POV-Ray : Newsgroups : povray.unofficial.patches : Another post_process idea Server Time
19 Mar 2026 06:12:11 EDT (-0400)
  Another post_process idea (Message 25 to 34 of 34)
Subject: Re: Another post_process idea
Date: 27 Apr 2000 20:05:03
Message: <chrishuff_99-AA2D30.19080527042000@news.povray.org>
In article <fnMIOTUUN9bxt3LPOpYLvXWLF9LA@4ax.com>, Glen Berry
<7no### [at] ezwvcom> wrote:
> We could probably at least arrange to store only the attributes that
> a given filter actually needs, instead of storing everything. That
> way, a extremely large temp file would only be generated if you used
> a filter that required one.
This is already done...each filter has a set of flags for the types of
information it uses, and only that information is saved. Or were you
talking about only saving information for pixels that will be used? That
probably wouldn't have much of a gain, since most filters use all of the
pixels...
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 28 Apr 2000 07:48:21
Message: <qqmem7qa1kq.fsf@schlatt.fmi.uni-konstanz.de>
Chris Huff <chr### [at] yahoocom> writes:
> In article <qqm### [at] schlattfmiuni-konstanzde>, Thomas
> Willhalm <tho### [at] willhalmde> wrote:
> > Perhaps you should consider to apply the filter on the fly. I know
> > that you need more than one pixel a time for several of the
> > exististing and proposed filters. Perhaps it is possible to determine
> > which one you need and forget the others.
> This would probably be quite difficult...currently, a filter can access
> any position in the data "images". To do this, you would have to do it
> during rendering, and would probably have to place restrictions on the
> possible things the filters can do. Either that, or recalculate the data
> as it is required...which could get extremely slow. Most people have
> enough disk space.
> And what is wrong with a temporary file anyway?
My small hard disc ;-)
I wasn't aware that most filters use much more than a few pixels at a time.
In future, I will be more patient and watch the implementations coming
before I doubt their usefulness.
http://thomas.willhalm.de/ (includes pgp key)
Date: 28 Apr 2000 10:24:00
Message: <39099eff@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: True for most of these, but the COLOUR type is an array of 3 floats, not
: doubles.
  So we get:
  786432*(3*4+3*8+2*8+8+6*8+3*8) = 103809024 bytes = 99 Megabytes.
  Not much difference.
: Currently, only the needed data is saved.
  But if the function uses all the parameters, it will take the maximum
amount?
  If the function is applied in a pixel-by-pixel basis, regardless of the
other pixels, why can't it be done on the fly, as someone else suggested?
It would certainly save lots of memory and/or disk space usage.
  And I don't think that writing and then reading 100 Megs of data to/from
disk is the fastest operation possible...
Date: 28 Apr 2000 13:37:09
Message: <3909cc45$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
However, limiting filters to a single pixel of data greatly limits the
functionality.  Almost all photoshop filters (including relatively simple
ones of the "filter factory" type) use access multiple pixels at a time.
-Nathan
Date: 29 Apr 2000 06:56:38
Message: <390abfe6@news.povray.org>
Nathan Kopp <Nat### [at] koppcom> wrote:
: However, limiting filters to a single pixel of data greatly limits the
: functionality.  Almost all photoshop filters (including relatively simple
: ones of the "filter factory" type) use access multiple pixels at a time.
  That's right, but I was referring to the coloring function only. The other
filters will still need data from the whole image, but hopefully not that
much.
Date: 29 Apr 2000 10:08:05
Message: <chrishuff_99-439477.09110929042000@news.povray.org>
In article <390abfe6@news.povray.org>, Warp <war### [at] tagpovrayorg>
Coloring function? You mean filters that only adjust the colors? Some of
those would depend on multiple pixels too.
Filters are applied in order...you can't do 1-pixel filters first and
only save the data in a file if a filter like blur is used. You would
have to add a completely different filtering system to the code, it
would make code maintenance and filter coding harder, and would really
not have much of a benefit.
I really don't see the problem with the file caching idea...it is used
for photon mapping, radiosity, etc. It is also what is used in image
editing programs. I would like to see it extended to allow load_file and
save_file, so the render doesn't have to be redone every time...the size
really only becomes a problem on large render sizes with every possible
filter, something that would be quite rare. Most filters only require
color information, and only the necessary data is saved. If space is so
tight that you can't have a program generate a temporary file about
10.5MB (1024*768*(5*2-byte color components + one 4-byte depth
component, color and depth seem to be the most commonly used)), I
suggest you clean out your hard drive. :-)
> The other filters will still need data from the whole image, but
> hopefully not that much.
They will still need all the data they needed before...and if one
multi-pixel filter is used, all of the filters would have to be done the
way things currently are done.
Date: 1 May 2000 12:12:25
Message: <390dace8@news.povray.org>
: If space is so
: tight that you can't have a program generate a temporary file about
: 10.5MB (1024*768*(5*2-byte color components + one 4-byte depth
: component, color and depth seem to be the most commonly used)), I
: suggest you clean out your hard drive. :-)
  I counted about 105 MB, not 10.5 MB. That's a whole lot more.
Date: 1 May 2000 19:21:54
Message: <chrishuff_99-C13F6D.18250301052000@news.povray.org>
In article <390dace8@news.povray.org>, Warp <war### [at] tagpovrayorg>
It sure is, you are off by a factor of 10.
1024*768 = 786432
5 color components per pixel at 2 bytes each, plus one depth value at 4
bytes:
14 bytes per pixel
786432*14 = 11010048 bytes per 1024*768 image processed with filters
using depth and color(the two most commonly used variables).
11010048/1048576(the number of bytes in a megabyte) = 10.5 MB.
Remember that only the necessary information is saved...I think
"find_edges" and "normal" are the only ones which use normal
information, and none use UV coordinates or intersection point.
Including the post_process filters I made, the only ones which use depth
are "stars", "normal", "find_edges", "focal_blur", and "depth". Most
only use color information, which has to be stored in some form anyway.
If only those filters are used, you have a 7.5MB temporary file for a
1024*768 image.
Date: 3 May 2000 05:37:45
Message: <390ff368@news.povray.org>
: 5 color components per pixel at 2 bytes each
  You said earlier that the color components are stored as floats.
: Remember that only the necessary information is saved...
  I was calculating the worst case scenario, where everything is needed.
Date: 3 May 2000 08:53:52
Message: <chrishuff_99-9E6F43.07570203052000@news.povray.org>
In article <390ff368@news.povray.org>, Warp <war### [at] tagpovrayorg>
Of course, that should be 4 bytes.
That would be 15MB for filters which only use color, and 21MB for
filters using color and depth. Not tiny files, but certainly a lot
smaller than 100MB. And since the are *temporary* files, they are gone
when the render finishes.
That scenario is currently impossible to reach, the filters don't exist
for it...and if it was possible, most of them would be wasted anyway,
since some(like depth or normal) would completely replace previously
processed images.
