POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
19 Nov 2025 02:34:44 EST (-0500)
  concentric blobs clouds (Message 1 to 10 of 66)
Subject: concentric blobs clouds
Date: 26 Apr 2016 08:47:12
Message: <571f6350@news.povray.org>
I was going to add some cumulus to my sea scene, but the ones I had from
the project tierra where not very convincing, so... I started another
experiment.
The approach is similar to that of my previous cumulus include, but with
a trick to make softer media. As the method involved the object pattern,
the media was a bit sharp with just 0 or 1 in the density map.
The trick is to create an array of blob components positions and radius,
then use that to create 4 blobs with concentric shapes and use them on
an averaged density map. The results are surprisingly fast... this one
took "only" 47 min.
jaime
Download 'blob-clouds-test-03d.jpg' (52 KB)
Preview of image 'blob-clouds-test-03d.jpg'
Subject: Re: concentric blobs clouds
Date: 26 Apr 2016 09:05:01
Message: <web.571f66e85193772e670f6e990@news.povray.org>
> took "only" 47 min.
Nice and fluffy as it should be.
The method of averaging object patterns will be of further use - at least I hope
so...
Norbert
Date: 26 Apr 2016 09:45:00
Message: <web.571f70925193772eff125f370@news.povray.org>
> experiment.
> took "only" 47 min.
> jaime
Here is a resource about the simulation on cloud phenomenon which I know.
http://wiki.flightgear.org/Atmospheric_light_scattering
Date: 26 Apr 2016 09:52:49
Message: <571f72b1$1@news.povray.org>
> experiment.
> took "only" 47 min.
> jaime
Impressive - though am I correct there are some artifacts in the right
part of the center top plume? Was it run with AA ?
Asking mostly because of my continuing look into blob related bugs.Those
spots look like other issues I have seen related to media and blobs at
the blob(s) boundary.
Bill P.
Date: 26 Apr 2016 12:39:55
Message: <571f99db$1@news.povray.org>
   Thanks... perhaps too fluffy, tough.
> so...
  Well, it's nothing fancy, just the average pattern. The real trick is
that the averaged blobs are concentric (with diminishing radius and the
same threshold):
   interior{
     media{
       method 3 intervals 1 samples Cloud_Samples
       scattering{2,.01}
       absorption .005
       density{
         average
         density_map{
           [1
             object{
               cloud_a
               color rgb 0
               color rgb .25
             warp{turbulence .5}
             scale 2 warp{turbulence .67} scale 1/2
             scale 4 warp{turbulence 1} scale 1/4
           [1
             object{
               cloud_b
               color rgb 0
               color rgb .5
             warp{turbulence .5}
           [1
             object{
               cloud_c
               color rgb 0
               color rgb .75
             warp{turbulence .5}
           [1
             object{
               cloud_d
               color rgb 0
               color rgb 1
             warp{turbulence .5}
jaime
Date: 26 Apr 2016 12:45:55
Message: <571f9b43@news.povray.org>
> know.
   Well, fortunately POV-Ray media scattering type 2 takes care of all
that... what I'm really looking for is some method to create convincing
cumulus shapes. Right now they are just a bunch of blob spheres filling
a random conical shape, but I've got some ideas to try from this paper:
   https://hal.inria.fr/inria-00537462/file/BN04_clouds.pdf
   I will try to start with a base blob with just a few big components
and then trace a lot of smaller ones on the surface of it.
jaime
Date: 26 Apr 2016 12:56:13
Message: <571f9dad@news.povray.org>
> right part of the center top plume? Was it run with AA ?
   You have a good eye... I had to zoom several times to see them! Yes,
it was run without AA, and the artifacts are likely due to the media
container (another blob, BTW... I forgot to mention this).
> bugs.Those spots look like other issues I have seen related to media
> and blobs at the blob(s) boundary.
   Yes, that's likely the problem: see the attached test. The inner solid
blob is the object used on the density pattern, and the transparent
outer blob is the media container: you can clearly see the artifacts are
coincident with a blob boundary.
jaime
Download 'blob-clouds-test-03d-containers.jpg' (74 KB)
Preview of image 'blob-clouds-test-03d-containers.jpg'
Date: 26 Apr 2016 12:58:16
Message: <571f9e28@news.povray.org>
Another one using the exact same clouds but with a sunset lighting.
jaime
Download 'blob-clouds-test-03e.jpg' (49 KB)
Preview of image 'blob-clouds-test-03e.jpg'
Date: 26 Apr 2016 13:20:00
Message: <web.571fa3065193772e670f6e990@news.povray.org>
> > so...
> same threshold):
>    interior{
>      media{
>        scattering{2,.01}
>        absorption .005
>        density{
>          average
>          density_map{
>            [1
>              object{
>                cloud_a
>                color rgb 0
>                color rgb .25
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_b
>                color rgb 0
>                color rgb .5
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_c
>                color rgb 0
>                color rgb .75
>              warp{turbulence .5}
>            [1
>              object{
>                cloud_d
>                color rgb 0
>                color rgb 1
>              warp{turbulence .5}
> jaime
Thank you for the code snippet.
Concentric is clear, otherwise it would be similar to proximity patterns.
But, who knows...
Norbert
Date: 26 Apr 2016 15:27:14
Message: <571fc112@news.povray.org>
Am 26.04.2016 um 18:58 schrieb Jaime Vives Piqueres:
You folks are amazing!
