POV-Ray : Newsgroups : povray.binaries.images : Tinkering with textures Server Time
18 Feb 2025 18:01:16 EST (-0500)
  Tinkering with textures (Message 1 to 10 of 71)
Subject: Tinkering with textures
Date: 25 Jul 2016 00:40:01
Message: <web.579597a8dfc396c6e095a6d0@news.povray.org>
I have always been more interested in the modelling aspects, I am particularly
fascinated by CSGs and meshes.
But I thought it would be fun to add some textures for a change. ;)
I am in the middle of moving to a new computer, so I dont have a radiosity
render yet.
Best wishes!
Download 'underconstructionmain2-ani-scn lgog.jpg' (1452 KB)
Preview of image 'underconstructionmain2-ani-scn lgog.jpg'
Subject: Re: Tinkering with textures
Date: 25 Jul 2016 03:07:04
Message: <5795ba98$1@news.povray.org>
> render yet.
> Best wishes!
Yes, nice isn't it? The only thing is the repetition of the image_map on
the top stones which is too obvious. Either edit the image in order to
hide too visible details, or use an image_map with more stones.
Date: 25 Jul 2016 04:24:10
Message: <5795ccaa$1@news.povray.org>
> render yet.
> Best wishes!
There is some really nice detail, there.
I like the split carpet. How did you get it around the pillars? ;-)
The scaffolding is good, I like the textures. It has some serious safety
issues though. You should model some scaffolding clamps to hold the
thing together. :-P
One last thing. It is a good idea to have a background that is not
uniform. A sky with simple clouds on a skysphere, is a good starting
point. It adds quite a bit to the look. :-)
I am just nitpicking because it is good.
Do you use a modeller or hand code?
Regards
Date: 25 Jul 2016 04:44:19
Message: <5795d163$1@news.povray.org>
Am 25.07.2016 um 06:38 schrieb architype:
I love this type of work-in-progress images ;)
Date: 25 Jul 2016 04:48:20
Message: <5795d254$1@news.povray.org>
Am 25.07.2016 um 10:24 schrieb Stephen:
Fitting the carpet around pillars seems like a pretty easy task,
especially since it actually appears to be a mosaic ;)
Date: 25 Jul 2016 05:17:37
Message: <5795d931$1@news.povray.org>
It does look like a mosaic in a full size view. But why the obvious joins?
Interesting. :)
Regards
Date: 25 Jul 2016 07:15:00
Message: <web.5795f37868edbca0602b026c0@news.povray.org>
Thank you all for the replies. :)
"Yes, nice isn't it? The only thing is the repetition of the image_map on
hide too visible details, or use an image_map with more stones."
Good point :)
"There is some really nice detail, there.
thing together. :-P
Do you use a modeller or hand code?"
I appreciate the feedback ;)
Do I use a modeller?
Yes and no; no technically I don't use a modeller, but in practice I use Pov-Ray
as a modeller. I use the standard top-down approach, I break an arcade into
arch,
column and wall. I break the column into foot, shaft and capital etc.
Everything is a reusable parametric macro stored in an include file.
I use an old template generator written in delphi that takes the filename and
the
macro name as parameters.
The structure of the template is something like this:
debug = 1 or 0 (zero means that the file is used in a project and that the
camera
                should not be loaded)
if debug = 1 include the standard camera and light file
macro ColumnObj (params) = union
*variables and stuff*
object {  FootObj }
object {  ShaftObj }
object {  CapitalObj }
if debug then create an instance of the object
here goes the include file stuff with search path and the like
and a list of params
and the default settings of the macro
The foot, shaft and capital is broken down into smaller pieces in the same way.
And the column file is called/instanced in the arcade macro.
So because Pov-ray is so fast and I mainly use meshes and CSG I can draw the
column in a few seconds, so that I see what I am doing.
I use a custom insert menu that have stuff like:
#local W = 1;
#local H = 2;
#local T = 3;
box{<-W/2, 0, -T/2>, <W/2,H,T/2>  translate blah blah rotate so and so }
so I almost only use basic shapes and simple transforms. Sure, certain things
are hard to do with this technique, but in 90% of the cases it works just fine.
If I have an extremely tricky ornament or something I can create that particular
bit in some other program like sketchup and export to pov-ray. But generally I
just alter the architectural design into something I can model with my pov-ray
technique... :p
"It does look like a mosaic in a full size view. But why the obvious joins?
Interesting. :)"
Well, this was a quick demo, I was looking for work and needed to show that
I could use textures as well. I intend to finish it, but I dont have time
right now. ;)
> Interesting. :)
> Regards
>      Stephen
Date: 26 Jul 2016 07:06:40
Message: <57974440$1@news.povray.org>
> arch,
I would call that hand coding. I use a modeller with OpenGL viewports. A
proper plan, two elevations and a 3D view. But I am in the minority here.
[Snip]
> Interesting. :)"
> right now. ;)
Fair enough.
Keep us updated when you have the time.
Regards
Date: 26 Jul 2016 07:11:03
Message: <57974547$1@news.povray.org>
>> use Pov-Ray
>> into
>> arch,
I'll keep you company ;-)
Date: 27 Jul 2016 08:00:02
Message: <web.5798a20768edbca0e2e698420@news.povray.org>
> > arch,
> [Snip]
> > Interesting. :)"
> > right now. ;)
> Fair enough.
> Regards
>      Stephen
Sounds interesting, is it freeware?
The main drawback with my method is that arranging objects is very time
consuming and boring. (Ie placing furniture in a room for example.)
Also, it works best with classical architecture with lots of symmetries
and axes.
I looked at the code again and it was more extensive than I thought.
Of course, I didnt write it all but reused classical mouldings and
capitals that I have in my library.
But the project was still 20 files [not counting library components]
I rendered a higher res image to see the details. Also, I discovered
15+ bugs :p
The model is based on Charlemagne's Palatine chapel in Aachen, that
is my usual approach. Since I am not much of an artist/designer I
often start with a good design and alter it slightly so that it is
more easy to create in Pov-Ray.
I want to create an exploded drawing, these images was my inspiration:
https://classconnection.s3.amazonaws.com/460/flashcards/2137460/jpg/artstor_103_418220034232801350707963274.jpg
http://3.bp.blogspot.com/-U0RWjPnCRFI/Vgbp3aVs5XI/AAAAAAAAA1M/pfeNpzblGFA/s1600/Palatine_Chapel.png
The line drawing is a better composition but I want to make a well
textured model. :) I it is a fun project, even though bug fixing is
going to be a bit tedious I think it will be worth it.
The image renders fairly quickly so I am hoping to make an animation.
If I do a good job with the textures the animation will look decent
even without a radiosity setting.
Best wishes! /A
Download 'detailed_underconstructionmain2-ani-scn.jpg' (2517 KB)
Preview of image 'detailed_underconstructionmain2-ani-scn.jpg'
