POV-Ray : Newsgroups : povray.beta-test : segmentation fault Server Time
16 Feb 2026 08:47:04 EST (-0500)
  segmentation fault (Message 1 to 5 of 5)
Subject: segmentation fault
Date: 7 Jun 2011 14:33:47
Message: <4dee6f0b@news.povray.org>
I'm getting an interesting seq fault ... I changed some scaling factors
with a couple of macros in my "ndi" scene and that resulted in the
number of parsed tokens being increased, and everything was OK until I
added the shrubs back in (more tokens) ... then seg fault appeared with
this message ...
Parsing 386364K tokens
File 'PrunedShrub.inc' line 85: Parse Error: std::bad_alloc
Possible Parse Error: Attempt to free NULL pointer.
Fatal error in parser: Cannot parse input.
didn't change #5434 address this
btw: shocked that system monitor showed that it snagged 121MB of my swap
(RARELY does that). it took a few seconds before the system was it's
usual responsive self ... still a runaway case?
Subject: Re: segmentation fault
Date: 8 Jun 2011 09:00:46
Message: <4def727e@news.povray.org>
> this message ...
  Some minimal code that causes the error would be helpful...
Date: 8 Jun 2011 09:41:30
Message: <4def7c0a$1@news.povray.org>
>> this message ...
The scene files that produce this error (and the above error another time):
Parsing 901655K tokens
Render failed
have been posted in p.t.scene-files
when I go into buildings.inc on line 272 and change 0TOScale = 0.25 to
OTOScale = 0.5 it runs fine ... /NOT/ implying that the OTO macro is the
problem but the increase in tokens parsed count (from reducing the
scale) is what's happening here.
Date: 8 Jun 2011 10:35:53
Message: <4def88c9$1@news.povray.org>
> Render failed
More than 1 Billion (US) tokens and parsing... but Virtual memory
allocated to povray is above 4 Gigabytes.
What is your OS ?
(A 32 bits one might have issue!)
Looks like it goes down to:
Parsing 1435168K tokens
 5223m 3.4g (Virt / Res)
(Res is irrelevant, it is just an indication that most of the 4 GB of
ram is used already on this system (x86_64 linux) by povray and
rendering will be slow due to swap)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 8 Jun 2011 11:04:11
Message: <4def8f6b$1@news.povray.org>
>> Render failed
> What is your OS ?
32 bit opensuse11.2
I mean I'm happy with the scale factor set at 0.5 ... but hey I was just
curious about how it would look at a lower scale ;-) maybe this is just
a worse case scenario compounded by me being on 32 bit ... but it sounds
like it's hammering (but working on) your system pretty good. maybe
others running the latest incantation might weigh in on this, as I'm not
sure if you'd call what I'm seeing a bug then.
