![](/i/fill.gif) |
Illustration re:
http://news.povray.org/povray.general/thread/%3Cweb.56ea1f7e7eb839c15e7df57c0%40news.povray.org%3E/
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#include "debug.inc"
Set_Debug (true)
#include "textures.inc"
#include "shapes.inc"
#include "shapes2.inc"
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
light_source { <0, 150, 0> color rgb <1, 1, 1>}
#declare Camera_Top = camera {
location <0, 4, -0.01>
//right x*image_width/image_height
look_at <0, 0, 0>}
#declare Camera_Front = camera {
location <5, 20, -20>
look_at <5, 10, 0>}
camera {Camera_Top}
plane {y, 0 pigment {White}}
#declare T1 = 0.01; // Line widths
#declare T2 = 0.005;
#declare MarkerCircle = 0.012;
#declare Teeth = 36; #declare N = Teeth; // Number of teeth on gear (N)
#declare Pitch = 24; #declare P = Pitch; // Gear pitch (P)
#declare RootCircle = (Teeth-2)/Pitch; #declare RD = RootCircle; // Root circle
diameter (RD)
#declare PitchCircle = Teeth/Pitch; #declare D = PitchCircle; // Pitch circle
diameter (D)
#declare OutsideCircle= (Teeth+2)/Pitch; #declare OD = OutsideCircle; // Outside
circle diameter (OD)
#declare Hub = 0.9;
#declare Hole = 0.25;
torus {RootCircle, T2 translate <0, T1, 0> texture {pigment {color Blue}
finish {phong 0.1}} } // RootCircle Circle
torus {PitchCircle, T2 translate <0, T1, 0> texture {pigment {color Red}
torus {OutsideCircle, T2 translate <0, T1, 0> texture {pigment {color Green}
finish {phong 0.1}} } // OutsideCircle Circle
torus {Hub, T1 translate <0, T1, 0> texture {pigment {color Black} finish
{phong 0.1}} } // Recessed Hub Circle
torus {Hole, T1 translate <0, T1, 0> texture {pigment {color Black} finish
{phong 0.1}} } // Shaft hole
// Center marker
cylinder {<-OutsideCircle, T1, 0>, <OutsideCircle, T1, 0> T2 texture {pigment
{color Black} finish {phong 0.1}} }
cylinder {<0, T1, -OutsideCircle>, <0, T1, OutsideCircle> T2 texture {pigment
cylinder {<-OutsideCircle*2, T1, RootCircle>, <OutsideCircle*2, T1, RootCircle>
T2 texture {pigment {color Black} finish {phong 0.1}} }
#declare CircularThicknessAngle = (360/N)*0.5; // Circular Thickness Angle
0.5 because teeth AND spaces
#declare Degrees = 90; // Degrees to rotate through involute
#declare Radians = Degrees * pi/180; // Radians to rotate through involute
#declare AngularSpacing = 360/Teeth; // How many degrees to rotate involute
curves for next tooth
#for (Tooth1, 0, Teeth)
#declare Tooth2 = Tooth1 + 0.5;
#for (theta, 0, Radians, 0.001)
#declare X = RootCircle * (cos(theta) + theta*sin(theta));
#declare Z1 = RootCircle * (sin(theta) - theta*cos(theta));
#declare Z2 = -RootCircle * (sin(theta) - theta*cos(theta)); // Opposite
side of involute tooth
sphere{ <X, T1, Z1>, T1 pigment {Blue} rotate -y*Tooth1*AngularSpacing}
sphere{ <X, T1, Z2>, T1 pigment {Blue} rotate -y*Tooth2*AngularSpacing}
#declare Distance1 = sqrt (pow (X,2) + pow (Z1,2)); // radius at this point
in the plotting of the gear tooth
// check if at RootCircle Circle
#if ( theta = sqrt (abs ((Distance1 / RootCircle) - 1) ) )
sphere{ <X, T1, Z1>, MarkerCircle pigment {Green} rotate
sphere{ <X, T1, Z2>, MarkerCircle pigment {Green} rotate
// check if at OutsideCircle Circle
#if ( theta > sqrt ((pow (OutsideCircle, 2) - pow (RootCircle, 2)) /
RootCircle) ) // Seems broken. Thanks, M.I.T :|
sphere{ <X, T1, Z1>, MarkerCircle pigment {Yellow} rotate
sphere{ <X, T1, Z2>, MarkerCircle pigment {Yellow} rotate
/* check if involutes cross
#declare NegInvolute = transform {rotate <0, -AngularSpacing, 0>};
#declare NI_Point = vtransform (<X, T1, Z2>, NegInvolute);
#if ( abs(NI_Point.z) - abs(Z1) < 0.1)
sphere{ <X, T1, Z1>, MarkerCircle pigment {Gray50} rotate
//sphere{ <X, T1, Z2>, MarkerCircle pigment {Green} rotate
#end // end for
Download 'involute.png' (120 KB)
Preview of image 'involute.png'
![involute.png](/povray.binaries.images/attachment/%3Cweb.56ead6a6f14b8acb5e7df57c0%40news.povray.org%3E/involute.png?ttop=443824&toff=1100&preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
Le_Forgeron <jgr### [at] free fr> wrote:
> the top part of a teeth must never be close to the bottom part of the opposite gear.
> IIRC, if top part (difference of radius between red and green) circle is 1, the
> bottom part (grey and red) should be 1.25.
Yes, I would agree that there needs to be more [any] clearance between the teeth
of one gear and the body of the other. I'm progressing towards that.
> And unless you have a specially made gear, the perpendicular straight line to the
black line
> (which start at the red line ?) should be the line on which the teeth of each gear
get in contact
Right the gears ought to meet where the red circles are tangent, and "roll"
along a line that is tangent to both base circles - which makes it normal to
both involutes at that point. I'm working on illustrating that.
> You are correct: you have a problem with the width of the tooth.
I'll look through that - I've probably seen 100 similar pages, but that doesn't
help me "put it all together" especially when a lot of things are interrelated,
and changing one thing then changes 5 others. So, this will likely be an
intermittent mix of progress, error, and correction.
> And despite the top schema, the outer circle of one gear does not match the inner
circle of the other. Never.
> If it was, the smallest particle at the top of a tooth would block the system when
crunched in the pit.
Yes. I have yet to add any clearance, and I need to learn more about how to
construct an undercut.
I found this fascinating page:
http://www.codeproject.com/Articles/1037482/Drawing-Gears-Circular-and-Non-Circular
But apparently the code may need some fixing to run. I can read it and learn
from it though :)
Thanks for keeping an eye on things and keeping me on course.
There is always so much to learn.
![](/i/fill.gif) |
