POV-Ray : Newsgroups : povray.binaries.images : Le Forgeron: experiments Server Time
28 Mar 2026 04:24:11 EDT (-0400)
  Le Forgeron: experiments (Message 62 to 71 of 71)
Subject: Re: Le Forgeron: experiments
Date: 4 Sep 2016 09:15:00
Message: <web.57cc1d431d798e7f7a3e03fe0@news.povray.org>
Not all objects can I simulate in Blender.
Tesselation - this is what you need.
Today I wrote gts import. Later, I will write an automatic converter.
Most of all I'm interested in the object blob.
Tessel and tesselate give a bad result. Others get well.
            items=[("bourke", "bourke", ""),
                   ("cristal", "cristal", ""),
                   ("cubicle", "cubicle", ""),
                   ("heller", "heller", ""),
                   ("tessel", "tessel", ""),
                   ("tesselate", "tesselate", "")],
#version 3.7;
#include "functions.inc"
global_settings {
    assumed_gamma 1.000000
    max_trace_level 3
    charset utf8
sky_sphere {
    pigment {rgb<0.051, 0.051, 0.051>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare data_Blob_ob = blob {
    threshold 0.6
    sphere { <0,0,0>, 1.702, 2 texture {Default_texture}
    matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.000000,
0.000000, 1.000000, -0.000000,  0.000000, 0.000000, 0.000000>
0.000000, 1.000000, -0.000000,  0.905406, 0.181065, -1.091782>
#declare Test = tesselate {original data_Blob_ob accuracy 50 texture{pigment
{rgb 0.8}}}
//object{Test}
gts_save { "/home/leonid/test.gts",Test}
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
    fade_distance 29.9999828339
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-26.440706, 46.691945, -0.000003>
    translate <7.481132, 5.343666, 6.507640>
Download 'tesselation.jpg' (375 KB)
Preview of image 'tesselation.jpg'
Date: 4 Sep 2016 13:37:38
Message: <57cc5be2@news.povray.org>
Thanks for spotting a bug in tessel and tesselate.
Now patched to get a closed surface.
Download 'after.png' (94 KB) Download 'before.png' (102 KB)
Preview of image 'after.png'
Preview of image 'before.png'
Date: 8 Mar 2017 13:30:00
Message: <web.58c04cc81d798e7f7a3e03fe0@news.povray.org>
Hello!
Good idea: load binary file format.
But object has no color. :(
#version 3.7;
global_settings {
    max_trace_level 3
    charset utf8
sky_sphere {
#declare Material = texture{
    pigment{color srgbft <0.8000,0.8000,0.8000,0.0000,0.0000>}
    finish{
        diffuse 0.8000
        brilliance 1.8000
stl_load { "/home/leonid/untitled.stl" }
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
untitled.stl in attachment.
Download 'untitled.stl.dat' (1 KB)
Date: 8 Mar 2017 13:50:01
Message: <web.58c0512e1d798e7f7a3e03fe0@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> Hello!
> #version 3.7;
> global_settings {
>     max_trace_level 3
>     charset utf8
> sky_sphere {
>     finish{
>         diffuse 0.8000
>         brilliance 1.8000
> light_source {
>     <4.08,5.9,-1.01>
>     color rgb<1, 1, 1>
>     fade_power 1
> camera {
>     perspective
>     location  <0,0,0>
>     look_at  <0,0,-1>
>     up <0, 1, 0>
>     angle  49.134343
stl_load { "/home/leonid/untitled.stl" texture { Material }}
But, the cube can have different textures for each polygon.
It would be nice to use a texture_list.
Date: 8 Mar 2017 14:41:06
Message: <58c05e52@news.povray.org>
And which version of STL would you use ?
There is 2 incompatible format for color encoding (in binaray STL):
* As stated on wikipedia:  generic STL file reader cannot automatically
distinguish between them.
* 2 "attribute byte count" bytes at the end of every triangle store a
15-bit rgb color information
** bits 0-4 for blue, bits 5-9 for green, bits 10-14 for red, bit 15 set
when color is valid
** bits 0-4 for red, bits 5-9 for green, bits 10-14 for blue, bit 15
unset when color is local, set to use global
* the header (80 bytes) can have overall color specification (only for
the latter encoding)
** but it can have COLOR=RGBA or/and MATERIAL= with 12 bytes for diffuse
reflection, specular highlight and ambient light
The stl_load-ed object is an usual povray shape: immerge it in whatever
texture/pattern you want.
(actually, it's a mesh once loaded, but there is no uv coordinates in
STL to help you)
And to make things funnier, no one as a clue about the 15 bit color
space: is it linear or gamma corrected ? (and which correction)
happy reading :
https://en.wikipedia.org/wiki/STL_(file_format)
Date: 8 Mar 2017 15:30:00
Message: <web.58c068df1d798e7f7a3e03fe0@news.povray.org>
> when color is valid
> STL to help you)
> happy reading :
No,no,no. Only idea. STL as base.
We can write an string array at the end of the file:
mesh_materials=['glass','wood','metal']
We can write an integer array at the end of the file:
face_material_indexes=[mesh_materials[0],mesh_materials[2],mesh_materials[1],mesh_materials[1],mesh_materials[2],mesh_m
aterials[0]]
If it is written to a file, you can change the parser.
Now in .pov
#declare Metal = texture{}
#declare Wood = texture{}
#declare Glass = texture{}
#declare My = texture_list{3,texture{Metal},texture{Wood},texture{Glass}}
stl_load{filename,texture_list{My}}
Date: 8 Mar 2017 17:25:20
Message: <58c084d0$1@news.povray.org>
IMHO, no.
STL is not extensible.
It was designed in the 80's, without provision (at least in binary) for
extensions.
The added trailer is probably going to be lost when edited by any
program supporting STL... if it can load it at all.
If you want to design a new file format, go for it, but you cannot call
it STL.
If only povray can read your file, what about using the normal scene
language of mesh or mesh2 ?
The loaded STL can be exported with some macro to explore the relevant
mesh, see "Access to data of mesh", top of the page :
https://bitbucket.org/LeForgeron/povray/wiki/Object
(the export is left as an exercise for the reader)
Date: 9 Mar 2017 10:55:00
Message: <web.58c179e31d798e7f7a3e03fe0@news.povray.org>
If I have time to model and animate, then I will use hg-povray.
I'm interested in experiments with tessellation. :)
But... using the normal scene language of mesh or mesh2... This is the fastest
way to load an object into a scene? Is there a way to speed it up? :)
Date: 9 Mar 2017 11:52:29
Message: <58c1884d$1@news.povray.org>
The fastest is mesh2, because it is as near as the internal data as
possible.
Everything else need to search each new item in the already loaded part,
which mean the loading process is something O(n²) or at least
O(n.log(n)) when mesh2 is O(n).
So, the less triangles, the better.
GTS & STL have the advantage of avoiding text parsing, for the binary
format, yet the transformation into internal data need to perform search
on unsorted data so they get O(n²) performance as the number of
triangles increases it starts to suck (or slowdown enough to be noticed).
mesh syntax cumulate the drawbacks: text parsing and repeated search.
The real fast would be a binary serialization of the internal data, but
that is not available (yet ? do not hold your breath for it); and no
actual editor would be able to handle it (and it would be yet another
file format)
My rule of thumb:
* small mesh, you can use gts or stl.
* really huge number of triangles, you better load via mesh2 syntax
The power of your I/O, CPU, memory and your patience draw the line
between small and huge.
Date: 9 Mar 2017 12:55:00
Message: <web.58c193e91d798e7f7a3e03fe0@news.povray.org>
> possible.
> file format)
> My rule of thumb:
Thanks!
Probably, I need here:
http://www.amd.com/en/ryzen
While I'm collecting money, I need to work with tessellation so that the mesh
transformed object is automatically loaded into the Blender for new
transformations and new tesselations. Perhaps, interesting results will be
obtained.
