POV-Ray : Newsgroups : povray.binaries.images : More Faked Volumetrics (35k jpeg) Server Time
18 Feb 2025 16:55:22 EST (-0500)
  More Faked Volumetrics (35k jpeg) (Message 1 to 10 of 12)
Subject: More Faked Volumetrics (35k jpeg)
Date: 8 Apr 2004 14:47:47
Message: <40759DEA.90906@hotmail.com>
Hello everyone! Here's an idea I've been thinking of for quite a while.
I'm pretty sure somebody has done something like this before... it might
have been a grass texture, though.
What you see is actually a flat plane layered with over eighty
semitransparent textures. Each additional texture is scaled slightly
larger than the last, and uses a slightly altered color_map (actually a
pigment_map, but it doesn't really need to be one anymore). The texture
is then translated to the camera's X & Z coordinates to achieve a more
proper illusion.
I can't really see a practical application for this trick. Even though
this image rendered in a little over five minutes, it can get very slow
when antialiasing is applied :(  Also, POV-Ray tends to throw an error
if the number of texture layers goes over 100.
I still have yet to try it with radiosity. There's no reason why it
shouldn't work.
The code has been placed (a little too hastily) to
povray.binaries.scene-images.
Questions and comments are always welcome-
-Samuel Benge
Download 'fake_elevation.jpg' (35 KB)
Preview of image 'fake_elevation.jpg'
Subject: Re: More Faked Volumetrics Update (31k total, 2 jpegs)
Date: 8 Apr 2004 15:35:08
Message: <4075A907.6070804@hotmail.com>
Update:
I just tried it again with antialising, and the render time didn't
really go up that much. Evidently, the last time I tried aa the texture
had a lot of noise in it. Also, removing the surface normal considerably
decreases render time.
I attached two more images. The first one has the surface normal in
place and uses aa. The second uses no surface normal, but still has aa.
The render times are diplayed in the lower right corner of each image.
-Samuel Benge
Download 'fake_ev1.jpg' (15 KB) Download 'fake_ev2.jpg' (16 KB)
Preview of image 'fake_ev1.jpg'
Preview of image 'fake_ev2.jpg'
Date: 8 Apr 2004 15:51:48
Message: <4075ad54@news.povray.org>
Number two looks better (IMHO) and renders faster. Looks like a winner to
me.
Nice technique, BTW.
Regards!
Subject: Re: More Faked Volumetrics (35k jpeg)
Date: 8 Apr 2004 17:03:19
Message: <4075be17@news.povray.org>
Uzytkownik "Samuel Benge" <stb### [at] hotmailcom> napisal w wiadomosci
news:407### [at] hotmailcom...
> proper illusion.
It may come handy at rendering backdrops to aerial scenery (e.g. a flying
aeroplane).
> shouldn't work.
> -Samuel Benge
Respectfully
Matt
Date: 8 Apr 2004 18:55:30
Message: <4075d862$1@news.povray.org>
<snip:technical />
BRILLIANT idea! It may cause some challenges for the renderer if objects
  are within those planes. Have you found any trouble with, say, a
sphere in the middle of the clouds?
Respectfully,
Dan P
http://<broken link>
Date: 8 Apr 2004 21:18:24
Message: <4075f9e0$1@news.povray.org>
Samuel Benge nous apporta ses lumieres ainsi en ce 2004/04/08 15:33... :
>> though this image rendered in a little over five minutes, it can get
>> very slow when antialiasing is applied :(
> Update:
> texture had a lot of noise in it. Also, removing the surface normal
> considerably decreases render time.
> aa. The render times are diplayed in the lower right corner of each
> image.
> -Samuel Benge
Second one looks beter for a flyby over some clouds, the first should be
beter for a snowy field. For me anyway.
Date: 8 Apr 2004 21:31:58
Message: <cjameshuff-6BB5D0.21324408042004@news.povray.org>
In article <4075d862$1@news.povray.org>,
Well, since it's on a 2D surface, it'd look a bit odd...
BTW, I vaguely recall some very good sky_sphere pigments done using this
technique. One advantage there is that you don't have any intersection
or finish/normal calculations, so it renders faster. The layered pigment
feature of sky_spheres seems to be overlooked far too much.
http://tag.povray.org/
Date: 8 Apr 2004 21:40:47
Message: <4075ff1f@news.povray.org>
I misunderstood what he did; I thought he used many planes with seperate
transparent image_maps. I should have looked at the source; my bad.
Respectfully,
Dan P
Date: 8 Apr 2004 21:47:58
Message: <4076007F.7080109@hotmail.com>
Looks like something I'll have to try. Thanks.
-Samuel Benge
Date: 9 Apr 2004 10:51:49
Message: <4076b885$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
> -Samuel Benge
*drool* Practical applications are overrated and can alwasy come later :)
this alone is cool.
