POV-Ray : Newsgroups : povray.advanced-users : Media artifacts, help needed! Server Time
10 Jan 2025 19:43:41 EST (-0500)
  Media artifacts, help needed! (Message 1 to 10 of 12)
Subject: Media artifacts, help needed!
Date: 1 Oct 2006 13:55:00
Message: <web.45200051e7045ab39cf609e10@news.povray.org>
I'm working on a design which has a number of media-filled objects (using
emission to produce glowing effects around other solid objects). Very often
where 2 objects overlap in the camera view, occasonal bright white pixels
appear on the objects. I've tried rendering with anti-aliasing and a higher
max_trace_level and neither of these fix it. I've seen quite a few
references to this kind of problem with media, but have been struggling to
find any tips to solve it, or any discussion of the cause of this issue!
Has anyone got any good advice?
Thanks in advance for any help,
Pete Hurst
Subject: Re: Media artifacts, help needed!
Date: 2 Oct 2006 14:35:08
Message: <45215bdc@news.povray.org>
Random Pete nous apporta ses lumieres en ce 01/10/2006 13:52:
> Pete Hurst
It may be that you have some coincident surfaces between the media containers or
that those overlap.
Try making the containers a little bit smaller or shift the objects farther
apart from one another.
You may also try to move the camera some small amount from it's current location.
Just remember - if the world didn't suck, we would all fall off.
Date: 2 Oct 2006 16:00:01
Message: <web.45216ea75e9182af3dbbbbd10@news.povray.org>
It's a tricky one, this. I'm also having this problem with emissive media.
However, these white artifacts are occurring on container objects which do
not overlap, and even in reflections of the media in other objects.
Furthermore, the artifacts are different with every render, even when
nothing is changed in between. Antialiasing etc does not help. Since my
container objects are meshes, I originally thought that maybe polygon edges
were behaving like coincident surfaces or something, but I'm not so sure any
more.
I was going to deal with the problem by rendering the image at least double
the size necessary and then scaling it down in the GIMP, effectively
antialiasing them out externally, but the single spots I get on reflective
surfaces will not be ironed out so easily. My problem is that this is for
an IRTC entry, so editing the artifacts out individually (trivially easy)
is against the rules...
I am playing with media settings to see what I can do.
Bill
Date: 3 Oct 2006 07:44:04
Message: <45224d04@news.povray.org>
"Random Pete" <pet### [at] gmailcom> wrote in message
news:web.45200051e7045ab39cf609e10@news.povray.org...
> often
> higher
I'm working on an emission media problem as well with some clouds ....
(concentric spheres) and no_shadow keyword on the object nearest the camera
appeared to have helped with my problem.
Jim
Date: 3 Oct 2006 09:55:00
Message: <web.45226b265e9182af9cf609e10@news.povray.org>
Thanks for your suggestions, I'll let you know if I have any luck!
The media objects in question are
 - isosurface {f_poly4(x,y,z,0,1,-1,0,0)}  (a double-ended curved spike)
 - torus
 - sphere
There are many isosurfaces and torii in the scene, and one central sphere.
Artifacts are most prevalent where the isosurfaces are in front of the
sphere; however there are many elsewhere and (having looked at it again)
not necessarily where objects are in front of one another.
I'm rendering in MegaPOV since a bug in POV 3.6 (relating to spline
functions being passed to macros) often causes the scene to fail to parse.
Date: 3 Oct 2006 16:31:18
Message: <4522c896@news.povray.org>
If your container objects are meshs, you
might try adding inside_vector, not sure, but that
might help.
Date: 3 Oct 2006 21:16:09
Message: <45230b59$1@news.povray.org>
Bill Pragnell nous apporta ses lumieres en ce 02/10/2006 15:55:
> more.
> Bill
Any jitter anywhere? jitter changes randomly from render to render. Try adding
"jitter 0" in the media deffinition, it may help, at least, the problem pixels
won't change.
You can also try changing the method used from the default (method 3).
Try increasing the number of samples. If using the default, keep intervals to 1,
the default value.
Please hassle me, I thrive on stress.
Date: 3 Oct 2006 21:21:25
Message: <45230c95$1@news.povray.org>
Random Pete nous apporta ses lumieres en ce 03/10/2006 09:52:
>  - torus
>  - sphere
Try adding "all_intersection" to the isosurface.
Try adding no_shadow to the containers.
If a container is an union, try changing it to a merge.
Try adding "jitter 0" or "jitter off" to the media.
Try changing the number of samples.
"Sure, everyone's in favor of saving Hitler's brain, but when you put it into
the body of a great white shark, suddenly you're a madman."
             --Futurama
Did you know that Al Capone's business card said he was a used furniture dealer.
Date: 3 Oct 2006 21:30:01
Message: <web.45230d6d5e9182af9cf609e10@news.povray.org>
> might help.
No .. I was using meshes in the scene but they weren't media objects, plus I
already gave them an inside_vector!
I've got rid of most of the artifacts now in any case - I've removed the
central sphere entirely from the image (it was an idea I was trying that
didn't really work out) I also (stupidly) was using method 3 with more than
1 interval. Finally I played around with the CSG to avoid coincident
surfaces. There is still the occasional artifact but since tonight was the
deadline, they'll have to stay or be manually edited out!
I'll post in binaries.images once the final renders are complete...
Thanks again for all the advice.
Pete
Date: 4 Oct 2006 00:00:00
Message: <web.4523318d5e9182af9cf609e10@news.povray.org>
I'll remember that for next time I encounter problems! (Which I'm sure I
will - I love using media since it produces such wonderful effects). I've
posted my final renders in p.b.images.
Thanks again
Pete
