POV-Ray : Newsgroups : povray.unofficial.patches : Another post_process idea Server Time
14 Mar 2026 02:37:26 EDT (-0400)
  Another post_process idea (Message 15 to 24 of 34)
Subject: Re: Another post_process idea
Date: 27 Apr 2000 08:43:24
Message: <390835eb@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: r, g, b                   - unclipped RGB colors.
: x, y, z                   - intersection point.
: u, v                      - UV coordinates.
: depth                     - distance to intersection point.
: inorm_x, inorm_y, inorm_z - surface normal at intersection point.
: pnorm_x, pnorm_y, pnorm_z - perturbed surface normal.
: dir_x, dir_y, dir_z       - ray direction(if I succeed in adding it to
: the available information).
  Don't tell me all this is stored into memory in order to be able to apply
the post processing?
  Hmm... Let's count.
  If we make a 1024x768 image that would be 786432 pixels.
  I suppose that the floating point numers are of 'double' type, which means
8 bytes (in PC and most other systems).
  This means that for each pixel the rgb info will take 3*8 bytes, the
intersection point 3*8 bytes, the uv-coordinates 2*8 bytes, the depth 8
bytes, surface normals and perturbed normals 6*8 bytes and finally the ray
direction 3*8 bytes.
  Summing all this up we get:
  786432*(3*8+3*8+2*8+8+6*8+3*8) = 113246208 bytes = 108 Megabytes.
  Taking into account that the average computer has 128 Megabytes of memory,
that would eat it up pretty efficiently.
  If all this is not stored into memory, then forget this :)
Date: 27 Apr 2000 08:43:58
Message: <3908360d@news.povray.org>
Btw, I think this is a good idea. Keep up the good work :)
Date: 27 Apr 2000 09:13:33
Message: <chrishuff_99-426A53.08163427042000@news.povray.org>
In article <390835eb@news.povray.org>, Warp <war### [at] tagpovrayorg>
> apply the post processing?
>   Hmm... Let's count.
> means 8 bytes (in PC and most other systems).
True for most of these, but the COLOUR type is an array of 3 floats, not
doubles.
> 8 bytes, surface normals and perturbed normals 6*8 bytes and finally
> the ray direction 3*8 bytes.
> memory, that would eat it up pretty efficiently.
Currently, only the needed data is saved. Each post_process has a set of
flags indicating which data it needs, and only that data is
saved/loaded. This would be harder to do with the color_function filter,
since you would have to detect which functions and/or variables are
used, but it should still be possible.
Also, I don't know if this is the way it already is done, but it should
be possible to save to a file and only read in the data as it is used.
This would slow down some post_processes though...it would probably be
best as an option that people could turn on for lower-memory systems.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 27 Apr 2000 12:35:08
Message: <qqmd7nbfqo3.fsf@schlatt.fmi.uni-konstanz.de>
Chris Huff <chr### [at] yahoocom> writes:
Mmmh, I don't like the idea of saving a temporary file that has several
times the size of the final image. Perhaps you should consider to apply
the filter on the fly. I know that you need more than one pixel a time for
several of the exististing and proposed filters. Perhaps it is possible
to determine which one you need and forget the others.
http://thomas.willhalm.de/ (includes pgp key)
Date: 27 Apr 2000 13:15:53
Message: <39087636.C4483C9B@inapg.inra.fr>
What about the possibility of aborting/continuing a trace ? It's already a
problem with the current post-processing implementation (focal blur behaves
strangely when a trace that have been aborted is resumed).
G.
Date: 27 Apr 2000 13:18:11
Message: <39087653@news.povray.org>
In article <390835eb@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
If you look into the MegaPOV 0.4 source code you will find that a maximum of
160 bytes per pixel are in memory (using the default COLORs are float (4
byte) and DBL is double (8 byte)).  However, there are several flags in
there which I guess reduce the amount of data stored per pixel.
     Thorsten
Date: 27 Apr 2000 13:41:34
Message: <fnMIOTUUN9bxt3LPOpYLvXWLF9LA@4ax.com>
On 27 Apr 2000 18:35:08 +0200, Thomas Willhalm <tho### [at] willhalmde>
A few thoughts come to mind:
Not all filters can be performed "on the fly."
Photoshop, probably the most respected image processing program on the
planet, uses its own swap file to store temporary image data while
processing an image. This swap file easily grows to many times the
size of the original image. It's just the nature of image processing.
I will admit that the POV post_processing represents an unusual
situation, in that we have so many additional attributes per pixel, in
addition to the typical R, B, and G values. If all these values are
stored in a temp file, it will indeed be many times larger than the
final output file. On the bright side, at least this file will be
deleted, and isn't permenant.   :)
Also this large array of potential attributes to work with, offers
many interesting possiblities for filters that can't be implemented
in a 2D program like Photoshop. For example, we have the potential to
create a *much better* "trace contour" filter than the one in
Photoshop. The one in Photoshop is based solely on altering the tonal
range of the image, with no knowledge of the actual geometry of the
scene. In our case we can not only take tonal information into
account, but we have access to the actual geometry of the scene. We
can find exactly where the edge of an object is, and not have to guess
based on a change in pixel brightness.
So yes, some filters would need large amounts of memory or temp/swap
files, but there is probably little we can do about it, especially for
some of the proposed filters. We could probably at least arrange to
store only the attributes that a given filter actually needs, instead
of storing everything. That way, a extremely large temp file would
only be generated if you used a filter that required one.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 27 Apr 2000 13:54:03
Message: <39087DD5.6A67FCFD@pacbell.net>
And let's face it, not all computers are created equal or have the same
amount of ram available. There are a few scenes I have had to abort
development on simply because I did not have the system resources to
support the features and number of objects I was trying to work with.
I am certainly not going to blame the program for my system's shortcomings.
If you want to play with "big boy" computer programs you should be ready
to spend the money on the equipment needed to support them.
Date: 27 Apr 2000 14:02:08
Message: <O4AIORaFjLuoYv2vsvbkPoinqBzx@4ax.com>
Ken actually agrees with something I said? Let me mark this on the
calendar. It's a rare day.   :)
Later,
Glen Berry
Date: 27 Apr 2000 20:01:14
Message: <chrishuff_99-A3CDE4.19035327042000@news.povray.org>
In article <qqm### [at] schlattfmiuni-konstanzde>, Thomas
It is better than trying to keep it all in RAM!
> Perhaps you should consider to apply the filter on the fly. I know
> that you need more than one pixel a time for several of the
> exististing and proposed filters. Perhaps it is possible to determine
This would probably be quite difficult...currently, a filter can access
any position in the data "images". To do this, you would have to do it
during rendering, and would probably have to place restrictions on the
possible things the filters can do. Either that, or recalculate the data
as it is required...which could get extremely slow. Most people have
enough disk space.
And what is wrong with a temporary file anyway?
