POV-Ray : Newsgroups : povray.binaries.images : Steam Fog: First WIP Server Time
27 May 2026 19:58:58 EDT (-0400)
  Steam Fog: First WIP (Message 28 to 37 of 57)
Subject: Re: Steam Fog: First WIP
Date: 1 Mar 2019 13:41:31
Message: <5c797cdb$1@news.povray.org>
Hello Thomas,
thanks again. May be I read this section some years ago but it did not
came into my mind. The only problem was, that it led me to a wrong track
regarding the container issues with the steam fog approximation. I will
not use an emitting media as sun but will follow an approach by Johannes
Eriksson (May-June competition of the IRTC in 2006). But this is a
legacy scene and the conversion is not as simple as I expected.
Best regards
Michael
Date: 1 Mar 2019 20:08:46
Message: <5c79d79e$1@news.povray.org>
Le 19-02-28 à 13:25, MichaelJF a écrit :
> I commented the steam fog approximation out, so it rendered a little bit
> faster. One sees two instances of the same object (it is the example
> from the tutorials shipped with POV but in a box {-2,2 } instead of a
> sphere). The only difference is
> object { Sonne
>     scale <500,500,500>*5
>     translate MediaPos
> object { Sonne
>     translate <3,1,5>
> with MediaPos=< 649.685959 , 1442.616855 , 39968.697311 >
> Obviously I will not use it in my scene. It's just a riddle I
> encountered by chance. I played a little bit with intervals, samples,
> variance, confidence but without any success. It seems to be due to the
> scaling alone.
> Best regards
> Michael
Hints :
Don't change intervals from the default of 1. Higher intervals count =
slower render and may introduce artifacts.
Variance and confidence are used for sampling methods 1 and 2, and are
not used with method 3 (default).
If you use two value for samples, the second will be silently ignored
when using method 3.
Date: 2 Mar 2019 12:47:08
Message: <5c7ac19c$1@news.povray.org>
> Hints :
Many thanks, I think this issues should be stated in the docs more clearly.
Best regards
Michael
Date: 5 Mar 2019 14:06:19
Message: <5c7ec8ab$1@news.povray.org>
Am 24.02.2019 um 20:43 schrieb MichaelJF:
> Am 23.02.2019 um 10:12 schrieb Jörg "Yadgar" Bleimann:
>> Hi(gh)!
>> On 22.02.19 20:04, MichaelJF wrote:
>>> Hi to the crowd,
>>> this image has still a lot of flaws (sun colour and reflections, the
>>> swan model itself, textures of the cattails) and may be limitations
>>> to media by POV. media seems to be handling color_maps or
>>> density_maps different than pigment or texture having no
>>> interpolation between the map entries but shap edges. This is what I
>>> derived in a first attempt. Rendering time was a little bit longer (3
>>> weeks).
>> Just my mustard ;-):
>> The rising fog should be turbulated more, now it looks like small
>> straight columns of mist... and what about using Chris Colefax's
>> lensflare macro?
>> See you in Khyberspace!
>> Yadgar
> Hi Yagdar,
> the rising turbulence is just my problem (see the code I posted some
> minutes earlier). I cannot see a reason to add lens flare to the image.
> Especially since we have no conversion of the lens flare macros by chris
> colefax to POV 3.7. They did not work with 3.7 so far. I played around
> with them to solve this issue a while ago, but failed unfortunatelly.
> Best regards
> Michael
After looking at a lot of photographies of sundowns and sunrises again I
now understand your recommendation of the lens flare macros. But they
are still resistant to my conversion efforts. To chance ambient by
emission simply doesn't work here. If you study his disc approach it
should work, but there seems to be a hidden secret I have not detected
so far. With Jaime's lightsys this simple exchange works.
Best regards
Michael
Date: 16 Aug 2020 11:55:30
Message: <5f3956f2@news.povray.org>
Am 22.02.2019 um 20:04 schrieb MichaelJF:
> Hi to the crowd,
> swan model itself, textures of the cattails) and may be limitations to
> media by POV. media seems to be handling color_maps or density_maps
> different than pigment or texture having no interpolation between the
> map entries but shap edges. This is what I derived in a first attempt.
> Rendering time was a little bit longer (3 weeks).
> Best regards
> Michael
Hi to the crowd again,
since I lost all the code of the original approach of this image due to
a headcrash, I had to restart this scene from scratch. Only the
erroneous density I posted here was left and the corrections Thomas and
Alain proposed of course. Here is the actual WIP. I wondered how a white
sun can cast yellow beams, but I took this RL image
https://de.wikipedia.org/wiki/Sonnenaufgang#/media/Datei:Sonnenaufgang_penon_de_ifach.jpg
as a basis for the sky_sphere, the sun, and its reflections. I failed to
model this thin slice of white in the reflections in the original
photography so far. But I think to "forget" it, is a venial sin.
I plan to add some pines, cattails, gras, broom, and the swan of course,
but nothing more. The steam fog over land will be invisible after the
addition of the plants (hope so). Additional suggestions are welcome as
ever.
At the moment the rendering time is manageable: some hour with 16
threads at 3.6 GHz (intel core i9).
Best regards
Michael
Download 'gelaende_pov_scene13.png' (849 KB)
Preview of image 'gelaende_pov_scene13.png'
Date: 16 Aug 2020 12:30:00
Message: <web.5f395e5768f7cc2a1f9dae300@news.povray.org>
MichaelJF <mi-### [at] t-onlinede> wrote:
> I failed to
Maybe you can add a cylinder of media that is bisected by the water's surface?
Or layer an AOI texture onto the water?
Other than that, I'd look to prior art in the archives, or in other graphics
groups...
Great job so far!   :)
Date: 17 Aug 2020 02:45:02
Message: <5f3a276e@news.povray.org>
Op 16/08/2020 om 18:27 schreef Bald Eagle:
>> I failed to
> groups...
Great job indeed. First thing I thought concerning this issue was: Tom
York's diffuse modulation. Maybe it can help you: see his comment in the
following thread:
http://news.povray.org/povray.newusers/thread/%3Cweb.4393311ed86e519e4114da700@news.povray.org%3E/?ttop=338362&toff=650
Date: 17 Aug 2020 13:11:23
Message: <5f3aba3b$1@news.povray.org>
Am 17.08.2020 um 08:45 schrieb Thomas de Groot:
>>> I failed to
>> surface?
>> graphics
>> groups...
> following thread:
Thank you both for your suggestions. May be the addition of an other
media may cure the problem but I had a lot of difficulties to adjust the
media as they are so far and will not risk to disturb them by another
one. The other approach proposed by Thomas is the use of a texture_map
to the lake similiar to the construction of my sky_sphere. Fortunatelly
air has no ripples or waves and is more predictable as water. May be I
must have more patience in modellng a filtering disc with a proper
scaled hole
disc {
    0,z,20000, unkown hole size
    pigment { colour srgbf <1,0.847,0.333,1> }
    rotate <0,0,-90-degrees(acos(vnormalize(SolarPosition).z))>
    translate SolarPosition/10000
    no_image no_reflection
Best regards
Michael
Date: 18 Aug 2020 03:15:05
Message: <5f3b7ff9$1@news.povray.org>
Op 17/08/2020 om 19:11 schreef MichaelJF:
>>>> I failed to
>>> surface?
>>> graphics
>>> groups...
>> the following thread:
> scaled hole
> disc {
> Best regards
> Michael
Best approach I guess is the one made by Jaime Vives Piqueres. I have
been working with his code lately for a couple of months (adding foam to
sea water for instance; see my 'Nature Beyond' thread).
See the following link for the technical aspects:
http://www.ignorancia.org/index.php/galleries/old-images/sea-buoy/
Date: 18 Aug 2020 13:46:01
Message: <5f3c13d9@news.povray.org>
> scaled hole
> disc {
> Best regards
> Michael
When working with disc, don't forget that they have an interior that is
not limited to the visible part.
Whenever you have media, you need to add hollow to any disc in the scene.
This :
disc{0 y 10}
have the same interior as this :
plane{y 0}
