POV-Ray : Newsgroups : povray.binaries.animations : Some more dominos Server Time
29 Mar 2026 02:52:19 EDT (-0400)
  Some more dominos (Message 1 to 8 of 8)
Subject: Some more dominos
Date: 26 Nov 2004 15:22:29
Message: <opsh29jrzl029eka@hennes.sytes.net>
now that I've managed to write some macros to line up dozens of dominos
I'm trying to follow the falling dominos with the camera. But that looks
really nervous and abrupt. Any hints for a smooth camera movement?
http://home.nexgo.de/auspeitscher/Domino_4.mpg (9 MB)
By the way: Has anyone a good texture and normal pattern for a domino? ;-)
Thanks in advance
   Ralf
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Subject: Re: Some more dominos
Date: 26 Nov 2004 15:35:00
Message: <web.41a7935ad016956b3522e90@news.povray.org>
"Ralf Jonas" <Scr### [at] hotmailcom> wrote:
> Hi,
 Hi Ralf,
very nice movie. I think the camera movement during the first time of Your
movie is much too fast. You should make the fly through the dominos much
slower and then increase the speed if You focus on the falling dominos.
That would help a lot. Another thing, why is You movie sooooooooo big ??
What kind of codec and which bitrate did You used to create it ?
Shu
Date: 26 Nov 2004 15:55:00
Message: <web.41a79752d016956b3522e90@news.povray.org>
Ooops, forgot to ask :
How did You animate Your camera, by a spline, by simple translate and
rotate, or did You used the autoclock macro from Chris Colefax ?
Shu.
Date: 27 Nov 2004 07:02:36
Message: <opsh4g2yid029eka@hennes.sytes.net>
Well, I did it the hard way. ;-) Sorry, it's my first animation ever.
   #switch(time_step)
     #range (0, 32.4999999)
         #local winkel = time_step / 64 * PI;
         #local xpos = -1.0 + time_step * .03;
         #local ypos = 0.30 + sin(winkel) * 0.472;
         #local xview = xpos + 0.1;
         #local yview =0.30 + sin(winkel + 0.1) * 0.472;
         location  <xpos,  0.06, ypos>
         look_at   <xview, 0.02, yview>
         #declare bahn1_x = xpos;
         #declare bahn1_y = ypos;
     #break
     #range (32.5, 46.499999)
         #local bahn1_x = -1.0 + 32 * .03;
         #local bahn1_y = 0.30 + sin(32 / 60 * PI) * 0.472;
         location  <bahn1_x + (time_step-32) * .03,  0.06 - ((time_step-32)
/ 14 * 0.04), bahn1_y>
         look_at   <bahn1_x + 0.1 + (time_step-32) * .03, 0.02, bahn1_y>
     #break
     #range (46.5, 55.4999)
         location  <bahn1_x + (time_step-32) * .03,  0.02, bahn1_y>
     #break
     #range (55.5, 61.499999)
         location  <bahn1_x + (time_step-32) * .03,  0.02 + ((time_step-55)
/ 6 * 0.04), bahn1_y>
     #break
     #range (61.5, 68.455555)
         #local bahn1_x = -1.0 + 61 * .03;
         #local winkel = (time_step-61) / 14 * PI;
         #local xpos = bahn1_x + sin(winkel) * 0.1;
         #local ypos = bahn1_y - (1-cos(winkel)) * 0.2;
         look_at   <xpos + cos(winkel) * .1, 0.02, ypos + sin(winkel) * .1>
     #break
     #range (68.5, 90.455555)
         #local bahn1_x = 0.93;
         #local bahn1_y = 0.56;
         #local xpos = bahn1_x;
         #local ypos = bahn1_y - (time_step-68) * .02;
         look_at   <xpos,  0.02, ypos + .1>
     #break
     // etc. etc. etc.
   #else
     #error str(time_step, 10, 5)
   angle 70
Date: 27 Nov 2004 07:20:06
Message: <opsh4ht8b2029eka@laptop>
Uh oh, I hope I can tell you.
First of all, I'm using Linux and it took me a long time to find
something to make an mpeg file. Then I found mpeg2encode:
                           mpeg2encode / mpeg2decode
               MPEG-2 Encoder / Decoder, Version 1.2, July 19, 1996
                              Copyright (c) 1996
                         MPEG Software Simulation Group
This programme needs a parameter file:
MPEG-2 Domino Sequence, 25 frames/sec
/mnt/network/drive_l/hennes/POVRay/domi-1%03d    /* name of source files */
-         /* name of reconstructed images ("-": don't store) Old: q%d*/
-         /* name of intra quant matrix file     ("-": default matrix) */
-         /* name of non intra quant matrix file ("-": default matrix) */
-         /* name of statistics file ("-": stdout ) */
2         /* input picture file format: 0=*.Y,*.U,*.V, 1=*.yuv, 2=*.ppm */
360       /* number of frames */
1         /* number of first frame */
00:00:00:00 /* timecode of first frame */
12        /* N (# of frames in GOP) */
3         /* M (I/P frame distance) */
0         /* ISO/IEC 11172-2 stream */
0         /* 0:frame pictures, 1:field pictures */
640       /* horizontal_size */
480       /* vertical_size */
2         /* aspect_ratio_information 1=square pel, 2=4:3, 3=16:9,
4=2.11:1 */
3         /* frame_rate_code 1=23.976, 2=24, 3=25, 4=29.97, 5=30
frames/sec. */
5000000.0 /* bit_rate (bits/s) */
112       /* vbv_buffer_size (in multiples of 16 kbit) */
0         /* low_delay  */
0         /* constrained_parameters_flag */
4         /* Profile ID: Simple = 5, Main = 4, SNR = 3, Spatial = 2, High
= 1 */
8         /* Level ID:   Low = 10, Main = 8, High 1440 = 6, High =
4          */
0         /* progressive_sequence */
1         /* chroma_format: 1=4:2:0, 2=4:2:2, 3=4:4:4 */
1         /* video_format: 0=comp., 1=PAL, 2=NTSC, 3=SECAM, 4=MAC,
5=unspec. */
5         /* color_primaries */
5         /* transfer_characteristics */
5         /* matrix_coefficients */
640       /* display_horizontal_size */
480       /* display_vertical_size */
0         /* intra_dc_precision (0: 8 bit, 1: 9 bit, 2: 10 bit, 3: 11 bit
1         /* top_field_first */
0 0 0     /* frame_pred_frame_dct (I P B) */
0 0 0     /* concealment_motion_vectors (I P B) */
1 1 1     /* q_scale_type  (I P B) */
1 0 0     /* intra_vlc_format (I P B)*/
0 0 0     /* alternate_scan (I P B) */
0         /* repeat_first_field */
0         /* progressive_frame */
0         /* P distance between complete intra slice refresh */
0         /* rate control: r (reaction parameter) */
0         /* rate control: avg_act (initial average activity) */
0         /* rate control: Xi (initial I frame global complexity measure)
0         /* rate control: Xp (initial P frame global complexity measure)
0         /* rate control: Xb (initial B frame global complexity measure)
0         /* rate control: d0i (initial I frame virtual buffer fullness) */
0         /* rate control: d0p (initial P frame virtual buffer fullness) */
0         /* rate control: d0b (initial B frame virtual buffer fullness) */
2 2 11 11 /* P:  forw_hor_f_code forw_vert_f_code search_width/height */
1 1 3  3  /* B1: forw_hor_f_code forw_vert_f_code search_width/height */
1 1 7  7  /* B1: back_hor_f_code back_vert_f_code search_width/height */
1 1 7  7  /* B2: forw_hor_f_code forw_vert_f_code search_width/height */
1 1 3  3  /* B2: back_hor_f_code back_vert_f_code search_width/height */
I don't know which parameter to change... Do you know?
Regards
   Ralf
Date: 29 Nov 2004 06:55:01
Message: <web.41ab0d11d016956b3522e90@news.povray.org>
Lol, what the hell is that ??? Sorry i'm 100% windows kid :). Actually there
should be something like data rate or bitrate. Maybe You need to change the
quantitizer to higher values ?? Sorry can't help You with this, i'm using
Xvid codec and VirtualDUB to encode my movies. Works fine and is very easy
to use and most important it's freeware. But windows only, at least VD.
Concerning the camera animation just have a look here :
http://tilo.ackro.de/CrystalPOV/index.php
I used different ways to animate the camera, but from my own oppinion
Autoclock macro is the easiest way to do it. Defining a camera spline i as
hard as Your way and functions are too mathematical to me and only offer
sinple rotations or spirals as far as i got through it. I'm still hoping
for a good animation system.
Shu.
Date: 29 Nov 2004 08:42:46
Message: <41ab2755@news.povray.org>
Ralf Jonas wrote:
> Hi,
This seems to be a really ancient piece of software, does it?
I usually use mencoder, which is part of mplayer[1]. It's a commandline
utility, but rather easy to use (compared to this one ;). You can use
it's multifile input filter and use mpeg2 for output. The vbitrate
parameter gives the desired bitrate (800kbit/s being the default)
Something like this might help (not tested, I have to look it up
everytime I use it):
mencoder "mf://*.png" -ovc lavc \
Greets
Dave
[1] http://www.mplayerhq.hu
Dave "tPassive" Vogt | Linux  user  #225040 | www.frozenbrain.com     |
_____________________|______________________|_________________________|
List of Spam filter victims: http://frozenbrain.com/rel.php/victims   |
PGP Key:                     http://frozenbrain.com/public_key.asc    /
Date: 30 Nov 2004 18:53:15
Message: <41ad07eb$1@news.povray.org>
Ralf Jonas wrote:
 > Hi,
 > looks  really nervous and abrupt. Any hints for a smooth camera movement?
Instead of making the camera move along a path, per se, give them camera
an inertial vector, a rotational vector, and a mass. Then with each
frame, calculate the the movement of the camera and find it's new position.
Then, during the animation, start applying "energy" to those vectors to
affect the desired movement.
The nice thing about this method is that it's framerate independent and
can produce quite complex and natural feeling camera movements (makes it
easy to add physically correct "errors" like bouncing and
over-compensation).
I would also recommend writing a quick math macro that can determine the
vectors automatically based on a series of points and information about
how the overall behavior of the camera (maximum rotational/linear
acceleration and the like).
I think you'll find the implementation far more simple than my
explanation. ;)
> Thanks in advance
>   Ralf
