POV-Ray : Newsgroups : povray.animations : Subset Animation Not Working Server Time
16 Jul 2025 08:24:49 EDT (-0400)
  Subset Animation Not Working (Message 1 to 10 of 14)
Subject: Subset Animation Not Working
Date: 20 Mar 2006 09:49:51
Message: <441ec10f$1@news.povray.org>
I'm using povray for windows, version 3.6, 32-bit.  I've started getting
into some very large animations (1500+ frames per scene).  As I result
I've been having splitting my animations into chunks and rendering each
chunk on a different computer.
Where I am having trouble is is the Subset_Start_Frame and
Subset_End_Frame commands.  They do not seem to work properly.  For
example, in an animation I'm working on now (1200 frames), if I ask the
computer to render frames 600-800 using the Subset commands in the ini
file I do not actually get frames 600-800.  Rather, I get frames from
later on in the animation.
Strangely though, if I use the "Initial_Frame" and "Final_Frame"
commands like so:
Initial_Frame=600
Final_Frame=1200
It renders properly.  Only problem is that it doesn't stop at frame 800,
but rather goes straight on through.  Of course, if I set Final_Frame to
800 the animation gets compressed into fewer frames (i.e. 1200 frame
animation becomes an 800 frame), rather then rendering to frame 800 of 1200.
What is going wrong?  Is there an easy way around this?  Ini file
attached below (subset commands removed).
Bryan
Antialias=on
Antialias_Threshold=0.1
Antialias_Depth=2
Input_File_Name=10 mile.pov
Output_File_Name=C:\POV\10 Mile Point\animation\
Initial_Frame=600
Final_Frame=1200
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=off
Pause_when_Done=off
Subject: Re: Subset Animation Not Working
Date: 20 Mar 2006 10:20:00
Message: <web.441ec73d20875604b1b469160@news.povray.org>
This should work as it has worked for me.
Initial_Frame=1
Final_Frame=1200
Initial_Clock=0
Final_Clock=1
Subset_Start_Frame= 600
Subset_End_Frame=800
A point to bear in mind is, if you are doing calculations based on the clock
value as opposed to the Frame_number. You might get unexpected results
Date: 20 Mar 2006 10:30:18
Message: <441eca8a$1@news.povray.org>
"Bryan Heit" <bjh### [at] NOSPAMucalgaryca> wrote in message
news:441ec10f$1@news.povray.org...
> I am having trouble is is the Subset_Start_Frame and Subset_End_Frame
> commands.  They do not seem to work properly.  For example, in an
> animation I'm working on now (1200 frames), if I ask the computer to
> render frames 600-800 using the Subset commands in the ini file I do not
> actually get frames 600-800.  Rather, I get frames from later on in the
> animation.
Hi Bryan,
I just did a very small test using command line options "+kfi0 +kff10 +sf5
+ef6" in 3.6 and it did what I expected.
The only thing I can think of to check (sorry if it's obvious) is that you
are adding the subset settings as well as leaving the frame settings in the
ini file i.e. you should not be overwriting the frame settings with the
subset frame settings. Because clearly if you specify the subset final frame
without telling it the real final frame it's not going to be able to
correctly work out where in the cycle the frames should be.
Chris B.
Date: 20 Mar 2006 10:45:26
Message: <441ece16$1@news.povray.org>
That is how I did it.  I just ran a test, using your code, trying to
animate frames 820-900.  Once again, it did not work.  I don't know
exactly where it started, but it started somewhere in the neighborhood
of frame 1100.
But I think I may know what's going wrong.  When I use the subset
command, what gets returned when I call "final_frame" in the .pov file?
  I think that would explain my problem, if instead of getting the
"Final_Frame" from the ini file, the command was returning the value for
"Subset_End_Frame".
Since I use the "final_frame" call for a lot of calculations it would
explain why everything seems to go off when I use subsets (assuming I'm
right about my problem with the subset).
It is not an issue of using the clock command; the call "clock" doesn't
even appear in the .pov file I am using.
Bryan
Date: 20 Mar 2006 10:50:29
Message: <441ecf45$1@news.povray.org>
+kff10 +sf5
I'm doing it via an .ini file.  Perhaps it is treating it differently?
> ini file
Nope.  This is how I setup my .ini file:
Initial_Frame=1
Final_Frame=1200
Initial_Clock=0
Final_Clock=1
Subset_Start_Frame= 820
Subset_End_Frame=900
As I mentioned to Stephen, this appeared to start the animation at frame
~1100.   I'm thinking that maybe it's a problem with the way I calculate
a lot of stuff.  Rather then using "clock", I use "final_frame" and
"frame_number" for many calcs.  Perhaps the when I call "final_frame"
when subsets are in use, Pov is returning "Subset_End_Frame" instead?
Bryan
Date: 20 Mar 2006 11:10:01
Message: <web.441ed37520875604b1b469160@news.povray.org>
> +kff10 +sf5
> > ini file
> Initial_Frame=1
> Final_Frame=1200
> Initial_Clock=0
> Final_Clock=1
> Bryan
Put this line or similar into your pov file.
#debug concat ("frame_number = ", str(frame_number, -3), "/n")
and
Debug_File=C:outputpathdebug.txt
In your ini file. This will give you the actual Frame numbers in the file
debug.txt in your specified path. You might be able to work out what is
going wrong. The debug statement combined with concat and str can be very
useful fot faultfinding.
Date: 20 Mar 2006 11:12:51
Message: <441ed483$1@news.povray.org>
news:441ecf45$1@news.povray.org...
>  I'm thinking that maybe it's a problem with the way I calculate a lot of
> stuff.  Rather then using "clock", I use "final_frame" and "frame_number"
> for many calcs.  Perhaps the when I call "final_frame" when subsets are in
> Bryan
I think you're right. 'final_frame' does seem to come up with the last frame
of the subset being rendered rather than the value set using the Final_Frame
option setting (Which seems to conflict with the POV-Ray documentation).
Chris B.
Date: 20 Mar 2006 15:41:40
Message: <441f1384$1@news.povray.org>
I've ran a few tests and this is exactly the problem.  When you declare
a "Subset_End_Frame" povray will return that value when you call
"final_frame" in a .pov file.
Bryan
Date: 21 Mar 2006 09:30:00
Message: <web.44200d0120875604b1b469160@news.povray.org>
> Bryan
There is a command used in the ini file that is called this. The same as
+EFn in the command line.  If you try to send the value to #debug then you
get an undeclared identifier, error.
Date: 21 Mar 2006 10:34:26
Message: <44201d02@news.povray.org>
"Stephen" <mca### [at] hotmailcom> wrote in message
news:web.44200d0120875604b1b469160@news.povray.org...
>> > frame
>> > Final_Frame
>> > documentation).
>> Bryan
> You have lost me on this. Are you declaring your own "Subset_End_Frame"?
> Stephen
I think he means that when you set the Subset_End_Frame in the ini file that
the value you set it to is displayed in the message stream when you use the
debug command in POV-Ray to display the final_frame preset variable. The
same happens when you use the command line option +EFn to set the subset end
frame.
The documentation says that the final_frame variable available at run-time
in the SDL will contain the value set using Final_Frame, but from my tests
this doesn't seem to be the case if a subset end frame is defined.
I rendered the following two frames and got the following results from the
debug commands:
// Command line options  +kfi0 +kff10 +sf5 +ef6
camera { location <0,2,-2> look_at 0 }
light_source { <-5,30,-10> 1 }
#debug concat("Final Frame  : ",str(final_frame,3,3),"\n")
#debug concat("Initial Frame: ",str(initial_frame,3,3),"\n")
#debug concat("Frame Number : ",str(frame_number,3,3),"\n")
// Rendering frame 5 of 6
// Final Frame  : 6.000
// Initial Frame: 5.000
// Frame Number : 5.000
// Rendering frame 6 of 6
// Frame Number : 6.000
Not what I would have expected from the documentation.
Chris B.
