Hello,
The problem of the day :
I'm trying to project an image onto the rounded corner.
I've tried a lot of try with image_map and uv_mapping without success.
Here is my "best" (less bad) result for now.
Do you think it's possible to map the image directly onto the object?
The joined image is the result of three parts with two planar and one
cylindrical projection, but the joints don't stick :(
How would you do it ?
The geometry of the rounded corner is simple and I can post the code
with my tests using image_map{}.
The image used is here : <https://shorturl.at/mnqz2> on which I added
red marks.
Kurtz le pirate
Compagnie de la Banquise
Download 'coin4.png' (495 KB)
Preview of image 'coin4.png'
Use a parametric function, so that you could make the geometry of the curve, and
then use that to uv-map it manually in SDL by applying the function as a 1:1
mapping function from <x, y> to the <u, v> of the shape.
I have to head out, but can elaborate on that if you need me to.
- BW
Attached is a method using new v3.8 and yuqk features. While working up
new inbuilt functions for yuqk, I've tried to implement them with the
ability to return 't' or indexes for maps when that's possible.
The shapes I left as isosurfaces. Better render performance could be had
by using using more basic CSG for the shapes and still the function set
up for applying the image_map.
Bill P.
Download 'rndcrnr.jpg' (158 KB)
Download 'rndcrnr.pov.txt' (7 KB)
Preview of image 'rndcrnr.jpg'
Yep. In the scene where I wrote ObjLeftL and ObjLeftR, those should have
been ObjLegL and ObjLegR, respectively.
(The definition of Pink is also extraneous)
Bill P.
> Bill P.
after two days of absence, I find your example... and what example !
on first reading, I understood nothing, but I'm going to peel it back a
bit more.
and I need the yuqk fork, which I don't have and which isn't (yet?)
available for my platform.
It's an excellent proofreading exercise.
What a job! Hats off to you!
Kurtz le pirate
> bit more.
He's just got the uv-mapping data hardwired into the object definition.
So, if you were going to map a sphere, you'd use theta and phi to describe the
surface.
remapping theta and phi from radians to a 0-1 domain, you can grab the pixel
from the image.
So you just write a function to do that "inverse uv mapping", and apply it to an
average texture that combines the r, g, and b values from the image map.
- BW
>> bit more.
I'm always overwhelmed on initially seeing more than the simplest code
from others! My own old code too, truth be told.
I'm aiming for the scene I posted to be a shipped example in the next
release. As I've added more comments, I picked up a couple more typos
(*)... None affected the result, but they certainly hurt the clarity of
the example. The next release of yuqk will have this code with
additional comments - and I hope no remaining mistakes - should you want
to wait to 'peel'.
(*) - f_elliptical_sphrswp(...,-90,-90...) should have read '+90,-90'.
The first value is an initial starting position for the sphere sweep and
the only values allowed are left handed rotations of [0.0...360.0) so
the implementation took the -90 as abs(-90) or +90, despite what I typed...
What Bill W says is true. Conceptually, it's just user directed,
piecemeal, uv mapping in play here - another form of what you were
trying in fact.
In yuqk, generally, I've been pushing the code toward more ways to paint
shapes - often using other shapes. The inbuilt f_path() function in yuqk
is as much about painting CSG shapes, as it is about having a new way to
set up isosurface shapes (which can also paint themselves).
The 'list_object' pattern new to yuqk is conceptually an internal
implementation of Matthew Goulet's / Blue Herring's 'multiobj.inc' from
the currently offline, but being worked upon, object-collection
(lib.povray.org).
Yuqk's inbuilt f_elliptical_sphrswp() is conceptually similar to Bruno
Cabasson's elliptic_torus.pov.
Some of yuqk's density_file interpolation extensions are for playing
with 3D painting of objects. Ideas related to SDL proximity pattern
implementations of years past (Edouard Poor?).
Yuqk's new 'pattern_modifiers' keyword is about capturing complex
spatial manipulations which can then be accessed to keep textures,
function defined shapes, and CSG-shapes aligned / matched. The aim is
texturing in simpler 3D space and shapes ahead of spacial changes /
deformations - and having it all track correctly for a final result.
This an extension of capturing transforms in the same manner.
Anyhow. It's true a lot of what looks new / complicated in yuqk is just
what others have taken runs at long ago in a different, perhaps
extended, form.
(The user_defined{} bit is, of course, clipka's work already in v3.8
beta 2 / v4.0)
Bill P.
Check out:
https://developer.nvidia.com/gpugems/gpugems/part-iii-materials/chapter-20-texture-bombing
Seems simple enough to do, and ought to be fast if implemented in source.
- BW
> Check out:
> - BW
Thanks for the pointer! Added it to my notes.
I think, maybe, Sam did something like this a long time ago in SDL. I
vaguely remember an image of tree leaves on the ground...?
Bill P.
