POV-Ray : Newsgroups : povray.advanced-users : SOR pigmentation Server Time
14 Mar 2026 16:08:42 EDT (-0400)
  SOR pigmentation (Message 1 to 10 of 12)
Subject: SOR pigmentation
Date: 22 Jul 2011 04:30:00
Message: <web.4e293425ebd1ef4bd62250910@news.povray.org>
Hello
I use this code to produce the body of a rocket :
#declare forme = sor { 16,
                       <0.0005,-6>,
                       <1.0,-4>,
                       <1.01,-2>,
                       <1.15,0>,
                       <1.35,2>,
                       <1.55,4>,
                       <1.69,6>,
                       <1.8,8>,
                       <1.89,10>,
                       <1.925,12>,
                       <1.79,14>,
                       <1.5,16>,
                       <0.99,18>,
                       <0.175,20>,
                       <0.07,20.1>
                       <0.0005,23>
                       hollow
later restricted to the sections of interest by various "difference" with
co-axial cylinders in CSG operations, but this makes no ... difference.
When textured with :
#declare txtr = texture { pigment { color Red }
                         finish { ambient 0.05 diffuse 0.8 }
I get strange results, with the object beeing usually OK, but, for some
orientations and distances to the observer, full of "semi-random" holes
(perpendicular to the axis of the SOR), shape errors, and granite-like black
imperfections.
Which parameter is wrong ?
I set :
global_settings { max_trace_level 256 assumed_gamma 1.0 }
Thanks !
Gilles
Subject: Re: SOR pigmentation
Date: 22 Jul 2011 04:45:23
Message: <4e2938a3$1@news.povray.org>
Le 22/07/2011 10:27, 43oasis nous fit lire :
> Hello
>                        <0.0005,-6>,
>                        <1.0,-4>,
>                        <1.01,-2>,
>                        <1.15,0>,
>                        <1.35,2>,
>                        <1.55,4>,
>                        <1.69,6>,
>                        <1.8,8>,
>                        <1.89,10>,
>                        <1.925,12>,
>                        <1.79,14>,
>                        <1.5,16>,
>                        <0.99,18>,
>                        <0.175,20>,
>                        <0.07,20.1>
>                        <0.0005,23>
>                        hollow
> imperfections.
> I set :
Sor documentation:
http://wiki.povray.org/content/Documentation:Reference_Section_4.1#Surface_of_Revolution
have you tried to add "sturm" before "hollow" ?
what and where is your camera ? your light sources ?
Date: 22 Jul 2011 06:50:01
Message: <web.4e2950a0d8a46f7d62250910@news.povray.org>
> > Hello
> >                        <0.0005,-6>,
> >                        <1.0,-4>,
> >                        <1.01,-2>,
> >                        <1.15,0>,
> >                        <1.35,2>,
> >                        <1.55,4>,
> >                        <1.69,6>,
> >                        <1.8,8>,
> >                        <1.89,10>,
> >                        <1.925,12>,
> >                        <1.79,14>,
> >                        <1.5,16>,
> >                        <0.99,18>,
> >                        <0.175,20>,
> >                        <0.07,20.1>
> >                        <0.0005,23>
> >                        hollow
> > imperfections.
> > I set :
> Sor documentation:
Ah, interesting : by adding the "sturm" specification (more precise maths), I
remove almost all the black defects, leaving mainly the shape errors.
I removed the "hollow", which I do not use in fact ; no difference.
Here is the camera and lightsource specs :
#declare Position = (1-klok)*100*<100,15,80> - 10*<120,7,50>;
// Part of an animation, 0<=klok<=2 ; the effect occur around klok = 1.06.
// That is Position = <-1776.4413,-156.4662,-961.1530>
// This is where the SOR is translated in my scene
    #declare xS = 0;
    #declare yS = 1;
    #declare zS = 0;
    up <xS,yS,zS>
    angle 1
    location <0,0,-2000>
    look_at (Position - 9*x)
light_source {                    // far enough to avoid problems ...
  0
  color White
  translate <20000, 30000, -10000>
For zCam <= -1958.5 or zCam >= 2003.5, all the defects in my scene (where there
are other SORs, affected by the same problem) are gone.
Gilles
Date: 22 Jul 2011 10:40:49
Message: <4e298bf1@news.povray.org>
  If you are having rendering artifacts with the sor object (which you can't
get rid of even with 'sturm'), one possibility is to use a mesh instead.
As an additional bonus, the mesh might even render faster.
  Incidentally, there's a macro at lib.povray.org for that exact purpose
(ie. to create a mesh in the shape of a surface of revolution from a spline).
Date: 22 Jul 2011 13:45:01
Message: <web.4e29b5cad8a46f7d62250910@news.povray.org>
Thanks for this tip ; I'll try that.
I wonder how the rendering of the SOR can vary with the distance of the
observer,
and, more specifically, be wrong only within a certain interval of
distances/orientations ...
At first sight, it seems that this happen when the axis of the SOR is ~
perpendicular to the view ray, and, then, within a certain interval of observing
distances.
At first sight ...
Gilles
Date: 22 Jul 2011 14:35:16
Message: <4e29c2e4@news.povray.org>
> observer,
  It probably has to do with the algorithm by which it's calculated and
the limited accuracy of floating point numbers (although I can't say this
with certainty without knowing the specifics).
Date: 22 Jul 2011 14:55:26
Message: <4e29c79e@news.povray.org>
> camera {
>      #declare xS = 0;
>      #declare yS = 1;
>      #declare zS = 0;
>      up<xS,yS,zS>
>      angle 1
>      location<0,0,-2000>
>    0
>    color White
>    translate<20000, 30000, -10000>
> For zCam<= -1958.5 or zCam>= 2003.5, all the defects in my scene (where there
> Gilles
You place your camera at a large distance and use a very small angle
that effectivelt removes perspective. That, in turn, can cause
calculation errors. Those errors will cause the apearance of various
artefacts.
Try placing your camera closer and use the orthographic projection. It
effectively simulate a camera set at infinity.
Date: 23 Jul 2011 11:05:00
Message: <web.4e2ae293d8a46f7310dd5c30@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > camera {
> >      #declare xS = 0;
> >      #declare yS = 1;
> >      #declare zS = 0;
> >      up<xS,yS,zS>
> >      angle 1
> >      location<0,0,-2000>
> >    0
> >    color White
> > Gilles
> artefacts.
> Alain
I can imagine that (this is also a reply to Warp) floating point has a limiting
accuracy, which may be critical when you deal with infinitely thin (right ?)
surfaces like SOR.
Of course, without looking at the algorithm, one cannot say more ...
I am nevertheless slightly amazed by the fact that the defect vanish when you
move the camera closer or FARTHER from the object ...
Gilles
Date: 23 Jul 2011 12:15:07
Message: <4e2af38b$1@news.povray.org>
> surfaces like SOR.
Such is the floating point precision... and its issues.
For instance, considers (you can translate in C if you like):
#declare AA=1/10;
#declare BB=1/2;
#declare SA=0;
#declare SB=0;
#local I=0;
#while(I<10)
#declare SA=SA+AA;
#declare SB=SB+BB;
Bye now, what is the value of SB and SA ?
For instance, SB is 5.0;
But SA is not 1.0 (due to the fact that 1/10 cannot be represented
accurately in binary floating points)
Date: 23 Jul 2011 23:21:04
Message: <4e2b8fa0$1@news.povray.org>
> Alain<aze### [at] qwertyorg>  wrote:
>>> camera {
>>>       #declare xS = 0;
>>>       #declare yS = 1;
>>>       #declare zS = 0;
>>>       up<xS,yS,zS>
>>>       angle 1
>>>       location<0,0,-2000>
>>>     0
>>>     color White
>>> Gilles
>> artefacts.
>> Alain
> surfaces like SOR.
> Gilles
That's the problem with floating numbers. There are situations where
they introduce some random noise in the results, while, at other times,
you get exact results.
If you appen to work with values that can be represented exactly within
the precision available, all is well. If, at least some values can't be
represented exactly in binary, then you get rounding errors.
If you use very small values with large ones, or very large with small,
you get precision and underflow errors in addition to the rounding ones.
You can also notice that the defects will move, change or vanish totaly
if you rotate your object, or rotate the camera around it, while keeping
the same distance.
Also, in your case, if you scale the object, the result WILL change.
