POV-Ray : Newsgroups : povray.animations : Tech TV's Eyedrops Server Time
6 Oct 2024 10:04:59 EDT (-0400)
  Tech TV's Eyedrops (Message 1 to 10 of 10)
Subject: Tech TV's Eyedrops
Date: 20 Nov 2002 23:03:40
Message: <3DDC5D18.9C9944D1@comcast.net>
All,
  I'm just about finished a music video done completely
in POV I want to get on TechTV's EyeDrops show.  The technical
guidelines basically only tell me to encode it in MPEG.  I've
written TechTV and gotten no additional help.  I've rendered
all the frames in 720x540 per their recommendations.  I've got
several video programs which can assemble the files.  Are there
any pieces I may be missing?  Did I need to use field rendering?
I've rendered this at 15fps (again no direction from TechTV).
Any other suggestions?
Thanks,
    Emory
Subject: Re: Tech TV's Eyedrops
Date: 21 Nov 2002 07:15:46
Message: <3ddcce72$1@news.povray.org>
I think you may find that you needed to render at 30fps (for NTSC). Rendering at 15fps
may be
an insurmountable problem. I would think that using field rendering here would be
definitely
beneficial too. You'll need to find out whether they require MPEG 1 or 2, as this will
have a
direct impact on the end size of the video file ie. MPEG 2 = better quality for
smaller size
than MPEG 1.
TMPGEnc will encode to both of the above formats. http://www.tmpgenc.net/
All the best,
Andy Cocker
"Gwen & Emory Stagmer" <emo### [at] comcastnet> wrote in message
news:3DDC5D18.9C9944D1@comcast.net...
> All,
> Thanks,
>     Emory
Date: 21 Nov 2002 07:42:27
Message: <ppjptu4s8ab6154f8bmek2qb5832lgdh7b@4ax.com>
On Wed, 20 Nov 2002 23:12:08 -0500, Gwen & Emory Stagmer
<emo### [at] comcastnet> wrote:
>All,
>Thanks,
>    Emory
Hi Emory,
The settings you've used should be OK but if you wanted to get the
best out of the target format (i.e. NTSC) I would render at 30fps with
field rendering enabled (odd fields) - this should give you the
smoothest animation. One caveat though is that POV's field rendering
option renders two image files per frame, one for each field, which
you must somehow combine using a suitable tool to give a correct
field-rendered frame.
Also, the 720x540 seems strange to me - I've only really seen 720x480
as a recommended NTSC resolution. If you do decide to re-render I
would use 720x480
Another thing to mention is that if you do decide to render to fields
you should encode to MPEG2 since MPEG1 can't handle fields.
Cheers and good luck,
Scott
Date: 21 Nov 2002 10:19:25
Message: <BA02A8BD.71F4%fidel.viegas@artrecognition.co.uk>
in article ppjptu4s8ab6154f8bmek2qb5832lgdh7b@4ax.com, Scott Moore at
noo### [at] nospamcom wrote on 21/11/02 12:43 pm:
> would use 720x480
That's correct. For PAL TV it would be 720x576.
All the best
Fidel.
Date: 22 Nov 2002 07:15:43
Message: <3DDE21F6.8B032882@comcast.net>
The 720x540 resolution was the highest recommended by the
Eyedrops submission page at TechTV.com:
http://www.techtv.com/eyedrops/story/0,24330,3373159,00.html
They're kinda short on details in my opinion...this is my first
try at a TV compatible animation, so any help is a 'good thing' :)
Thanks (all) for your suggestions.  I'd love to re-render at 30fps,
but I'm up to about 6CPU WEEKS on my 1.8Ghz P4 machine at 15fps.
I don't want to delay the release by another 12 weeks...
Thanks again everyone,
   Emory
> > would use 720x480
> All the best
> Fidel.
Date: 22 Nov 2002 10:19:45
Message: <3DDE4B20.70909@free.fr>
For TV compatible animation, especially for broadcast,
beware of the TV overscan (upto 10% of the image near a border might
get mangled/eated by a TV). So check that no crucial part of the
animation happen in that zone.
Otherwise, some might see it and some other won't.
Date: 22 Nov 2002 15:49:10
Message: <Xns92CEA0DC3128Dtomatimporg@204.213.191.226>
Le Forgeron <jgr### [at] freefr> wrote in news:3DD### [at] freefr:
The other big conversion issue is color saturation.  What looks great on a
monitor can be just plain awful on ntsc or pal.
http://www.psu.edu/dept/cac/viz/sem_notes/cg_for_video/
or
http://www.camcorderinfo.com/info/colorguide.htm
Date: 22 Nov 2002 20:17:59
Message: <3DDED952.AB99FABD@comcast.net>
Thanks alot for your suggestions and websites.  I think I'm OK
on the color saturations since I tended to use very natural colors
in this animation.  Also: I've framed these images in such a way
that the 10% overscan probably isn't a problem.
I posted two stills to p.b.i: the titles are
"ezekiel 0" and "ezekiel 1".  Your comments are appreciated!
Emory
> or
Date: 23 Nov 2002 06:57:26
Message: <bdputus0aa3gkq3ochcan7ijfsje7qu81e@4ax.com>
On Fri, 22 Nov 2002 20:26:42 -0500, Gwen & Emory Stagmer
>in this animation.
Actually, black (RGB 0) can also cause problems - in fact any RGB
value less than 16 or more than 230 are not 'NTSC-safe'. I wouldn't
worry too much about this. Since TechTV don't mention this on their
website I assume they will handle this.
Cheers,
Scott
[Side Note]
Earlier on I was puzzled by when TechTV list 720x560 as a recommended
resolution - a quick search on the net revealed this was related to
aspect ratio. NTSC 'pixels' are not square - they're tall rectangles
(aspect ration of 0.9091) so if your rendering software doesn't allow
you to control aspect ratio (i.e. assumes square pixels) you should
render at 720x560 and then resize to 720x486 to pre-quash the image -
this will then ensure circles look like circles when displayed on the
TV. However, since POV does let you control aspect ratio you could
have saved yourself some CPU time by using
right     x*image_width*0.9091/image_height
in your camera statement and rendering to 720x486
Date: 4 Dec 2002 03:10:55
Message: <3DEDB8C3.F2031150@buckosoft.com>
I have, for years, said #declare FPS=30;
But these days, making actual VCDs with synched audio played on a real
live TV and not a Windows Media Player simulation, i have discovered that
#declare FPS=29.97;
is much more correct.
(I couldn't figure out: "if the drum machine runs at 120 beats per minute,
why is not one beat exactly 15 frames?")
dik
