![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Round brilliant models are a dime a dozen, but I've never seen settings
modeled, so I figured I would do it. I'm satisfied with the prongs, but
I don't know how these things attach to the ring. (Web image searches
haven't helped, because in most of the images, the gem blocked the base
of the setting, and when this wasn't the case, the setting was way too
fancy for my goal.)
I have four models for the base of the setting. Which do you think is
the best, and do you have any better ideas?
Download 'setting_survey-a.jpg' (45 KB)
Download 'setting_survey-b.jpg' (44 KB)
Download 'setting_survey-c.jpg' (45 KB)
Download 'setting_survey-d.jpg' (44 KB)
Preview of image 'setting_survey-a.jpg'
![setting_survey-a.jpg](/povray.binaries.images/attachment/%3C59449400%40news.povray.org%3E/setting_survey-a.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-b.jpg'
![setting_survey-b.jpg](/povray.binaries.images/attachment/%3C59449400%40news.povray.org%3E/setting_survey-b.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-c.jpg'
![setting_survey-c.jpg](/povray.binaries.images/attachment/%3C59449400%40news.povray.org%3E/setting_survey-c.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-d.jpg'
![setting_survey-d.jpg](/povray.binaries.images/attachment/%3C59449400%40news.povray.org%3E/setting_survey-d.jpg?ttop=427364&toff=250&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The much regretted Steve Paget would have known right away! My most
humble personal opinion would favour Plan B or C.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> fancy for my goal.)
I'll make it more difficult to decide by saying A or D instead of Thomas's B or
C.
I don't know anything about jewelry, especially rings, but I just always thought
diamonds or clear gems were placed onto a setting with a reflective underside.
Looking at pictures of ring settings just now it would seem to prove me mostly
wrong.
Many apparently have open space below the prongs, a hole in the ring itself, at
least for this type of setting. I guess that's to allow more light around it.
Maybe because light doesn't refract down and back up very easily??
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> fancy for my goal.)
I prefer the ones with the silver base as I fancy it might reflect light
back into the gem. So for a round cut stone I prefer A and C for a
square cut stone.
Then I remembered my wife has a ring with a similar setting.
So I took a couple of photographs with my old camera.
I'll post them in OT so they will disappear in a fortnight.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> C.
> wrong.
I thought that too but I found this answer that makes sense, to me:
Without a Hole on the underside of the Shank, chances are good, the
Sharp Point of your Stone would Break off during setting.
The Tapered Part of a Diamond is called the Pavilion. The Pavilion comes
to a Sharp Point at the end. That Point is Fragile and can Chip Easily.
Sometimes the Sharp Point has a Flat Facet on the end of it, called the
Culet!
The Culet is only there to keep that Point from Chipping! If you exert
any pressure on that Point during Setting, it can Break it right off and
Crush it. Setting your Diamond into those Round Open Circles keeps your
Diamond or Gemstone Aligned, and keeps the Stones from getting Broken.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> square cut stone.
You've given me a lot to think about; thanks. I suppose I should thank
Steve Paget as well.
Here are a couple more ideas. They are both plan E because the same
macro is used for both renders, but with different arguments.
Download 'setting_survey-e1.jpg' (46 KB)
Download 'setting_survey-e2.jpg' (46 KB)
Preview of image 'setting_survey-e1.jpg'
![setting_survey-e1.jpg](/povray.binaries.images/attachment/%3C594804fc%40news.povray.org%3E/setting_survey-e1.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-e2.jpg'
![setting_survey-e2.jpg](/povray.binaries.images/attachment/%3C594804fc%40news.povray.org%3E/setting_survey-e2.jpg?ttop=427364&toff=250&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
https://www.google.com/search?q=stone+setting+pdf&rlz=1C1CHFX_enUS633US634&oq=stone+setting+pdf&aqs=chrome..69i57j0l2.3
269j0j7&sourceid=chrome&ie=UTF-8
The gems are cut with angles that reflect the light entering mainly from the
table and reflected by the facets of the pavilion.
The prongs hold the gem into the setting by tension.
All else is mostly aesthetics and an attempt to reduce rubbing, chipping, and
loosening of the gem in the setting.
Good work so far - glad you got your laptop problems sorted out! :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> square cut stone.
Ah well it keeps his memory alive.
I like those but I think I would need to see the gems in the settings to
make a comparison.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> make a comparison.
A setting, fully loaded (radiosity, photons, camera DOF), renders in
minutes. A round brilliant stone, fully loaded (above + dispersion),
renders in minutes. The setting and stone combined in one scene? Many
hours!
I sacrificed dispersion, lowered max_trace_level, and used 2-pass
radiosity for these renders. This cut render times to under 15 minutes
each.
I also made a tweak to plan E where the prongs join the base.
Download 'setting_survey-set-a.jpg' (48 KB)
Download 'setting_survey-set-b.jpg' (48 KB)
Download 'setting_survey-set-c.jpg' (48 KB)
Download 'setting_survey-set-d.jpg' (48 KB)
Download 'setting_survey-set-e1.jpg' (49 KB)
Download 'setting_survey-set-e2.jpg' (49 KB)
Preview of image 'setting_survey-set-a.jpg'
![setting_survey-set-a.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-a.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-set-b.jpg'
![setting_survey-set-b.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-b.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-set-c.jpg'
![setting_survey-set-c.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-c.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-set-d.jpg'
![setting_survey-set-d.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-d.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-set-e1.jpg'
![setting_survey-set-e1.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-e1.jpg?ttop=427364&toff=250&preview=1)
Preview of image 'setting_survey-set-e2.jpg'
![setting_survey-set-e2.jpg](/povray.binaries.images/attachment/%3C594fe1d7%40news.povray.org%3E/setting_survey-set-e2.jpg?ttop=427364&toff=250&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> make a comparison.
> hours!
> each.
I like "A" and "D" best.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
