POV-Ray : Newsgroups : povray.binaries.images : Skyrim (and beyond) Server Time
5 Sep 2025 05:08:48 EDT (-0400)
  Skyrim (and beyond) (Message 11 to 20 of 36)
Subject: Re: Skyrim (and beyond)
Date: 16 Oct 2012 07:40:20
Message: <507d47a4@news.povray.org>
A'ight, I think I'm doing something wrong here, because I'm not getting
the fixed-width contour lines.
Here's relevant bit of SDL:
#declare East_Land4 = union {
   object { Land4_P00P00_to_P12P28 }
   object { Land4_P20P00_to_P28P28 }
   object { Land4_P00M04_to_P12M32 }
   object { Land4_P16M04_to_P32M32 }
   object { Land4_P32P00_to_P44_28 }
   object { Land4_P48P00_to_P60P28 }
   object { Land4_P32M04_to_P44M32 }
   object { Land4_P48M04_to_P60M32 }
   object { tamriel_4_12_60_ }
   object { tamriel_4_28_60_ }
   object { tamriel_4_44_60_ }
   object { tamriel_4_60_60_ }
   #declare InputPigment = pigment{
     gradient z
     rotate x*90
   pigment{
     Pg_Elevation_Lines(
       InputPigment,
       8,
       3,
       8,
       0,
       on
     pigment_map{ [ 0 InputPigment][ 1 rgb x] }
     rotate -90 * x
     scale 16384.0 * 3.2
     translate <0.0, 0.0, -13800.0>
   finish{ ambient 1 diffuse 0 }
Halp?
Tim Cook
http://empyrean.sjcook.com
Download 'tamrieleast.png' (217 KB)
Preview of image 'tamrieleast.png'
Date: 16 Oct 2012 08:50:00
Message: <web.507d579ef9ac85a35b7d07940@news.povray.org>
Tim Cook <z99### [at] gmailcom> wrote:
> I do believe I just clicked on the 'reply' button instead of 'followup'...
> ...again.
Oh yes. I've not yet been to Dawnstar, Riften or Morthal so I couldn't comment!
Trying to keep the quest list down to a manageable size :)
> I'm of half a mind to take and scale the meshes so they match what I've
> been able to discern of 'real' distances for things; they're squished
> about 10x laterally and stretched 10x vertically, so when you correct
> for that, Skyrim's a lot flatter.  (It's about 250 lore-canon miles from
> Dawnstar to Windhelm, or something like that...?  Whereas in-game, if
> you use their 128 units = 6 feet, it's only about 25 miles.  And the
> Throat of the World is iirc 52 miles high--again with the 128 units to 6
> feet measure.)
I thought so, or it would take weeks to cross wilderness! It's quite a clever
effect though, the landscape hides the locations' proximities so on the ground
it feels like a real, large world.
If you get Sam's contours working, it'd be fun to see a tourist hiking map :)
Date: 16 Oct 2012 15:20:00
Message: <web.507db334f9ac85a35f336ae30@news.povray.org>
>      gradient z
>      rotate x*90
>    pigment{
>      Pg_Elevation_Lines(
>        InputPigment,
>        8,
>        3,
>        8,
>        0,
>        on
>      rotate -90 * x
>      scale 16384.0 * 3.2
> Halp?
A simple "gradient z" will not work because it doesn't contain any topographical
information describing your landscape. The macro requires a height map, so
you'll need to produce one from East_Land4 and then pass it to the macro. (You
might even be able to use it for a height_field object instead of that union of
objects you have now, but I'm not sure, since I don't know how your scene is set
up.)
Once you have your height_map, you'll be going forward again. If not, just give
me a holler :)
Date: 17 Oct 2012 00:26:31
Message: <507e3377@news.povray.org>
> up.)
> me a holler :)
Well, a little bit of progress, but something's obviously not right...
Here's what I've got now, with tamrielheightsmall.png being a straight
height-gradient render.
box{
   <-7200,-4800,-0.1>,< 7200, 4800, 0.1>
     image_pattern{ png "c:\downloads\tamrielheightsmall.png" }
     rotate z*180
     translate <-0.5, -0.5, 0.0>
     scale <1,0.8,1>
   pigment{
     Pg_Elevation_Lines( InputPigment, 8, 2, 32, 0, off )
...and this is what it comes out as.  (there's some weird noise at the
top and bottom that's there even with just using InputPigment as the
pigment, and the contour lines are all noisy)
Download 'tamriel flat.png' (485 KB)
Preview of image 'tamriel flat.png'
Date: 17 Oct 2012 17:10:00
Message: <web.507f1dbcf9ac85a3402211370@news.povray.org>
<snip>
Alright, after scratching my head for a while I've determined that the problem
is with your height data. I zoomed up on an unlined portion of your image and
saw a lot of noise; rendered it with Pg_Elevation_Lines, and got similar results
as yours.
So to get rid of the noise, try one of these options:
1) Open the height map in Gimp, and apply the Despeckle filter using its default
settings. Unfortunately, Gimp does not (yet!) support 16-bit grayscale.
-or-
2) Render your height map in POV-Ray using these command line options: +fng +f
+a0.01 +am2 +r3 This seems to be more accurate than Gimp's Depseckle filter,
although POV-Ray still cannot match the gamma of the original image, so
calculating the proper line spacing and offset with Pg_Elevation_Lines might
prove difficult.
Other program options include PhotoShop, Terragen, Wilbur, or any other program
that can manipulate 16-bit height maps.
Since I was unable to render your entire height map, I cannot say for certain if
the noise reduction techniques I tried would completely get rid of all the
artifacts, so you may need to tweak some settings here and there (interpolating
the image in POV-Ray comes to mind).
Sam
Date: 17 Oct 2012 18:13:43
Message: <507f2d97$1@news.povray.org>
> as yours.
Hmm...I ran the height image through despeckle and a few blurs just now,
and it's not changing the amount of noise artifacts with the contour
lines...?  Hmm.
Tim Cook
Date: 17 Oct 2012 18:33:46
Message: <507f324a@news.povray.org>
> lines...?  Hmm.
Ah wait.  If I run the original height map through POV using your
suggested settings it cleans up a lot...bit of an interesting result,
though.
Still noisy in places, hmm.  Ok, using a lower number for +a increases
the noise...
Here's the render with +a0.05 +am2 +r4 and the function called with 20
lines, 1.05 width, 32 quality.
Tim Cook
Download 'tamriel flat.png' (476 KB)
Date: 17 Oct 2012 18:35:00
Message: <web.507f3255f9ac85a3d69746330@news.povray.org>
> > as yours.
> lines...?  Hmm.
Hmm, it should have at least helped.
I was wrong about POV-Ray not mapping the gamma correctly: it does. Also, when
trying to re-render the height map in POV, you need to use "interpolate 2" in
addition to high AA settings.
Try the attached. It's just a simple blur filter, but it works for the tiny
portion I cropped from your image.
Failing that, try the blur/resample file a posted a while back:
http://news.povray.org/povray.text.scene-files/thread/%3C4d34c72d@news.povray.org%3E/?ttop=372491
You might want to render your map at 2x resolution with a decent amount of blur
(2-6), and scale it back down to its original size.
If none of that works, would you mind posting your entire height map so I can
figure out what's going wrong?
Download 'blendpixelsb.pov.txt' (1 KB)
Date: 17 Oct 2012 18:46:13
Message: <507f3535$1@news.povray.org>
Ah!  A problem your macro doesn't take into account (not sure how it
would, either, but who knows?) is that of depressions, where a given
contour line loop isn't an ascending hill, but a shallower area.  On the
other image I'd rendered, they're easy to spot because the fade is on
the outside rather than the inside, so can be marked appropriately when
redrawing everything by hand.
Tim Cook
Date: 17 Oct 2012 20:11:34
Message: <507f4936@news.povray.org>
The original height map I rendered at 7200x4800, so it's a 2.4 MB png,
here's the reduced-size version.  (Ehm, re-rendered...oh hey, I had
jitter 'on' in the antialiasing options there, that might've been
contributing to the noise level, let's see what it turns out with that
off.)  *waits*
Here we go.
Tim Cook
Download 'tamrielheightsmall.png' (302 KB)
Preview of image 'tamrielheightsmall.png'
