Here's one of the Kepler-Poinsot solids: the small stellated dodecahedron,
on a Penrose tiling floor. The code also contains a slightly simpler & more
accurate dodecahedron than the one in the shapes2.inc.
Enjoy!
// Persistence of Vision Ray Tracer Scene Description File
// File: Dodec.pov
// Vers: 3.5
// Desc: Dodecahedron & small stellated dodecahedron
// Date: 2006.13.05
// Auth: PM 2Ring
// -d +A0.2 +AM2 +R4
// -F -A0.4 +AM2 +R1
// +A0.5 +AM2 +R2
// -d +A0.1 +AM2 +R4 +w1200 +h900
// +A0.3 +AM2 +R3
// -d +A0.5 +AM2 +R2 +w1200 +h900
// +A0.2 +AM2 +R2 +w1200 +h900 +FN
global_settings {
assumed_gamma 1
max_trace_level 50 // 7
#declare Area_Lights = 0;
#declare Do_Floor = 1*8;
#declare Reflect = 1*.75;
#declare WorldRad = 40;
//#declare CamLoc = <0, 15, -6.25> * .95;
//#declare CamLoc = <0, 4, -5> * 1;
#declare CamLoc = <0, 2, -6.25>* 2.0;
//#declare LookAt = 0;
//#declare CamLoc = <2.5, -3, 0.75>;
#declare LookAt = y*1.2;
location CamLoc
look_at LookAt
right x*image_width/image_height up y
direction z
angle 30
#if(1)
light_source {
<-0.75, 5, -3> * 4.5
//rgb 1
rgb 100 fade_distance 2.0 fade_power 2 //1.65 2.25
#if(Area_Lights)
#declare AL = 9;
#declare ASize = 0.75;
area_light x*ASize, z*ASize, AL, AL
adaptive 1 // 2
jitter
circular
orient
light_source {CamLoc rgb .1 shadowless}
//---Textures--------------------------------------------------------------
//For sky
#declare CMGray0 = color_map {[0.2 rgb 0.1][0.8 rgb .9]}
//For ground
#declare CMGray1 = color_map {[0 rgb .60][1 rgb 1.0]}
//Block finish
#declare FShiny =
finish{
ambient 0.075
diffuse .8
specular .75 roughness 3e-4
phong .5 phong_size 5
#if(Reflect)
//reflection .175*Reflect
reflection {0.05, 1 fresnel}
conserve_energy
#declare FGlass =
finish
ambient 0
diffuse 0.15 //.2
#if(Reflect)
reflection {0.05*Reflect, 1*Reflect fresnel}
specular .75
roughness 1E-4
//brilliance 1.5
conserve_energy
#declare TGlass = texture
pigment { color rgbf <0.985, .9975, .990, 1> }
//pigment { color rgbf <0.985, .9975, 1, 1> }
finish{FGlass}
#declare FGround =
finish{
ambient 0.05
specular .25 roughness 3e-4
reflection .75*Reflect diffuse .7 //2
#declare TGround =
texture{
//pigment{granite scale 75 colour_map{CMGray1}}
//pigment{checker rgb 0, rgb 1 rotate 45*y scale 2}
pigment{rgb 0*.75}
finish{FGround}
//Tile textures
#declare Tex1=
texture{
pigment{rgb 0}
finish{FGround}
#declare Tex2=
texture{
pigment{rgb 1}
finish{FGround}
#declare Tex3=
texture{
pigment{rgb 0.5}
finish{FGround}
#declare TSky =
texture{
function{abs(y)}
color_map{CMGray0}
finish{ambient 0.1 diffuse 0.85}
//---Macros-------------------------------------------
#macro FaceColour0(N)#end
#macro FaceColour(N)
#local Hue = 180 + 240*(mod(7+N,11))/11;
//#local Hue = 240*mod(N,2);
pigment{colour CHSV2RGB(<Hue, .75, .95>)filter 0.9} // transmit 0.65
//pigment{colour CHSV2RGB(<Hue, .65, .85>)}
//pigment{rgb x}
finish{FShiny}
//finish{FGlass}
#macro Pentamid(A, B, C, D, E, F)
intersection
object{Planes[A] inverse}
object{Planes[B]}
object{Planes[C]}
object{Planes[D]}
object{Planes[E]}
object{Planes[F]}
// ---Penrose triangle macros-------------------------------------
#declare Phi=(sqrt(5)+1)/2; //The Golden ratio
#declare phi=Phi-1;
//Interpolate from A to B
#macro inter(A,B,r) (A*(1-r)+B*r) #end
#macro PutSlim(A,B,C,P)
#if(P)
#local T1 = Tex1;
#local T2 = Tex2;
#else
#local T1 = Tex2;
#local T2 = Tex1;
#local E = inter(A,B,.5);
#local F = inter(A,C,phi);
#local G = inter(B,C,Phi/2);
triangle{A,E,F texture{T1}}
triangle{C,F,G texture{Tex3}}
triangle{B,E,F texture{T2}}
triangle{B,G,F texture{T2}}
#macro PutWide(A,B,C,P)
#if(P)
#local T2 = Tex2;
#else
#local T2 = Tex1;
#local E = inter(B,A,Phi/2);
#local F = inter(B,C,phi);
triangle{A,F,E texture{Tex3}}
triangle{A,F,C texture{Tex3}}
#macro Slim(A,B,C,D,P)
#if(D=0)
PutSlim(A,B,C,P)
#else
#local E = inter(A,B,phi);
#local F = inter(C,A,phi);
Wide(F,E,A,D-1,P)
Slim(C,E,F,D-1,P)
Slim(C,E,B,D-1,P)
#macro Wide(A,B,C,D,P)
#if(D=0)
PutWide(A,B,C,P)
#else
#local E = inter(C,B,phi);
Wide(E,A,B,D-1,1-P)
Slim(C,A,E,D-1,1-P)
#declare Top = 0*-1E-4; //Tile top height
#declare Ang = pi/5;
#declare Ang0 = radians(-117);
#declare Ang1 = radians(-81);
#declare Rad = WorldRad;
#declare Rdepth = Do_Floor;
#if(Do_Floor)
#declare Wedge=mesh{
Slim(0, <cos(Ang0), 0, sin(Ang0)>*Rad, <cos(Ang1), 0, sin(Ang1)>*Rad,
Rdepth, 0)
translate Top*y
#declare Floor =
union{
#declare I=0;
#while(I<5)
object {Wedge rotate y*72*I}
object {Wedge matrix <0,0,-1, 0,1,0, -1,0,0, 0,0,0> rotate y*72*I}
#declare I=I+1;
rotate 9*y
//--------------------------The objects-------------------
//Pre-compute dodecahedron planes
#declare Planes = array[12];
#declare Planes[0] = plane { y, 1 FaceColour(0)};
#declare Planes[11] = plane {-y, 1 FaceColour(11)};
#declare I=1;
#while(I<=5)
#declare Planes[I] = plane {<0, 1, -2>, 1 rotate y*(36+72*I)
FaceColour(I)};
#declare Planes[I+5] = plane {<0, -1, -2>, 1 rotate y*72*I
FaceColour(I+5)};
#declare I=I+1;
#declare Dodecahedron =
intersection
#declare I=0;
#while(I<12)
object{Planes[I]}
#declare I=I+1;
bounded_by {sphere {0, 1.258409}} //(2-Phi)*sqrt(3*Phi+6)
#declare SSDodec =
//union
merge
Pentamid(0, 1, 2, 3, 4, 5)
Pentamid(1, 0, 2, 5, 6, 7)
Pentamid(2, 0, 1, 3, 7, 8)
Pentamid(3, 0, 2, 4, 8, 9)
Pentamid(4, 0, 3, 5, 9, 10)
Pentamid(5, 0, 1, 4, 6, 10)
Pentamid(6, 11, 10, 7, 5, 1)
Pentamid(7, 11, 8, 6, 2, 1)
Pentamid(8, 11, 9, 7, 3, 2)
Pentamid(9, 11, 10, 8, 4, 3)
Pentamid(10, 11, 9, 6, 5, 4)
Pentamid(11, 10, 9, 8, 7, 6)
object{Dodecahedron}
//interior{ior 1.5 dispersion 1.1 dispersion_samples 5}
interior{ior 1.5}
bounded_by {sphere {0, sqrt(5)}}
rotate x*degrees(atan(3-sqrt(5)))
translate y*1.7761
#declare Ground =
cylinder{
-y, Top*y, WorldRad
texture{TGround}
#declare Sky =
sphere {0,1 inverse
texture{TSky}
scale WorldRad
//--------------------------The actual scene-------------------
#if(1)
object{Sky}
#else
background{rgb 0.5}
#if(Do_Floor)
object{Floor}
#else
object{Ground}
#if(1)
object{
//Dodecahedron
SSDodec
//texture{TGlass}
//translate y
rotate y*(180 - 3*18)
//scale 1.25
//translate -Phi*z
//-------------------------End of file-------------------------
Download 'dodecf0ws.jpg' (114 KB)
Preview of image 'dodecf0ws.jpg'
