POV-Ray : Newsgroups : povray.beta-test : POV-Ray for Windows version 3.7 beta 1 available Server Time
9 Jun 2026 03:13:08 EDT (-0400)
  POV-Ray for Windows version 3.7 beta 1 available (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: POV-Ray for Windows version 3.7 beta 1 available
Date: 19 Apr 2005 13:49:13
Message: <42654499@news.povray.org>
Thorsten Froehlich wrote:
> A Mac version is going to be made available within the next few weeks.
To be more precise, the current goal is the first half of May.  However,
please note that this is just a goal and not a promise yet.
	Thorsten
Date: 19 Apr 2005 14:38:47
Message: <42655037$2@news.povray.org>
Tiger (10.4 OS) will be out, and POV 3.7 will take benefit from it :)
At least with GCC 4.0 (Xcode 2.0) ...
Best regards,
Author of Eureka 2.12 (2D Graph Describer, 3D Modeller)
http://eureka.atari.org
Date: 19 Apr 2005 16:01:10
Message: <42656386$1@news.povray.org>
Francois LE COAT wrote:
> Hi,
>> However, please note that this is just a goal and not a promise yet.
Well, but please don't hold your breath about 64-bit addressing ;-)  That is
only available to non-GUI programs (that is, i.e. database servers and soon
who really benefit from 64-bit addressing and don't need a GUI), so for
POV-Ray to use it, the GUI frontend and backend will need to be split apart
completely and run as two independent programs that communicate with each
other.  As few users have systems with that much RAM (less than 2% according
to the collected stats), I cannot possibly justify holding back a beta
release to develop the means to do this.  On the other hand, there are more
than ten times as many users with dual-processor Macs, who will benefit from
the multithreading.  It is more realistic in about a year from now to see
something like 64-bit support.  Sorry!
	Thorsten
Date: 22 Apr 2005 11:58:37
Message: <42691f2d@news.povray.org>
Ouch.  I am already running into situations where the 2GB memory addressing
limit is hampering my designs.  In fact, I ran into it quite some time ago.
Then again, where are the 64-bit floating-point compilers to take advantage of
this possibility?
>> Hi,
> That is only available to non-GUI programs (that is, i.e. database
> servers and soon who really benefit from 64-bit addressing and don't
> need a GUI), so for POV-Ray to use it, the GUI frontend and backend will
> need to be split apart completely and run as two independent programs
> that communicate with each other.  As few users have systems with that
> much RAM (less than 2% according to the collected stats), I cannot
> possibly justify holding back a beta release to develop the means to do
> this.  On the other hand, there are more than ten times as many users
> with dual-processor Macs, who will benefit from the multithreading.  It
> is more realistic in about a year from now to see something like 64-bit
> support.  Sorry!
>     Thorsten
David Wallace
TenArbor Consulting
"Just In Time Cash"
www.tenarbor.com
1-866-572-CASH
Date: 22 Apr 2005 14:48:52
Message: <42694714$1@news.povray.org>
s.
The 64-bits addressing is not the main feature of GCC 4.0 that I'm
looking forward ... I was speaking of refined optimizations such
as parallelization and vectorization of the PPC code ... It seems
that GCC 4.0 is a great step in the direction of more efficient
code generation.
Do you know more than I know myself ?
Best regards,
Date: 22 Apr 2005 17:28:18
Message: <42696c72$1@news.povray.org>
> code generation.
On the gcc mailing list there have been several notes that code actually is
slower when compiled with gcc 4.0 than with 3.4 due to some optimizations
they had to leave behind when getting their new optimizer framework in.
Supposedly only gcc 4.1 will bring most of those things back.
Besides, I am not exactly very confident with what Apple will ship with Mac
OS X 10.4 - while they claim it will be gcc 4.0, it cannot actually be
because that way only released *today* but Apple is already sending out CDs,
which must have been pressed at least a week ago.  Besides, in the past
serious bugs in Apple's custom version of gcc have broken popular C++
libraries such as boost - the current Apple supplied gcc 3.3.x (not the real
gcc) has had an infinite loop allocating memory bug in the *compiler* (not
the generated code) for several months and Apple has not taken any action.
As it stands, I would be more interested to get the 'real' gcc generate AIX
for PowerPC code as that uses the sane and properly designed PEF/CFM
execuatable format* rather than the flawed Mach-O format (see for example
the summary on <http://www.unsanity.org/archives/000044.php> to learn why
Mach-O applications are so slow)...
	Thorsten
* IBM developed it along with the first Power processor, the superset of the
instruction set and processor architecture PowerPC processors are based on.
When Apple moved to PowerPC, the first Mac OS was developed using IBM
compilers running on Power-based AIX workstations.
Date: 23 Apr 2005 03:01:25
Message: <4269f2c5@news.povray.org>
> AIX for PowerPC code as that uses the sane and properly designed PEF/CF
M
> example the summary on <http://www.unsanity.org/archives/000044.php> to
> learn why Mach-O applications are so slow)...
f
> the instruction set and processor architecture PowerPC processors are
> based on. When Apple moved to PowerPC, the first Mac OS was developed
> using IBM compilers running on Power-based AIX workstations.
Well, as you are speaking about IBM, it seems that XLC (the IBM
compiler) can just be put in place of GCC using Xcode and produce
the best code for PPC. I can't find any information about that ...
Can you ?
Best regards,
Date: 23 Apr 2005 10:19:31
Message: <426a5973$1@news.povray.org>
It is not about the compiler, but the executable format.  IBM had to port
their compiler to the flawed Mach-O, so it does not solve any of the problems.
	Thorsten
Subject: Re: Building POV (was: POV-Ray for Windows ...)
Date: 23 Apr 2005 13:01:32
Message: <426a7f6c@news.povray.org>
> port their compiler to the flawed Mach-O, so it does not solve any of
> the problems.
Well, you're speaking of another platform (AIX eventually).
I personally used XLC for benchmarking, comparing dual-G4 and
dual-G5, with standalone IBM compiler and GCC (Xcode 1.5).
Time (in seconds) for computing 100 images :
dua### [at] 125GHz : GCC (3.3) 104 s. - XLC (6.0) 85 s.
dua### [at] 25GHz  : GCC (3.3) 60  s. - XLC (6.0) 48 s.
and parallel code for image processing (matching mainly integers).
I know that Apple let XLC replace the GCC compiler of Xcode
to produce a better code. Have you heard about that ?
Best regards,
Date: 23 Apr 2005 13:25:34
Message: <426a850e@news.povray.org>
The IBM compiler is just a command-line program like gcc, and it also takes
most of the gcc flags for compatibility.  You can hook it into any
makefile/shell based process easily.
	Thorsten
