POV-Ray : Newsgroups : povray.binaries.images : waste of time! Server Time
29 Mar 2026 18:04:08 EDT (-0400)
  waste of time! (Message 7 to 16 of 66)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: waste of time!
Date: 28 Jan 2008 10:11:14
Message: <479df092$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/27 20:20:
> so, any free time in your hands?  want to put that quad core to stress with
> povray 3.7beta?  If you're, try the little scene below.  With +AM2 +A0.04 +J1.0
> 1024X768 on a P4 2.66, it just brought my PC to a crawl for the whole weekend!
> It all began with a challenge in a brazilian forum, when some guy claimed this
> scene:
> http://200.213.105.41/greysilica/exemplos/cjcopojateado.png
> took him 48 hours to render with Blender internal renderer.
> Surely something was wrong, or so I thought.  Well, in the region between the
> bottom of second row cups and the top of first row cups, render time was about
> 11 minutes a line!  It is all about refractions, normals and fresnel
> reflections.  40 hours total on a P4 2.66 with povray 3.6.1...
> I'm sure it's possible to optimize it with some no_image, no_shadow trickery
> with doubles and no_reflection in the main cups, but I didn't thought of it
> beforehand!
You have multiple reflections and refractions. That mean that you have tons of
rays to compute. Add the aa and the small bumps, you need lot of subsampling =
lot of time.
Try adding adc_bailout 0.01 in the global_settings.
It will cause a small decrease in quality that can go unnoticed, but will
accelerate things as the ray tracing will often stop much earlier.
The strongest reason for the people to retain the right to keep and bear
arms is, as a last resort, to protect themselves against tyranny in
government.
Thomas Jefferson
Date: 28 Jan 2008 10:51:40
Message: <479dfa0c@news.povray.org>
seemingly, yes.  It gives a "suspicious" warning at the console output.
It's rgbft.  I think I should've put some more transmit and a little less
filter.  Hmm, I suppose 1 filter and 1 transmit do not work right:  the
color became quite bizarre when I tried...  I also think the original
image had a lot more diffuse and ambient as well...
Download 'us-ascii' (1 KB)
Date: 28 Jan 2008 10:53:36
Message: <479dfa80$1@news.povray.org>
> less filter.  Hmm, I suppose 1 filter and 1 transmit do not work right:
>  the color became quite bizarre when I tried...  I also think the
> original image had a lot more diffuse and ambient as well...
I heard (filter + transmit) should be <= 1 for things to look correctly.
Date: 28 Jan 2008 10:54:19
Message: <479dfaab@news.povray.org>
> tons of rays to compute. Add the aa and the small bumps, you need lot of
> subsampling = lot of time.
> will accelerate things as the ray tracing will often stop much earlier.
He also has focal blur (commented out on the scene, but looks like the
image has it).
Date: 28 Jan 2008 10:55:41
Message: <479dfafd@news.povray.org>
> z*2.6-y/3+x*.1 instead of <0.1, -1/3, 2.6>? This isn't the obfuscated
code contest, you know :)
it's what happens when you begin with just one dimension and then add
another, and then, a last one as well... :P
> I'm trying to modify the scene so that the camera gets rotated, instead
> of the whole scene. And taking that lightsource outside the union. My
> final goal is a camera rotate y*360*clock that looks good. It's not
> turning out so easy...
not really needed camera rotation for that.
just before rotate -x*amount
add:
rotate y*360*clock
Download 'us-ascii' (2 KB)
Date: 28 Jan 2008 10:56:57
Message: <479dfb49@news.povray.org>
Nicolas Alvarez napsal(a):
>> output.  It's rgbft.  I think I should've put some more transmit and a
>> little less filter.  Hmm, I suppose 1 filter and 1 transmit do not
>> work right:  the color became quite bizarre when I tried...  I also
>> think the original image had a lot more diffuse and ambient as well...
f+t <= 1
f   >  0
t   >  0
Did I forget something?
Date: 28 Jan 2008 10:58:03
Message: <479dfb8b@news.povray.org>
I think he used basically the same setup, but only too late I realized the
light should be closer and be directional.  Also, I think he used some
specular on the floor.  It's much too bright.
BTW, my bezier curve drawing skills suck. :P
Date: 28 Jan 2008 11:01:19
Message: <479dfc4f@news.povray.org>
> add:
> rotate y*360*clock
I tweaked lots of settings. I think the camera position doesn't look
exactly as before, but good enough. Rotating the whole scene in the way
you say didn't look right, for some strange reason. I also had to tweak
the z position to make the 'rotation center' better.
[global settings, background, cup, and tex unmodified from original,
snipping to make post shorter]
light_source {
   1.6*(4-z*8)+y*8
   1.2
   area_light
   x,y,4,4
   circular orient jitter
translate -z*0.8
union {
plane { y 0 pigment { rgb 1 } finish { ambient .2 diffuse .6 } }
object { cup translate 0 tex( <.7,.8,1,.8,.1> ) }
object { cup translate z*.7 tex( <.9,.86,.4,.8,.1> ) }
object { cup translate z*(.7+1.3) tex( <1,.96,.84,.8,.1> ) }
object { cup translate x*.7 tex(<1,1,1,.8,.1> ) }
object { cup translate x*.7+z*.7 tex(<.96,1,.67,.8,.1> )}
object { cup translate x*.7+z*.7*2 tex(<.7,1,.7,.8,.1> ) }
object { cup translate -x*.7 tex(<1,.6,.6,.1,.8> ) }
object { cup translate -x*.7+z*(.0+1.3) tex(<.5,.5,.8,.1,.8> ) }
object { cup translate -x*.7*2+z*(-.7+1.3) tex(<.7,1,.94,.1,.8> ) }
translate -z*0.8
light_source { <0,1,-8> .7 shadowless }
   location <0,1.5, -3>
   look_at 0
   angle 55
   //yes, I actually tried focal blur for the final render
   aperture .04 blur_samples 60 confidence 1 focal_point y/3+z*2
   rotate y*360*clock
Date: 28 Jan 2008 11:01:56
Message: <479dfc74$1@news.povray.org>
Well, I did change rgb with rgbft on the texture :)
PS: you're posting in HTML again.
Date: 28 Jan 2008 11:06:01
Message: <479dfd69@news.povray.org>
tons of
subsampling =
> lot of time.
yes, but looking at the original scene for the first time, I'd never have
guessed it!
but you're right, there are rays passing through 3 cups with IOR and
normals, as well
as reflecting off the other cups in the scene.  It's insanity squared!
I'll try that.  As well as some no_image, no_shadow trickery...
will
And I didn't even go with media for blurry shadows, area_lights, radiosity
and caustics!
I wonder how much time it'd take in an unbiased renderer such as Indigo or
Luxrender...
