POV-Ray : Newsgroups : povray.advanced-users : L*C*h(uv) color solid Server Time
8 Feb 2026 05:07:25 EST (-0500)
  L*C*h(uv) color solid (Message 1 to 10 of 82)
Subject: L*C*h(uv) color solid
Date: 18 Nov 2016 02:22:19
Message: <582eac2b$1@news.povray.org>
I would like to create a three-dimensional representation of the
L*C*h(uv) color space in the form of a cylinder.
How would I do that?
I may limit myself to colors that also exist in the sRGB color space.
Mike
Subject: Re: L*C*h(uv) color solid
Date: 18 Nov 2016 08:37:57
Message: <582f0435$1@news.povray.org>
I assume you already have a formula to convert the color space to sRGB.
What you need is a function-based pigment that yields appropriate
RGB values based on x,y,z coordinates inside the cylinder. There is
no direct way to define a user-defined color function (unless you
already have a pigment) but you can do it like this:
1. Define three separate float functions yielding R, G, B separately
f_R(x,y,z)
f_B(x,y,z)
f_G(x,y,z)
2. Create red / green / blue pigments from that using function
pattern and red / green / blue color_maps
3. Join the 3 pigments into RGB pigment via "average" pattern.
Regarding implementation of f_R(x,y,z) I was going to suggest
you derive radial distance and angle around y from x-z pair via
(pythagoras / atan2) but as far as I understand LCh(uv) is already
a cylindrical version of Luv so these transformations are
technically part of the color space conversion itself.
Still it would probably be useful to implement the coordinate
transformation (including appropriate scaling of intervals) in
a separate set of functions f_L, f_u, f_v since you need them
multiple times in the definition of f_R, f_G, f_B.
Date: 18 Nov 2016 12:41:48
Message: <582f3d5c$1@news.povray.org>
Actually, I have a formula to convert a *single* color vector from LCH
to sRGB.
https://github.com/THEjoezack/ColorMine/blob/master/ColorMine/ColorSpaces/Conversions/LchConverter.cs
But I don't know how to convert this to one of POV-Ray's functions.
Mike
Date: 18 Nov 2016 13:25:03
Message: <582f477f$1@news.povray.org>
> Mike
I would go via the fresh uv-mapping of cylinder, using a gradient map to
other gradient map of orthogonal direction.
Date: 19 Nov 2016 02:53:34
Message: <583004fe@news.povray.org>
>> Mike
Here illustrated with a lemon, and HSL2RGB.
The adaptation to a cylinder and L*C*h(uv) is left as an exercise for
the reader.
Download 'lemon.pov.txt' (1 KB) Download 'lemon.png' (74 KB)
Preview of image 'lemon.png'
Date: 19 Nov 2016 12:43:02
Message: <58308f26$1@news.povray.org>
> the reader.
I want to model the 3D shape of the color solid, too. This is a very
irregular shape, and I believe I will need to create an isosurface.
Mike
Date: 19 Nov 2016 12:47:19
Message: <58309027$1@news.povray.org>
Let's start with a relatively simpler example of converting CIE XYZ to
sRGB. The following function is copied from here:
https://github.com/THEjoezack/ColorMine/blob/master/ColorMine/ColorSpaces/Conversions/XyzConverter.cs
         internal static IRgb ToColor(IXyz item)
             // (Observer = 2°, Illuminant = D65)
             var x = item.X / 100.0;
             var y = item.Y / 100.0;
             var z = item.Z / 100.0;
             var r = x * 3.2406 + y * -1.5372 + z * -0.4986;
             var g = x * -0.9689 + y * 1.8758 + z * 0.0415;
             var b = x * 0.0557 + y * -0.2040 + z * 1.0570;
             r = r > 0.0031308 ? 1.055 * Math.Pow(r, 1 / 2.4) - 0.055 :
12.92 * r;
             g = g > 0.0031308 ? 1.055 * Math.Pow(g, 1 / 2.4) - 0.055 :
12.92 * g;
             b = b > 0.0031308 ? 1.055 * Math.Pow(b, 1 / 2.4) - 0.055 :
12.92 * b;
             return new Rgb
                 R = ToRgb(r),
                 G = ToRgb(g),
                 B = ToRgb(b)
I think it would be pretty easy to produce a macro that does all of the
above. But how do I turn that into a POV-Ray function? The function
needs to work as a color as well as an isosurface I think.
Mike
Date: 19 Nov 2016 12:55:07
Message: <583091fb$1@news.povray.org>
>> the reader.
for once, I would go for mesh
Date: 19 Nov 2016 12:59:16
Message: <583092f4@news.povray.org>
Basic of povray: the shape is not bound to the texture (excepted for
uv_mapping).
Make the work for the shape, and separately the work to map 3D
coordinates to colour.
Date: 19 Nov 2016 13:18:57
Message: <58309791$1@news.povray.org>
> uv_mapping).
Okay. But how?
Mike
