POV-Ray : Newsgroups : povray.binaries.images : More Wings3D learning... (140Kb) Server Time
25 Feb 2026 01:45:57 EST (-0500)
  More Wings3D learning... (140Kb) (Message 1 to 10 of 14)
Subject: More Wings3D learning... (140Kb)
Date: 13 Aug 2004 05:01:21
Message: <411c8361@news.povray.org>
...this time for simple architectural elements. The composition is
inspired on a trueSpace render done by Craftwerk Graphics, found on the
galleries at lightworkdesign.com (I can only find two renders from this
artist, both really impressive). My skills at photographic texturing are
not that good, but Skylight and POV-Ray radiosity helped getting it more
photorealistic.
   Regards..
Jaime
Download 'columns-11.jpg' (137 KB)
Preview of image 'columns-11.jpg'
Subject: Re: More Wings3D learning... (140Kb)
Date: 13 Aug 2004 05:20:01
Message: <cfi0vf$mg8$1@chho.imagico.de>
> photorealistic.
Looks good, are the textures all image maps?  How did you generate them?
  I assume you use UV-mapping generated in Wings.  I have not yet
figured out how to do this (guess i need to have a look at the manual
after all - something i have not bothered to do until now...)
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 13 Aug 2004 05:25:19
Message: <411c88ff$1@news.povray.org>
Nicely done, Jaime.
The plants add to it very well, but I wonder if it might make more sense to
have them grow better nearer the archways and less toward the interior?
Except it looks like daylight, or skylight, might be inward of there too
judging by the shadowy parts in front of the inside pillars. Unless that's
due to a unseen wall reflecting light back outward.
The texturing is realistic. Just that some pillars don't seem correct
because of the mortar lines disappearing, even in the blurry foreground I
thought it might show more of the darkened lines. Perhaps something to do
with either texturing, radiosity, normals, focal blur... or all combined?
Trying it as wallpaper here, it looks great even though stretched to
1600X1200.
Bob H.
Date: 13 Aug 2004 06:23:38
Message: <411c96aa@news.povray.org>
   Yes, all the textures are one image map, found with google at
     http://www.fromthedirt.com/textures/concrete.jpg
    but I've "proceduralized" it with several turbulent warps to avoid
pixelization. On the floor it is used with higher turbulence, and on the
walls it uses two layers with little but different turbulence values.
>  I assume you use UV-mapping generated in Wings.  I have not yet figured
> out how to do this (guess i need to have a look at the manual after all
   No, I'm just on the same situation... but I don't even know how UV
mapping works in POV-Ray.
   I just used the texturing capability of Wings3D to assign different
materials to groups of faces, so I can rotate them later with POV to
face the correct direction.
   Also, I assigned different materials to the fictitious blocks/tiles,
so the texturing is not continuous from tile to tile. In total, the set
of column+arch uses 12 different textures, 4 for each direction. The
mesh is contained on a macro to obtain a different texturing on each copy.
Jaime
Date: 13 Aug 2004 06:34:56
Message: <411c9950$1@news.povray.org>
   Yes, I later noticed it... and it was not intentional, just the
random seed used for the placement.
   Yes, there are some elements at the right, out of camera. But it's
also due to the stronger bounce of direct sun, on the floor at the left
side.
   No, it's just that I badly modeled one of the sides of the column on
Wings3D, and since there are many copies randomly rotated, some times it
appears this effect. I must have used too little depth on the mortar
extrusion...
> 1600X1200.
   Thanks! I will do the final version bigger... :)
Jaime
Date: 13 Aug 2004 06:50:01
Message: <cfi6c9$brm$1@chho.imagico.de>
Ah, so the brick structure is not actually painted in the image map but
results from different textures assigned to the different parts of the
column?
Date: 13 Aug 2004 07:02:40
Message: <411c9fd0@news.povray.org>
> column?
   Yes, see the attached Wings3D screenshot. It's a bit tedious, but not
more than doing it with CSG.
Jaime
Download 'wings-column.jpg' (15 KB)
Preview of image 'wings-column.jpg'
Date: 13 Aug 2004 08:15:07
Message: <cfib84$cmr$1@chho.imagico.de>
>> but results from different textures assigned to the different parts of
>> the column?
And surely faster to render...
I just did some tries with the UV-Mapping feature of Wings and it seems
to work relatively well - you can probably get similar results this way
without subdividing your models like you did but you will have to paint
a high resolution map of course.  The bad thing (and a general problem
about Wings) is that it gets really slow once you deal with models of
more than a few hundred faces.
Date: 13 Aug 2004 09:16:25
Message: <Xns95449BD19916Braf256com@203.29.75.35>
jai### [at] ignoranciaorg news:411c8361@news.povray.org
Oh, oh, I worked there [for a moment] :) (couldn't resist, sorry ;)
Greate image, very photorealistic indeed
http://www.raf256.com/3d/
Computer Graphics
Date: 13 Aug 2004 10:52:51
Message: <411cd5c3@news.povray.org>
Beautiful and very realistic. Congratulations!
Are you going to post the code in your website?
Good job!
Fernando
> photorealistic.
>   Regards..
> Jaime
