Am 09.09.2016 um 00:00 schrieb Mike Horvath:
> The camera is spherical. Do I really need to scale the "up" and "right"
> vectors to the image dimensions? I was under the impression that the
> spherical camera already automatically fills a 2:1 aspect ratio image.
My bad, I didn't pay much attention to the camera type.
Having had a closer look at the source code, here's my updated
(counter-intuitive) advice:
- To mirror the image vertically, flip the _right_ vector.
- To mirror the image horizontally, flip the _up_ vector.
- To mirror the image vertically _and_ turn the camera 180 degrees, flip
the direction vector.
Entirely untested, but that's what I infer from the source code.
On 9/8/2016 4:10 PM, clipka wrote:
> Am 08.09.2016 um 14:44 schrieb Mike Horvath:
>> It is a LDraw model, which has an inverted y axis or handedness. The
>> problem is when I render the scene, it appears upside-down. Even though
>> I already compensated by making the y axis negative. Anyone have an idea
>> what is going on?
> To me it looks like you're trying to achieve via camera up, right and
> direction what someone else has already cared for via the matrix
> transform, so effectively the two cancel out.
I forgot to add that the matrices are generated by the converter, and I
have no influence over what they contain.
Mike
I still suspect POV-Ray messes up when confronted with left-handed
coordinate systems in the spherical camera code. My up, right, location
and direction values work fine with a normal perspective camera. It's
only when they are applied to a spherical camera that the results are
incorrect.
Mike
Am 09.09.2016 um 01:03 schrieb Mike Horvath:
> incorrect.
No, POV-Ray doesn't mess up in spherical camera mode. It just uses the
`right` and `up` vectors in a weird, non-intuitive manner. As alluded in
my updated advice, `right` doesn't specify what's left and right in a
spherical camera image, nor does `up` specify what's up and down.
Instead, `direction` and `right` together specify what's up and down
(the `direction` vector rotated around the `right` vector by 90 degrees
gives you up when rotated in one particular direction, and down when
rotated in the other), and `direction` and `up` together specify what's
left and right (again the `direction` vector rotated around the `up`
vector by 90 degrees gives you left when roated in one particular
direction, and right when rotated in the other).
Do you mean mirroring or rotating? Because the image needs to be rotated
180 degrees, not mirrored.
Mike
> Mike
Disregard.
Mike
Le 08/09/2016 à 14:44, Mike Horvath a écrit :
> I have the following spherical camera:
> #declare Camera_Up = -y;
> #declare Camera_Right = +z;
> #declare Camera_Location = <0,0,0>;
> #declare Camera_Direction = -x;
> #declare Camera_LookAt = Camera_Location + Camera_Direction;
> #declare Camera_Transform = transform
> matrix <0,0,-1,0,1,0,1,0,0,0,-88,-640> // front entrance
> // matrix <0,0,-1,0,1,0,1,0,0,0,-88,100>
> // matrix <0,0,-1,0,1,0,1,0,0,0,-88,-180>
> // matrix <0,0,-1,0,1,0,1,0,0,-280,-88,-180>
> // matrix <0,0,-1,0,1,0,1,0,0,280,-312,140>
> // matrix <0,0,-1,0,1,0,1,0,0,200,-312,-140>
> // matrix <0,0,-1,0,1,0,1,0,0,-200,-312,-140>
> // matrix <0,0,-1,0,1,0,1,0,0,-360,-312,140>
> camera
> spherical
> angle 360 180
> up Camera_Up
> right Camera_Right
> location Camera_Location
> direction Camera_Direction
> transform {Camera_Transform}
> It is a LDraw model, which has an inverted y axis or handedness. The problem is when
I render the scene, it appears upside-down. Even though I already compensated by
making the y axis negative. Anyone have an idea what is going on?
> Mike
If you add a small look_at, it goes fine.
What is interesting is without it it seems to not recompute the direction/up/right
Download 'ca.png' (3 KB)
Download 'ca.pov.txt' (2 KB)
Preview of image 'ca.png'
I think this is intentional, as we had to define an order for camera parameters
in 3.6 to overcome a lot of trouble with the arbitrary order of parameters
taking immediate effect. Thus the relative parameters are only applied once in a
specific order and cannot be transformed in a meaningful way (the internal
representation is slightly different from the misc options available to the
user). Only absolute positions will be affected by teh transformation for
obvious reasons then: It is impossible to know what part of a transformation to
apply on which relative parameter (i.e. translations would not make sense).
http://www.the5thwave.com/cartoon/3906
Heh! I'd almost forgotten Rich Tennant's cartoons. Thanks for the reminder.
John
It's not about bravery.
It's about doing what I need to do to win
