POV-Ray : Newsgroups : povray.binaries.images : Losing the ability to POV... Server Time
17 Feb 2026 04:29:19 EST (-0500)
  Losing the ability to POV... (Message 1 to 10 of 21)
Subject: Losing the ability to POV...
Date: 7 Nov 2016 08:46:27
Message: <582085b3@news.povray.org>
Hi(gh)!
For quite a long time I did hardly anything POV-Ray-related than just
manually editing the Kabul 1:100,000 heightfield or, more recently,
collecting high-resolution OpenTopMap tiles for a more advanced version
of that heightfield...
...and now, I want to re-create a level from the Amiga game
"Rock'n'Roll" in POV-Ray (of course for animating it from the ball's
perspective later on...) - and fail already at the very first step,
which is creating a layered texture for a sky_sphere (or, simpler as not
involving UV_mapping, for six planes forming a cubic space).
The lowermost layer consist of equally spaced squares - so I thought
using the boxed pigment would be appropriate. But... whatever I try, I
always only get uniform black!
Is it an idiosyncrasy of 3.7? Or do I simple lose the general ability to
do anything sensible with POV-Ray?
Here is the code:
#declare P_Cubic_Division_Blue_Layer_1=
pigment
   boxed
   color_map
     [0    rgb 0]
     [1    rgb 1]
   translate <0, -1, 0>
// ACTUAL SCENE
plane
   y, -1
   texture
     pigment
       scale 0.1
     finish
       ambient 1
       diffuse 0
camera
   location 0
   look_at <0, -1, 0>
   angle 40
Subject: Re: Losing the ability to POV...
Date: 7 Nov 2016 09:50:43
Message: <582094c3$1@news.povray.org>
Remember that that boxed pattern is not a repeating one. It is 1.0 at
the origin and 0.0 at the sides of the box. You've moved the boxed
pattern down to the depth of the plane with a translate, but then you
have a scale 0.1 so the value at the plane is outside the box or 0.0
always.
Your camera is also quite close to the plane so even moving to a scale
of 1.0 for the boxed based pigment it might be hard to see the gray
gradient. Perhaps use a camera angle of 80 instead of 40 or move the
camera up the y axis.
Lastly, you might find the pavement or tiling patterns of use for what
you are trying.
Bill P.
Date: 7 Nov 2016 09:51:38
Message: <582094fa$1@news.povray.org>
On 11/7/2016 1:46 PM, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
> ....and now, I want to re-create a level from the Amiga game
> Here is the code:
I thing boxed is not the pattern you want.
To get an image with it move the plane away from the origin.
Weird pattern.
Regards
Date: 7 Nov 2016 09:55:00
Message: <web.582094b843d9fd0d80403a200@news.povray.org>
Hi Yadgar -
I believe that boxed is a non-repeating pattern, and so is wholly unsuited for
what you want, as well as how you're implementing it.
Read the description - it is ONE box.
You would have to translate it -0.5, rather than -0.1 to even see it.
You have no light source.
You have an odd camera position / look at / with no sky to contrast with.
So in essence you're looking at the unlit black plane that you've defined in
your scene.
Here's my quick dabbling that you can edit and see what I mean:
#version 3.7;
global_settings {
 assumed_gamma 1.0
 ambient_light color rgb <1, 1, 1>
include "colors.inc"
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere{ pigment { gradient <0,1,0>
                      color_map { [0.00 rgb <0.6,0.7,1.0>]
                                  [0.35 rgb <0.0,0.1,0.8>]
                                  [0.65 rgb <0.0,0.1,0.8>]
                                  [1.00 rgb <0.6,0.7,1.0>]
                      scale 2
                    } // end of pigment
          } //end of skysphere -------------------------------------
#declare P_Cubic_Division_Blue_Layer_1 =
pigment
   boxed
   color_map
     [0    rgb 0.5]
     [0.5    rgb 0.5]
     [0.5    rgb 1]
     [1    rgb 1]
   translate <0, -0.5, 0>
// ACTUAL SCENE
plane
   <0, 1, 0>, -1
   texture
     pigment
     { //checker Red, Blue
       scale 100
     finish
       ambient 1
       diffuse 0
camera
   location <0, 50, -50>
   look_at <0, 20, 100>
   //angle 40
light_source {<0, 5, -30> rgb 1}
Date: 7 Nov 2016 10:33:05
Message: <58209eb1@news.povray.org>
Hi(gh)!
On 07.11.2016 15:50, Bald Eagle wrote:
> Hi Yadgar -
> I believe that
> what you want,
No, it's not unsuited at all - at least when I use warps! So I did, and
it worked quite well (see attachment)... but now another problem arises
(of course, that's computing!): the inner boxes (uppermost texture
layer, see code) should have a concentric color gradient from greyish
blue to white - but instead, the gradient is centered in the lower left
corner, as if the box pattern uses only a quarter of the entire box! How
can I fix this?
The code:
// FINISHES
#declare F_Background=
finish
   ambient 1
   diffuse 0
// TEXTURES
#declare T_Cubic_Division_Blue_Layer_1 =
texture
   pigment
     boxed
     warp { repeat <1.384, 0, 0> }
     warp { repeat <0, 0, 1.384> }
     color_map
       [0 rgb 0]
       [0.00001 rgb 0]
       [0.00001 rgb <0, 0, 0.192>]
       [1 rgb <0, 0, 0.192>]
   finish { F_Background }
#declare T_Cubic_Division_Blue_Layer_2 =
texture
   pigment
     gradient x
     color_map
       [0       rgbft <0, 0, 0, 1, 1>]
       [0.40625 rgbft <0, 0, 0, 1, 1>]
       [0.40625 rgbft <0.129, 0.125, 0.388, 0, 0>]
       [0.59375 rgbft <0.388, 0.396, 0.678, 0, 0>]
       [0.59375 rgbft <0, 0, 0, 1, 1>]
       [1       rgbft <0, 0, 0, 1, 1>]
     scale 1.384
     translate <-0.192, 0, 0>
#declare T_Cubic_Division_Blue_Layer_3 =
texture
   pigment
     gradient z
     color_map
     scale 1.384
     translate <0, 0, -0.192>
#declare T_Cubic_Division_Blue_Layer_4 =
texture
   pigment
     boxed
     color_map
       [0.125 rgbft <0, 0, 0, 1, 1>]
       [0.125 rgbft <0.388, 0.396, 0.678, 0, 0>]
       [1 rgbft <1, 1, 1, 0, 0>]
     translate <0.06, 0, 0.06>
#declare LT_Cubic_Division_Blue =
texture { T_Cubic_Division_Blue_Layer_1 }
texture { T_Cubic_Division_Blue_Layer_2 }
texture { T_Cubic_Division_Blue_Layer_3 }
texture { T_Cubic_Division_Blue_Layer_4 }
// ACTUAL SCENE
plane
   y, 0
   texture { LT_Cubic_Division_Blue }
camera
   location <0, 10, 0>
   look_at 0
   angle 40
// end of code
See you in Khyberspace!
Yadgar
Download 'povnroll.png' (20 KB)
Preview of image 'povnroll.png'
Date: 7 Nov 2016 10:54:01
Message: <5820a399$1@news.povray.org>
Does POV-Ray support infinite sky_box sort of like sky_sphere? This may
be a good addition in a future version.
Mike
Date: 7 Nov 2016 19:28:27
Message: <58211c2b$1@news.povray.org>
Le 16-11-07 à 08:46, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
boxed evaluate to 1 at <0,0,0>, that value drop to zero at 1 unit
distance in all 3 directions forming a box going from <-1,-1,-1> to <1,1,1>.
Outside that box, it always return zero.
The other similar patterns are planar, cylindrical and spherical.
planar evaluate as 1 on the X-Z plane and drop to zero at +-Y.
cylindrical is a cylinder around the Y axis with a radius of 1.
spherical drop to zero at radius 1.
All those remain at zero outside those domains.
Subject: Problem solved! (was Re: Losing the ability to POV...)
Date: 7 Nov 2016 20:42:26
Message: <58212d82@news.povray.org>
Hi(gh)!
After deciding to discard the smooth color gradients in favour of sharp
stripes (which would be more true to the Amiga original), I now fixed my
problem with the background texture (see attachment).
I now will apply this layered texture to six planes defining the cubic
space in which the game level is located; they will be animated
according to the player's (a simple ball) movements, just like in the
original game!
Here is the code:
// begin code
// POV'n'Roll
// The Amiga game Rock'n'Roll as POV-Ray world
// E-Mail: yaz### [at] gmxde
// PIGMENTS
// FINISHES
finish
   ambient 1
   diffuse 0
// TEXTURES
texture
   pigment
     boxed
     color_map
       [0 rgb 0]
       [0.00001 rgb 0]
texture
   pigment
     gradient x
     color_map
       [0.40625 rgbft <0.388, 0.396, 0.678, 0, 0>]
       [0.46875 rgbft <0.388, 0.396, 0.678, 0, 0>]
       [0.46875 rgbft <0.2, 0.267, 0.533, 0, 0>]
       [0.53125 rgbft <0.2, 0.267, 0.533, 0, 0>]
       [0.53125 rgbft <0.129, 0.125, 0.388, 0, 0>]
       [0.59375 rgbft <0.129, 0.125, 0.388, 0, 0>]
     scale 1.384
texture
   pigment
     gradient z
     color_map
       [0.46875 rgbft <0.129, 0.125, 0.388, 0, 0>]
       [0.53125 rgbft <0.388, 0.396, 0.678, 0, 0>]
     scale 1.384
texture
   pigment
     boxed
     color_map
       [0.15 rgbft <0, 0, 0, 1, 1>]
       [0.15 rgbft <0.129, 0.125, 0.388, 0, 0>]
       [1 rgbft <0.129, 0.125, 0.388, 0, 0>]
     translate <0.072, 0, 0.072>
#declare T_Cubic_Division_Blue_Layer_5 =
texture
   pigment
     boxed
     color_map
       [0.3 rgbft <0, 0, 0, 1, 1>]
       [0.3 rgbft <0.2, 0.267, 0.533, 0, 0>]
       [1 rgbft <0.2, 0.267, 0.533, 0, 0>]
     translate <0.144, 0, 0.144>
#declare T_Cubic_Division_Blue_Layer_6 =
texture
   pigment
     boxed
     color_map
       [0.45 rgbft <0, 0, 0, 1, 1>]
       [0.45 rgbft <0.388, 0.396, 0.678, 0, 0>]
       [1 rgbft <0.388, 0.396, 0.678, 0, 0>]
     translate <0.216, 0, 0.216>
#declare T_Cubic_Division_Blue_Layer_7 =
texture
   pigment
     boxed
     color_map
       [0.6 rgbft <0, 0, 0, 1, 1>]
       [0.6 rgbft <0.533, 0.533, 0.8, 0, 0>]
       [1 rgbft <0.533, 0.533, 0.8, 0, 0>]
     translate <0.288, 0, 0.288>
#declare T_Cubic_Division_Blue_Layer_8 =
texture
   pigment
     boxed
     color_map
       [0.75 rgbft <0, 0, 0, 1, 1>]
       [0.75 rgbft <0.733, 0.733, 0.867, 0, 0>]
       [1 rgbft <0.733, 0.733, 0.867, 0, 0>]
     translate <0.36, 0, 0.36>
#declare T_Cubic_Division_Blue_Layer_9 =
texture
   pigment
     boxed
     color_map
       [0.9 rgbft <0, 0, 0, 1, 1>]
       [0.9 rgbft <1, 1, 1, 0, 0>]
     translate <0.432, 0, 0.432>
texture { T_Cubic_Division_Blue_Layer_5 }
texture { T_Cubic_Division_Blue_Layer_6 }
texture { T_Cubic_Division_Blue_Layer_7 }
texture { T_Cubic_Division_Blue_Layer_8 }
texture { T_Cubic_Division_Blue_Layer_9 }
// ACTUAL SCENE
plane
   y, -10000
   texture
     scale 500
     translate <0, -10000, 0>
camera
   location <0, 10, 0>
   look_at 0
   angle 40
// end code
Yadgar
P. S. Yes, POV-Ray hurts when not exercised on a daily basis!
Download 'povnroll.png' (10 KB)
Subject: Re: Problem solved! (was Re: Losing the ability to POV...)
Date: 9 Nov 2016 10:15:01
Message: <web.58233d6a37b7c347b488d9aa0@news.povray.org>
Congrats on working it out   :)
Nice use of warp and repeat.
I always forget about the warp feature - so many things to use in POV-Ray   :O
Date: 9 Nov 2016 20:44:11
Message: <5823d0eb$1@news.povray.org>
...but then I accidentally deleted all *png files in the POVnroll
project directory - and among them also the level 1 mosaic, cumbersomely
screen-copied from the Amiga emulator! So I will not be able to resume
my work, unless I do it all over again! Perhaps not all - a partial
version of it is on my friend's harddisk, but I have to phone him to
e-mail it to me, he does not regularly check his e-mail...
Computing sucks!!!
Yadgar
