POV-Ray : Newsgroups : povray.binaries.images : Exploring Medieval windows Server Time
29 May 2024 04:25:51 EDT (-0400)
  Exploring Medieval windows (Message 17 to 26 of 26)
Subject: Re: Exploring Medieval windows
Date: 14 Mar 2019 03:43:09
Message: <5c8a060d$1@news.povray.org>
On 13-3-2019 19:47, MichaelJF wrote:
> Am 13.03.2019 um 12:49 schrieb Thomas de Groot:
>> This is #2.
>> Basic frame texture and some small issues (code needs cleaning up).
> Hello Thomas,
> congratulations, you crafted this very well. It's very to close to my
> macros and showing, that I overlooked a small issue. But with sane
> definitions of the width of the wooden frame no one will notice my fault;)
Thank you indeed, Michael. I have not yet looked at your code but will
do that soon. However, your test image is very explicit and shows the
good work already.
The small issue I was talking about is the thin line of light visible
between the glass/lead and the window frame. It could be the window
being a tiny bit too small but I guess it is light "leaking" at angles.
Something similar is shown at the angle between floor and wall. I dimly
remember this phenomenon was discussed many years ago and I do not
remember the way to correct that, except, I believe, by using stochastic
anti-aliasing. I shall test that in any case.
Date: 14 Mar 2019 08:28:54
Message: <5c8a4906$1@news.povray.org>
As I supposed indeed, stochastic antialiasing (with no_cache) solves the
issue.
Date: 15 Mar 2019 04:36:02
Message: <5c8b63f2@news.povray.org>
>> angles. Something similar is shown at the angle between floor and
>> wall. I dimly remember this phenomenon was discussed many years ago
>> and I do not remember the way to correct that, except, I believe, by
>> using stochastic anti-aliasing. I shall test that in any case.
> issue.
The downside of this is that combining stochastic aa with photons, will
dramatically decrease render speed. A rough calculation for the image
above, with a crude setting of aa (+a0.1) and with photons enabled,
shows that it will take at least 24 hours to render. :-(
Date: 15 Mar 2019 07:54:12
Message: <5c8b9264$1@news.povray.org>
>> the issue.
Not precise enough I am afraid. I need to give you more relevant info:
+ The issue mentioned above was solved using UberPOV, without photons,
and with no_cache on in the radiosity block. Command line: +w640 +h640
+am3 +a0.01 +ac0.995 +r3 +bm2 +bs8 +wt6. Radiosity's count was lowered
to 10. Render time seemed acceptably "low" (I didn't render a complete
image).
+ The same settings using UberPOV, this time with photons on, the render
time soared up to the estimate of 24 hours+.
+ Using the latest version of 3.8, and with identical settings for +am3
on the command line (no_cache is /not/ available in this version), both
with or without photons available, the render time was "low" i.e.
acceptable for a test and within the hour. However, the issue mentioned
above was *not* solved. I tried to increase dramatically the count value
in the radiosity block but to no avail where the issue was concerned.
I would like some expert's view on the matter please.
Date: 15 Mar 2019 17:39:21
Message: <5c8c1b89$1@news.povray.org>
>>>> visible between the glass/lead and the window frame. It could be the
>>>> window being a tiny bit too small but I guess it is light "leaking"
>>>> at angles. Something similar is shown at the angle between floor and
>>> the issue.
>> will dramatically decrease render speed. A rough calculation for the
>> image above, with a crude setting of aa (+a0.1) and with photons
>> enabled, shows that it will take at least 24 hours to render. :-(
> image).
The most obvious issue that I see is where the wall meet the floor. It
looks like you are getting radiosity samples from the back of the wall.
Some possibility :
Make the wall go slightly lower than the floor.
Place another box inside the wall at the floor's level.
Add a plinth in front of the wall. It can make the scene more realistic
at the same time.
Scale up the whole scene by some factor, like 10 times. If using spacing
for the photons, increase it by the same factor.
If you have some problem with the window, try making the outer edge
broader so that it goes into the red frame.
Date: 16 Mar 2019 03:40:36
Message: <5c8ca874$1@news.povray.org>
>>>>> the window being a tiny bit too small but I guess it is light
>>>>> "leaking" at angles. Something similar is shown at the angle
>>>>> between floor and wall. I dimly remember this phenomenon was
>>>>> discussed many years ago and I do not remember the way to correct
>>>>> that, except, I believe, by using stochastic anti-aliasing. I shall
>>>> the issue.
>> image).
>> render time soared up to the estimate of 24 hours+.
>> +am3 on the command line (no_cache is /not/ available in this
>> version), both with or without photons available, the render time was
>> "low" i.e. acceptable for a test and within the hour. However, the
>> issue mentioned above was *not* solved. I tried to increase
>> dramatically the count value in the radiosity block but to no avail
Thank you Alain, much appreciated. some answers:
> Some possibility :
That is already the case.
> at the same time.
That is certainly something to do.
That is an interesting idea to follow up upon. I seem dimly to remember
now that this was the best solution given in the past. This time, I am
going to write that down in my notes book. ;-) [and then forget about it
of course]
That also is already the case. I shall see what happens when scaling the
scene up.
Thanks again!
Date: 18 Mar 2019 09:32:30
Message: <5c8f9dee$1@news.povray.org>
Thomas de Groot wrote on 13/03/2019 12:49:
> This is #2.
A beautiful light.
Paolo
Date: 20 Mar 2019 04:53:52
Message: <5c91ffa0@news.povray.org>
> Some possibility :
> at the same time.
This image version has been scaled up x10. Initially, the bleeding did
not disappear, only after I gave the walls a more complex texture was it
reduced. I think that it was mostly the uniform pigment that was at issue.
The window's edge still shows the issue; I need to look deeper.
To brighten up the room, I gave the walls a tiny bit of emission.
Instead of aa, I used a bit of focal blur.
Download 'cive medieval_test_#2b.png' (464 KB)
Preview of image 'cive medieval_test_#2b.png'
Date: 20 Mar 2019 11:25:06
Message: <5c925b52$1@news.povray.org>
>> Some possibility :
>> realistic at the same time.
>> spacing for the photons, increase it by the same factor.
Try making the window edges a little bit thicker, or add some thin
strips around it. The strips will act a little like the plinths at the
bottom of the walls. Make them black.
Date: 21 Mar 2019 08:22:42
Message: <5c938212$1@news.povray.org>
That does not do the trick. Like the plinths in the room, the bleeding
is just moved to the corner plinth/frame, as was the corner plinth/wall
before I changed the wall texture. So, the solution lies elsewhere, but
I do not know where at the moment.
