![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Impressive work, esp. on the textures / lighting.
IMO, the shadows the objects are casting on the ground look a bit to soft for
shadows made by direct sunlight. (maybe i'm wrong)
I wonder how it would change lighting/radiosity effects, if you use *real*
surface turbulence (isosurfaces) instead of normal statements.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you people don't stop kissing Gilles' ass, he's gonna get a rash.
Don't get me wrong.. he's a badass mutha and I know it as well as the
rest of you. That city pic he did for the IRTC made me weep like a
little girl. But this is NOT an awesome pic, nor does it look even
remotely photographic. It's just a radiosity test with a bunch of simple
primitives scattered around. I'll grant that it's interesting, but most
of us could probably have made it ourselves. All I'm saying is, show
some sense of perspective.
Now, Gilles, you can't keep doing this sort of thing. It's a letdown
when you create scenes that merely require human ingenuity. ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, as he said... ;-O Anyhow, here is my radiosity test. Of course
this one use caustics and photons as well. I just wonder why it doesn't
show up. *grumble*
It's just a simple test to see if I got some caustics and reflections
showing up, but albeit no such thing.
As usual it's a total ripoff of other peoples code, except for the
simple object.
+47 90 62 71 78 DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
azo### [at] dod no, Ducati M600, Clementine Ubesudlet: Aldri eid en J&%#PS.
Download 'radtest.jpg' (53 KB)
Preview of image 'radtest.jpg'
![radtest.jpg](/povray.binaries.images/attachment/%3C3990A64C.E3CBB127%40dod.no%3E/radtest.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sun light_source diameter should be 1 at a distance of 100.
K.K.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3990A64C.E3CBB127@dod.no...
| show up. *grumble*
Well I like the way the water is aligning with the box anyhow, like it's the
only thing causing the surface waves.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> simple object.
Well, not bad for throwing together different things :-) The water suffers much
from the regular structure, you could try RMF for that.
I wonder about the different material for the outside/inside of the table.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The answer to your question...
I backed off on the brightness(1.095) and of course the pigment function
is different from what Gilles had as the normal. Also I only did the
cylinders(laziness).
function{
pigment{
agate
turbulence 0.24
color_map{[0 rgb 1][.75 rgb 0][1 rgb<.3,.95,.3>]}
scale 0.3
The pigment is later multiplied by 0.15 which cuts into the surface too
much
but it looks neat anyhow.
Total Time: 4 hours 29 minutes 43.0 seconds
Peak memory used: 10044266 bytes
PII 233 , 96 mb
Phil
Download 'radiosity_test_file.jpg' (81 KB)
Preview of image 'radiosity_test_file.jpg'
![radiosity_test_file.jpg](/povray.binaries.images/attachment/%3C39910E35.6457ADD8%40tiac.net%3E/radiosity_test_file.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> K.K.
<taking out calculator> arctan(1/100) => 0.57 deg.
Yes, that seems ok. ( sun usually is about 30 arcminutes )
I think Gilles's sun is much larger, but i'm not very experienced with area
lights.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It really hurts now. Hard to code standing up ;-)
My point exactly. With the current Megapov implementation of radiosity, it's
become very easy to use. Now the effect obtained in these tests, while
highly satisfying, are far from the "real" thing. There's a LOT of room for
improvement. Of course, it's still hard to tell if the shortcomings of the
pics come from the scene code (a quick hack, with mostly standard settings)
or from the radiosity algorithm itself. For instance, I've been totally
unable to reproduce the simple (?) effect seen here :
http://www.3dluvr.com/marcosss/sky6s.jpg
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
you may feel that whenever Gilles posts, we all go crazy, and usually with
good reason.
as for the recent rad test images, we got so excited about those, because
quite a few of us have been playing with rad lighting, and Gilles happens to
have done a better job than most of us had managed (not for lack of trying)
if those images had been posted by anyone else (source included!), we would
have been equally happy :))
you try suffering with long render times for a few days, desperately trying
to accomplish a particular technique with only some success, then someone
gives you the moon on a stick. and tells you exactly how he did it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
