POV-Ray : Newsgroups : povray.binaries.images : Exomoon Whatmough - height distribution problem Server Time
25 Feb 2025 09:11:29 EST (-0500)
  Exomoon Whatmough - height distribution problem (Message 1 to 9 of 9)
Subject: Exomoon Whatmough - height distribution problem
Date: 13 Feb 2018 04:21:23
Message: <5a82ae13@news.povray.org>
Hi(gh)!
Meanwhile, I generated the first global physical maps of Whatmough (see
also my posting in p.b.a), starting with the terrain relief and land/see
distribution as shown in the animation (first image attached)... as
ocean depths and land heights were still too extreme for an almost
Earth-sized body, I tweaked the scaling factor of the terrain function
as well as the sea level (second image). But still I'm not contented
with the result, as low-lying land areas (dark and light green) and
shallow continental shelves (pale cyan) are by far too narrow to look
Earth-like. Which parameter(s) of the ridged_mf() function do I have to
change to achieve this?
See you in Khyberspace!
Yadgar
Download '2018-02-12 global map of whatmough, take 1.png' (188 KB) Download '2018-02-13 global map of whatmough, take 4.png' (159 KB)
Preview of image '2018-02-12 global map of whatmough, take 1.png'
Preview of image '2018-02-13 global map of whatmough, take 4.png'
Subject: Re: Exomoon Whatmough - height distribution problem
Date: 13 Feb 2018 04:41:14
Message: <5a82b2ba$1@news.povray.org>
On 13/02/2018 09:21, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
Run a series of animations changing one variable at a time.
That should give you a better idea where to start if you want to refine it.
Regards
Date: 13 Feb 2018 07:44:26
Message: <5a82ddaa@news.povray.org>
On 13-2-2018 10:21, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> Yadgar
I would say that the continental shelf width is ok; the land heights
have a problem indeed.
I may have a solution, but I need to delve deep into my (planetary)
scene files, so patience.
Date: 14 Feb 2018 03:16:29
Message: <5a83f05d$1@news.povray.org>
>> Hi(gh)!
>> (see also my posting in p.b.a), starting with the terrain relief and
>> land/see distribution as shown in the animation (first image
>> attached)... as ocean depths and land heights were still too extreme
>> for an almost Earth-sized body, I tweaked the scaling factor of the
>> terrain function as well as the sea level (second image). But still
>> I'm not contented with the result, as low-lying land areas (dark and
>> light green) and shallow continental shelves (pale cyan) are by far
>> too narrow to look Earth-like. Which parameter(s) of the ridged_mf()
>> function do I have to change to achieve this?
>> Yadgar
Sorry, no luck. I build my planets using a planetary image_map as
function. That is a different approach.
I keep looking for scenes where I might have used ridged_mf(); I know I
have, but it is a needle in a haystack of code...
Date: 15 Feb 2018 11:14:58
Message: <5a85b202$1@news.povray.org>
On 2/13/2018 4:21 AM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> Yadgar
I think what you need is some erosion to smooth some of the sharp edges.
Dunno how to do that though.
Mike
Date: 15 Feb 2018 12:25:03
Message: <web.5a85c22a20d8b322c437ac910@news.povray.org>
A macro or libray that allowed us to do offset-curves, or Minkowski Sums would
accomplish that if he were using a mesh.
http://www3.cs.stonybrook.edu/~algorith/files/minkowski-sum.shtml
Perhaps if he added or subtracted a bit of Perlin noise from the function, it
would accomplish some [random] smoothing of the function.
Date: 15 Feb 2018 14:15:35
Message: <5a85dc57$1@news.povray.org>
Well, I meant realistic weather and coastline erosion. I've played
around with World Machine in the past, but have no clue how to translate
those methods into POV-Ray.
Mike
Date: 15 Feb 2018 16:51:27
Message: <5a8600df$1@news.povray.org>
Hi(gh)!
You probably refer to the sharp contour boundaries in the maps - but
this is just an artifact of coloring defined height ranges (e. g. 0 to
100 metres = dark green, 100 to 200 metres = light green and so on).
With the real isosurface, there are still smooth transitions in height!
Yadgar
Date: 16 Feb 2018 03:13:23
Message: <5a8692a3@news.povray.org>
>>> Hi(gh)!
>>> Yadgar
Maybe this is of help. Do you remember my Geomorph macro from about 10
years ago? It models an isosurface landscape but the principles are
identical for a planet as the same functions are used. If you do not
have the macro, I attach here the latest version with the documentation.
Both are compatible even if the macro versions mentioned in the docs are
different. There is a short description of the ridged_mf function where
the parameter 'offset' might be what you are looking for. Otherwise, I
must say that Geomorph is a monster ;-)
I hope you can make sense of it and extract useful snippets for your
project.
Download 'new winzip file.zip' (427 KB)
