POV-Ray : Newsgroups : povray.animations : can't make static starfield, it keeps shifting Server Time
17 Mar 2026 19:09:13 EDT (-0400)
  can't make static starfield, it keeps shifting (Message 1 to 10 of 15)
Subject: can't make static starfield, it keeps shifting
Date: 15 Oct 2010 20:50:01
Message: <web.4cb8f65fd8b7640f7411a7fb0@news.povray.org>
I am trying to render an astronomy object, with stars as a background. This is
fine as a static image, but I'm having tremendous issues when doing an
animation. Basically, I can't find a solution to the simple problem of having
the exact same image (starfield) for all frames, when the camera is moving.
Looks like, no matter what, the starfield background is randomly built anew for
each frame. This is not good. I want the starry background to be exactly the
same in each frame, fully static relative to the moving camera.
I tried to paint Starfield1 on a box (or plane) and have the box move with the
exact same speed as the camera:
http://pastebin.com/raw.php?i=4KZL7jcG
povray from_mars.pov +W1920 +H1080 -visual DirectColor +A0.1 +AM2
Well, no, each frame the stars are painted again, randomly. :(
How do I make the starfield completely static for all frames when the camera is
moving?
Subject: Re: can't make static starfield, it keeps shifting
Date: 16 Oct 2010 03:31:24
Message: <4cb954cc@news.povray.org>
On 16/10/2010 1:48 AM, Florin Andrei wrote:
> Well, no, each frame the stars are painted again, randomly.:(
> moving?
Instead of your moving box, why not use a sky_sphere? I've used the
pigment from Starfield1 in the example below.
sky_sphere {
         granite
         color_map {
             [ 0.000  0.270 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
             [ 0.270  0.280 color rgb <.5,.5,.4> color rgb <.8,.8,.4> ]
             [ 0.280  0.470 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
             [ 0.470  0.480 color rgb <.4,.4,.5> color rgb <.4,.4,.8> ]
             [ 0.480  0.680 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
             [ 0.680  0.690 color rgb <.5,.4,.4> color rgb <.8,.4,.4> ]
             [ 0.690  0.880 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
             [ 0.880  0.890 color rgb <.5,.5,.5> color rgb < 1, 1, 1> ]
             [ 0.890  1.000 color rgb < 0, 0, 0> color rgb < 0, 0, 0> ]
     turbulence 1
     sine_wave
     scale .5
Best Regards,
Date: 16 Oct 2010 19:39:43
Message: <4cba37bf$1@news.povray.org>
>> camera is
>> moving?
> sky_sphere {
> pigment {
> granite
> color_map {
> turbulence 1
> sine_wave
> scale .5
This works because the sky_sphere is effevtively a unit sphere centered
on the camera.
This will works as long as the camera don't rotate.
The apparent change in your original star field is caused by a pattern
that relies heavily on sub-pixel details to do it's magic. When you move
the camera or the object that have the pattern, any difference in the
relative positions will cause the sub pixels bits that are visible to
change apparently at random.
The granite pattern used is very noisy, possibly the moisiest of all
patterns. That noise in increased by the applied turbulence.
Another effect of that trick is that it's resolution dependent. If you
change the resolution from, for example, 1600x1200 to 1601x1200, the
pattern of stars WILL totaly change.
If you want something consistant, you should take a look at the galaxy
include set. Available from the object collection:
http://lib.povray.org/searchcollection/index.php. Keyword "galaxy".
It can generate star fields, nebulaes, galaxyes, comets/meteors.
It have been successfully used in several animations.
Date: 18 Oct 2010 20:25:01
Message: <web.4cbce51d2d8aa957411a7fb0@news.povray.org>
I did that, I ripped the relevant part (the pigment) from the include file and
pasted it into my script, and reduced the scale a little bit, to make the stars
smaller:
http://dl.dropbox.com/u/29966/povray/from_mars.pov
But the stars are still twinkling a lot:
http://dl.dropbox.com/u/29966/povray/from_mars.mp4
I find it surprising that such a seemingly simple task (use a static bitmap as a
fixed background in an animation) is so hard to accomplish. Is there no way to
do that within povray?
Date: 18 Oct 2010 21:56:14
Message: <4cbcfabe@news.povray.org>
> smaller:
I tried your sample. Absolutely no flickring stars. As expected as you
use a sky_sphere.
BUT! If I stop the camera and ROTATE it like: rotate clock*y.
Doing that and I have flickering stars. Also expectable as you use a
pattern scalled very small and have sub-pixels details.
In the sample, you definetely don't use a static bitmap, but a pattern.
Date: 19 Oct 2010 05:20:28
Message: <4cbd62dc@news.povray.org>
Have you looked at the actually rendered frames? I think
you may be seeing artefacts from mp4 compression. Many codecs
don't really like artifical images and tiny sharp dots. Also,
does the animation really use a resolution of 1920x1080? If
not, you also have some scaling done by the converter.
Note that you should render without jitter (command line -J)
for animations, although it doesn't seem to do much here.
Date: 19 Oct 2010 15:50:01
Message: <web.4cbdf6632d8aa957411a7fb0@news.povray.org>
Here are the first 10 PNG frames (all 300 frames are like 30MB, and the first 10
are sufficient to demonstrate the problem):
http://dl.dropbox.com/u/29966/povray/from_mars.zip
You can move through them with an image viewer. The stars appearing and
disappearing between frames are clearly visible.
I am using povray 3.6.1 on Ubuntu Linux 10.04 32bit. The command line was:
How is my system different from yours that causes flickering here but not there?
Date: 19 Oct 2010 17:04:41
Message: <4cbe07e9@news.povray.org>
In your animation, it's mainly the fainter stars that flicker. Those are
to small to appear in my test renders.
My test used a much lower resolution and not the same aspect ratio:
+w800 +h600 +a0.2 +am2
With the kind of pattern used, it's not realy surprising.
A possible workaround:
Render an empty scene with only the background.
In the animation, use a large box or a plane somewhat behind the
farthest object.
Apply the prerendered background to that object as an image_map, scale
appropriately to cover the visible area. It may be interesting to post
process that image by bluring it a little.
Translate that object in parallel with the camera during the animation.
Date: 19 Oct 2010 19:41:10
Message: <4cbe2c96$1@news.povray.org>
> farthest object.
Alternatively, simply render the foreground with +ua then
the background will be transparent in the output file and you
can externally merge them with any background bitmap you like,
e.g., using the ImageMagick suite.
Date: 19 Oct 2010 21:02:32
Message: <4cbe3fa8@news.povray.org>
> moving?
    When I need a starry background in POV-Ray, I use an assortment of
randomly-placed triangles. There are other approaches, but I prefer this
because I like to use objects that model the simulated objects as
closely as possible. Stars, from the sightseeing viewpoint, are just
ultra-bright objects that are just close enough to appear as points of
light.
    The trick is to place the stars so that at least one pixel but no
more than four pixels overlap the star's silhouette on the computer
screen. This will give a point of light, especially when anti-aliasing
is used.
     Use the following code:
#local sB=sqrt(3)/min(image_height,image_width)/sCamZ;
#local pA=< 0,          sB*2/3,1>*100000;
#local pB=< sB/sqrt(3),-sB/3,  1>*100000;
#local pC=<-sB/sqrt(3),-sB/3,  1>*100000;
#local S0=seed(4);
#local cC=16;
#local sC=.5/cC;#while(sC<=1)
mesh {
#local iI=0; #while (iI<1600/cC*sCamZ*sCamZ)
   #local vAng=<rand(S0),rand(S0),rand(S0)>*360;
   #if
(vdot(vrotate(z,vAng),vCamD)>sCamZ/vlength(<sCamR/2,sCamU/2,sCamZ>) |
AllStars)
     triangle { vrotate(pA,vAng), vrotate(pB,vAng), vrotate(pC,vAng) }
#local iI=iI+1; #end
   no_shadow
pigment { rgb
<max(0,-(sC-1)*2),min(sC*4,-(sC-1)*4),max(0,(sC-.25)*4)>*.2+.8 }
finish { ambient 1 diffuse 0 }
//  scale Beyond
   translate pCamL
#local sC=sC+1/cC;#end
A number of parameters are used here that you'll need to define first:
* AllStars: If true, forces all stars to be made. When false prevents
creation of off-camera stars
* Beyond: This is commented out because you may not need it. If any of
the stars appear in front of other objects in your scene, take out the
slashes and set Beyond to some value that puts the stars beyond all of
the other scene objects.
* cC: This sets the number of shades of color the stars will have. Stars
will range in color from reddish to bluish.
* pCamL: The location setting of your camera.
* sCamR: The length of the right parameter of the camera. If you didn't
specify a right vector in the camera, use a value of 4/3 here.
* sCamU: The length of the up parameter of the camera. If you didn't
specify this parameter in the camera statement, use 1 here.
* sCamZ: The length of the direction vector in your camera. If you
specify the angle in your camera, then set this value equal to
cot(radians(angle)/2)*4/3. If you didn't specify either direction or
angle, use 1 here.
* vCamD: The normalized value of the direction vector in your camera
Hope this helps,
John
