Stephen <mca### [at] aolcom> wrote:
> The lighting is problematic. The light in the hall of mirrors brightens
> when I switch on radiosity. I did not mean this to turn into an
> experiment in radiosity but it looks looks like it is going to be. I
> have a normal area light in there to even things out.
As the mirror reflections indicate, your dance hall has mirrors on only two
walls. I wonder what would happen re: radiosity and photon complexity if all
four walls were mirrored?! (The 'infinite mirror-reflection' thing.) I have no
idea, but it sounds like an interesting experiment to try. ;-)
clipka <ano### [at] anonymousorg> wrote:
> (As a faster alternative to photons for this particular scene, you might
> try using mirrored copies of your primary light sources,
> `projected_through` the corresponding mirrors...
That's an interesting trick, that I wouldn't have thought of. Thanks.
> walls.
Three mirrored walls in fact. I chose the camera position so that I
wouldn't have much of a hall of mirrors, effect.Just a view of three sides.
So you want that I give my machine a stress test? ;)
Of course I'll give it a go. :)
Regards
Not so bad. Less than 6 minutes
No AA nor photons. Max Level 53/64
Regards
Download 'studio_vic2d_y_901a2x_0000.png' (773 KB)
Preview of image 'studio_vic2d_y_901a2x_0000.png'
On 14-11-2017 10:57, Stephen wrote:
> On 14/11/2017 08:03, Thomas de Groot wrote:
>> On 13-11-2017 21:27, Stephen wrote:
>>> The tunic and wings are emissive df3s, made from Poser models.
>>> I think I need a dragon and a rocky scene to complete this. :)
>> Yes indeed although I like this ballet school setting with the mirrors.
> It is old enough to have been made in Moray. :-)
>> A couple of things, if I may: (1) the overhead lights should be dimmed
>> - probably by at least 50 % (if not 25%) also for compensating the
>> light reflections from the mirrors.
> (2) Could you merge this scene with your
>> ballerina animation? That was awesome.
> Hmm! has anyone told you that you have an evil mind, recently?
> As if I haven't enough to do. ;-)
No. Nobody dares to. ;-)
> It is an interesting challenge though. First I have to find out why when
> I create the df3s there is a problem with the handiness. Or more likely
> with my set up. Then unless I wanted to make a df3 that coveres the
> whole playing area. I would need to work out a method of tracking the
> mesh to move the slicing rig there.
> On the brighter side. jr is working on a set of utilities for df3s. So
> it might be possible in the future.
I knew it was a difficult question, but I am confident in the results :-)
Oh! That is good!
No one living. I'm sure. ;-)
>> when I create the df3s there is a problem with the handiness. Or more
>> likely with my set up. Then unless I wanted to make a df3 that coveres
>> the whole playing area. I would need to work out a method of tracking
>> the mesh to move the slicing rig there.
It is an interesting problem and a long term one too. Just looking at
the sums. A five second animation @ 25 fps will produce about 180 Gigs
of data in tga and df3s. I reckon that if I can automate the process it
would take about a hundred hours to produce them. So not a project for
the faint hearted.
* Note the correct usage of the at sign. :-)
Regards
>>> coveres the whole playing area. I would need to work out a method of
>>> tracking the mesh to move the slicing rig there.
>>> So it might be possible in the future.
> the faint hearted.
Dear me, yes, I had not really realised this.
This is coming along very nicely :)
I like this second version a lot - the camera position just works better I
think.
Enhancements:
Maybe someone can contribute a proximity pattern to add some depth to the skin
texture. It also looks to me like either she has no pupils, or her eyelids are
closed, depending upon the size of the image...
I'm sure some of us have some slightly richer looking wood floor macros lying
about. ;)
Is there a way to light the room with HDRI?
Maybe just surround the room with one and add no_shadow?
Just throwing out ideas before turning in for the night.
Thanks but you are not seeing it from this side of the screen. *
> think.
That was just because Kenneth wanted a hall of mirrors.
Remember that this is not an exhibition image but a test image for the
df3s. I placed it in my studio because of the flack I got for Lanya's
dress. ;-)
I'm thinking of using the studio for my test environment because of
getting three additional views of the subject.
> Enhancements:
Here is a close up as changing the eyes in Poser was the only change I
made there.
FYI the female model is a low res one. I don't think it even uses an
image map for the body. So if I wanted more detail I would change it in
Poser. Besides I don't want to get distracted by looking at the model. ;-)
> about. ;)
As I implied to Thomas. The studio is a very old scene. At least ten
years old if I made it in Moray. So any contributions are welcome. :-)
I'm not too keen on that idea. I don't think it would work with three
walls of mirrors. I'm aware of the need for some sort of background.
That is why there are a couple of old chairs and a stack of mats. At one
time I had a table with a stereo and a mop and bucket. Just for interest.
Thanks. I'm flattered over a test image.
* I have no idea why in this image the wings and clothes did not show.
With the render time they should have been there.
But at least you can see that the model is low res and the eyes.
I had two other unexpected results yesterday that has set me back a bit. :-(
Regards
Download 'studio_vic2d_y_903a1_0000.png' (497 KB)
Preview of image 'studio_vic2d_y_903a1_0000.png'
