POV-Ray : Newsgroups : povray.beta-test : POV 3.7 beta 31 slow with mesh objects Server Time
29 Sep 2024 03:14:04 EDT (-0400)
  POV 3.7 beta 31 slow with mesh objects (Message 1 to 10 of 16)
Subject: POV 3.7 beta 31 slow with mesh objects
Date: 21 Mar 2009 13:19:59
Message: <49c521bf$1@news.povray.org>
  I tested scene with mesh objects with many triangles and POV 3.7 beta
on two cores renders it slower than old single threaded MegaPOV.
  Test scene with statistics files from MegaPOV and POV 3.7 beta are on
  http://devel.disnel.com/pov3.7-test
  it is rad_test04. Mesh objects are with unnecessary high detail to
demonstrate the problem. Rad_test 02 and 03 are without meshes and 3.7
beta is mush faster than MegaPOV with them, as expected.
Vaclav
Subject: Re: POV 3.7 beta 31 slow with mesh objects
Date: 21 Mar 2009 18:04:57
Message: <49c56489$1@news.povray.org>
How did you conclude from a scene using radiosity that meshes are slower?
	Thorsten
Date: 22 Mar 2009 06:10:31
Message: <49C60E96.1060507@disnel.com>
Thorsten Froehlich napsal(a):
>     Thorsten
With scenes without meshes is POV 3.7 mush faster than MegaPov, with
scenes with mesh objects is slower (much slower). From this I conclude,
that there is some problem with mesh objects. I don't conclude anything
about radiosity, I just use it nearly in all my renders and I used it in
test renders as well. I may try it with radiosity switched off, if it helps.
Vaclav
Date: 22 Mar 2009 06:40:01
Message: <web.49c614c3cd11f9a74cd5d81d0@news.povray.org>
Hello.
I assume that this is:
  *recursion_limit 2*
Currently, a recursion_limit > 1 slows the rendering of the scene compared to
POV-Ray 3.6.
This, because the algorithm of radiosity is under investigation.
try!
Carlo
Date: 22 Mar 2009 08:20:00
Message: <web.49c62be4cd11f9a79b04cb930@news.povray.org>
I assume we're talking about smooth meshes (i.e. mesh with smooth_triangle
elements, or mesh2 with normal vectors).
Can you do tests with "flat" meshes as well for reference?
Some of the changes I made to the radiosity code might have affected sample
density (and hence render time) on objects with pertubed normals (like smooth
meshes).
Date: 22 Mar 2009 11:10:00
Message: <web.49c653edcd11f9a79b04cb930@news.povray.org>
I took the liberty to add rad_test02 and rad_test04 to the portfolio of scenes I
use for benchmarking radiosity code changes. The 01 and 03 scenes asked for
additional include files which I did not find on the devel.disnel.com.
So far, tests with various variations to the radiosity code indicate that the
slowdown is in fact highly radiosity-related.
I expect future versions of POV-Ray to still require more CPU time for the
scenes than MegaPOV, but once again render faster in terms of "wall clock" time
even on a DualCore.
Date: 23 Mar 2009 04:39:00
Message: <49c74aa4@news.povray.org>
Fell free to use these scenes in any way.
Rad_test01 is something different and uses my own set of macros (you can
get them at http://povarch.sourceforge.net). This scene I used to
determine, how POV 3.7 works with trasparent objects and radiosity, you
don't need it for the problem with meshes. Rad_test03 uses fgrass.inc
include file made by Rune S. Johansen and can be obtained on his pages
(http://runevision.com). With this scene I tested, if the slowdown is
not related to complex textures (fgrass has several layers of textures
defined by function), I concluded, that not (you can look at .stat and
.time files there, .stat is statistics output from POV, .time is output
of UNIX time utility). Scene with fgrass texture was rendered faster
with 3.7 (but not two times faster, the speedup was much smaller ...).
I'll try rad_test04 with recursion_limit 1, as proposed by Carlo. C, and
with flat meshes, as proposed by you.
> even on a DualCore.
Date: 23 Mar 2009 06:18:20
Message: <49c761ec$1@news.povray.org>
rad_test04_flat (flat mesh) and rad_test04_rl1 (rad recursion level 1)
are there with resulting files and statistics. Speed problem looks very
similar with them.
Vaclav
Date: 23 Mar 2009 08:20:01
Message: <web.49c77db7cd11f9a76e4227230@news.povray.org>
I'm not surprised about the conclusions you drew from those stats, and as a
matter of fact I do see the same results here. If I wasn't the guy currently
twiddling around with radiosity to get it back to speed, I would probably come
to the same conclusions as you did.
The flat mesh idea is more sort of an experiment to get a clearer picture why
exactly radiosity is slowing down. If you're just after reasonably fast renders
of your shot, recursion_limit 1 is currently what you want.
Date: 23 Mar 2009 08:25:00
Message: <web.49c77f94cd11f9a76e4227230@news.povray.org>
> similar with them.
This is bad. I'm not too surprised about the flat mesh results, but the
recursion level 1 shots should render a good deal faster.
I'll run those scenes through my benchmarking process to see if I can get a
clearer picture on this.
