POV-Ray : Newsgroups : povray.binaries.images : The Colony Ship Server Time
27 May 2026 14:03:52 EDT (-0400)
  The Colony Ship (Message 44 to 53 of 73)
Subject: Re: The Colony Ship
Date: 12 Feb 2016 16:01:11
Message: <56be4817$1@news.povray.org>
On 2/12/2016 6:39 PM, clipka wrote:
> Am 12.02.2016 um 19:26 schrieb Stephen:
>> Incidently you really should quote, in your replies, who and what you
>> are replying to. IMO
> I agree with Stephen;
OMG! I will have to write this date in my diary. ;-)
Regards
Date: 12 Feb 2016 16:11:26
Message: <56be4a7e$1@news.povray.org>
Am 12.02.2016 um 21:07 schrieb Sven Littkowski:
> Couldn't it be possible to implement then a stochastic mode to POV-Ray,
> so it can do the same things? But I admit, I am not sure what stochastic
> means, will try to find out when I have a bit time. I just want to see
> our great POV-Ray pushed to its limits (as some of its programmers)... :-D
Stochastic means using a lot of randomness, resulting in grainy noise
instead of other (sometimes less obvious) types of artifacts. Goes
pretty much against POV-Ray's philosophy of trying to get reproducible
non-grainy results, but is the weapon of choice in UberPOV (and as a
matter of fact one of the primary reasons I started the UberPOV project
in the first place).
Date: 12 Feb 2016 16:36:38
Message: <56be5066$1@news.povray.org>
Knowing about UberPov and some other versions, I really think, it would
be nicer not to split the POV-family into more and more children, but to
enable POV-Ray Original to have such modes and capabilities, too.
Imagine, you create a scene that uses the latest features of POV-Ray
3.7, but for one effect you need to use UberPov or another member of the
POV-Ray family, and can't because they are not fully compatible with
their understanding of the scene code because they don't support the
same features.
I personally don't care, if a scene of mine looks on each computer the
same, as long as it is approximately the same. If possible, I would like
such a stochastic mode on demand.
But this is a thread about my colony ship, so I don't want to torture
you with my personal POV-Ray wishes. :-)
Date: 12 Feb 2016 23:14:53
Message: <56beadbd$1@news.povray.org>
On 02/12/2016 12:09 PM, Sven Littkowski wrote:
> Hmmm, will have to rethink my own position about that then. For my part,
> I always dislike all that quoting. I thought I did a favor to you all
> when I always deleted it. But okay, I can easily keep the quotations, no
> problem. :-)
It is **NOT** a favor!!  Your missing context is EXTREMELY annoying!  Especially due
to the
frequency of your posts.
      -=- Larry -=-
PS.  Short quotes only.  Just enough to show the context.
The full copy of the previous post that many (lazy) people use is unnecessary and also
irritating.
(Except, as here, when the full text is short.)   :-)
Date: 13 Feb 2016 00:40:57
Message: <56bec1e9$1@news.povray.org>
Yes, I was going to add this. Don't quote the whole article. You are
usually replying to a specific thought.  If it's multiple thoughts,
embed your replies inline with the corresponding thought.
And top-posting is for weenies -- Put your reply at the bottom.
Date: 13 Feb 2016 02:05:01
Message: <web.56bed558ce532354ac6323910@news.povray.org>
> problem. :-)
You weren't doing us any favors.
Deleting parts of quotes that are not relevant to your response is good
netiquette, but eliminating all the quotes in their entirety leaves the reader
with no context.  When you post without quoting, frankly, I have no idea what
you're talking about.  In a newsreader, we are forced to look up and down the
thread to see what you are referring to.  In the Web interface, it is virtually
impossible.
Date: 14 Feb 2016 09:26:23
Message: <56c08e8f@news.povray.org>
Kenneth,
See here the image. The twisted real heightfield remains gray as the
original image is, and also does not show any heights. It is just like
an ordinary image texture wrapped along a cylinder.
I also include a down-sized version of the heightfield image (the
original is 10,000x10,000, this one is only 1,000x1,000)
Here's the code:
#declare Fn_1 = function
 pigment
  image_map { jpeg "Colony Ship I - Heightfield Landscape.jpg" once
interpolate 2 }
// this image needs to be pi-units wide by 1.0 tall, NOT square.
// You can use these two modifiers to 'reverse' the imagery, to see it
// correctly on the INSIDE. HOWEVER, this does not reverse the *depth* of
// the heightfield. The only way to do that (that I know of) is to invert
// the image_map's colors (in Photoshop, for example.)
                //scale <-1,1,1>
                //translate <1,0,0>
#declare TheLandscape = object
 HF_Cylinder(function { Fn_1(x,y*1.7,z).gray }, // *Needs* the function
'wrapper' Fn_1
                                             1, // UseUVheight:  0 or 1
// ON-- IMPORTANT
                                             0, // UseUVtexture: 0 or 1
                             <int(100*pi),100>, // Resolution.
                                             1, // Smooth: 0 or 1
                                            "", // FileName, ""=no file,
                                       <0,0,0>, // EndA,
                                     <0,1.7,0>, // EndB-- if this
y-value is different from 1.0,
                                                // change the function's
y-value above to compensate.
                                           0.5, // Radius. Keep this at
.5 for 1:1 reproduction of
                                                // the image_map around
the circumference.
                                            0.1 // Depth
 scale < 0.58, 0.67, 0.58 >
 rotate < 90.0, 0.0, 0.0 >
 scale < 1500.0, 1500.0, 2500.0 >
#declare MyLandscape = union
 object { TheLandscape scale < 1.0, 1.0,  1.0 > translate < 0.0, 0.0,
0000.0 > }
 object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
 pigment { rgb < 0.05, 0.25, 0.0 > }
 finish { emission 0.0 }
On 14.02.2016 04:15, Kenneth wrote inside the BUGREPORTS section:
> That's odd. I DO see the green color, using just your code example.
Did you
> combine the 'MyLandscape' object with some other CSG and then apply
another
> different 'gray' texture?
> Yes, post an image there (at the IMAGES section).
Download 'sl - colony ship i.png' (29 KB) Download 'colony ship i - heightfield landscape 1000px.jpg' (118 KB)
Preview of image 'sl - colony ship i.png'
Preview of image 'colony ship i - heightfield landscape 1000px.jpg'
Date: 14 Feb 2016 10:06:01
Message: <56c097d9@news.povray.org>
Sorry, wrong image, here is the correct one for this case.
On 14.02.2016 09:26, Sven Littkowski wrote:
> See here the image. ...
Download 'sl - colony ship i.png' (333 KB)
Date: 14 Feb 2016 10:57:22
Message: <56c0a3e2$1@news.povray.org>
Le 16-02-14 09:26, Sven Littkowski a écrit :
> Kenneth,
> Here's the code:
>   pigment
> interpolate 2 }
>                  //scale <-1,1,1>
>                  //translate <1,0,0>
> 'wrapper' Fn_1
Performance tip:
When evaluating a pigment, and that pigment in in shades of gray, it's
beter to use .red, .green or .blue instead of .gray.
This use the fact that all 3 channels always evaluate to the same value.
.gray will evaluate each channels and perform a ponderated average that
is always the same value as the red, green and blue channels.
Using .red, .green or .blue, you only evaluate a single channel and
don't need to do the averaging.
It ONLY work for gray levels pigments and images.
Date: 14 Feb 2016 14:50:58
Message: <56c0daa2$1@news.povray.org>
Hi Alain, not sure if I understood.
You're saying, that I could use a full-color image as heightfield? Like
the same file for texture and heightfield? But I am thinking, a texture
that shows green meadows and brown (soil) paths through them, would give
me the accurate heights. But maybe I am misunderstanding.
Or do you mean, instead of a gray-scale image, I should use a red-scale
image (or green-scale, or blue-scale)? Can you explain in easier words
for me, or give me a sample image? Thanks.
On 14.02.2016 10:57, Alain wrote:
> Performance tip:
> better to use .red, .green or .blue instead of .gray.
> Alain
