, 1.0 >
 rotate < -90.0, 0.0, 0.0 >
 scale < 12.0, 1.5, 12.0 >
 translate < 0.0, 1.5, 0.0 >
#local Scale = 5;
cylinder
 pigment {rgbt 1}
 hollow
 interior
  media
   samples 20
   density
    frequency 3
    color_map
     [0.5 rgb 0.02]
     [0.5 rgb 1.00]
    scale <3, 1, 10>*1
    warp { turbulence <2.5, 1.0, 1.6> }
 scale Scale
 translate < 0, 1, 0 >
fog
 fog_type   2
 distance   300
 color rgb < 0.20784,  0.192160,  0.2509800 > *0.8 // Purple
 color rgb < 0.7451,  0.50196,  0.42745 > *0.8 // Pink
 fog_offset 1.1
 fog_alt    2.25
 turbulence 1.8
fog
 distance 15
 color rgb<0.3, 0.5, 0.2>
 fog_type 2
 fog_offset 2.5
 fog_alt .1
 turbulence 0.01
 turb_depth 0.02
fog
 distance 15
 color rgb<0.5, 0.1, 0.1>
 fog_type 2
 fog_offset 1.5
 fog_alt .4
 turbulence 0.02
 turb_depth 0.02
fog
 distance 15
 color rgb<0.1, 0.1, 0.6>
 fog_type 2
 fog_offset 1.0
 fog_alt .2
cylinder
 texture { T01 }
 texture
  Polished_Chrome
  //pigment{color rgb< 1, 0.6, 0> }
  //normal {bumps 0.5 scale 0.10}
  finish { phong 1 phong_size 50}
sphere
 texture { T01 }
 texture
  Polished_Chrome
// Planet
sphere
 < 80.0, -2.0, 13.0 > 7.0
 texture { T01 }
difference
 texture { T01 }
 finish { ambient 0.85 }
 translate < 80.0, -2.0, 13.0 >
http://www.avg.com
Download 'sl - cloud cities 3.jpg' (393 KB)
Preview of image 'sl - cloud cities 3.jpg'
Date: 26 Nov 2017 19:54:22
Message: <5a1b623e@news.povray.org>
This is how it looks without scattering and emission. :-)
Both seem to be required for correct colors. But look to the lowest
posting in this thread, that is an update and I try out an isosurface there
My need now is, instead of fog, a media that can give me what I need.
See the 2nd attached image, it shows the different atmospheric layers I
need:
- ground fog just reaching above clouds
- orange distant layer, hiding the edges of my clouds
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.6
http://www.avg.com
Download 'sl - cloud cities - no scattering no emission.jpg' (218 KB) Download 'tutimgmultifog.png' (66 KB)
Preview of image 'sl - cloud cities - no scattering no emission.jpg'
Preview of image 'tutimgmultifog.png'
