POV-Ray : Newsgroups : povray.unofficial.patches : post_process suggestions? Server Time
2 Apr 2026 16:57:28 EDT (-0400)
  post_process suggestions? (Message 51 to 58 of 58)
Subject: Re: post_process suggestions?
Date: 3 May 2000 19:10:17
Message: <chrishuff_99-3649B7.18132903052000@news.povray.org>
In article <ie71hscr585hiohhurfjkp8bq9pe1ppnt5@4ax.com>, Peter Popov
<pet### [at] usanet> wrote:
> www.gimp.org
Uh, right. Thanks. :-)
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 4 May 2000 01:32:37
Message: <OAoROftXR6qd1ySUb3WprSIpKqpE@4ax.com>
On Wed, 03 May 2000 18:10:46 -0500, Chris Huff
<chr### [at] yahoocom> wrote:
>This sounds like it would best be done as a simple macro using
>blur_matrix(which should probably be renamed to "convolution_matrix",
>since it can do more than blurring and it seems to be the common name).
If you want, you could also shorten that to simply "convolve" and save
some typing. Since we are referring to a process and not an object,
the verb might also be more appropriate than the noun as well.
Just an idea...
Glen
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 4 May 2000 12:12:37
Message: <3911a175@news.povray.org>
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-80DFAD.19253627042000@news.povray.org...
> Does anyone have any suggestions for additional filters?
A GTran filter - makes your images look like Giles did them.
Date: 4 May 2000 13:34:17
Message: <vLMROTH8RQpXI=BKlhdeTYhui0Xe@4ax.com>
On Thu, 4 May 2000 17:12:33 +0100, "Tom Melly" <tom### [at] tomandluf9couk>
While we are wishing for the impossible, I want the GTran+10 filter.
It makes your images look like a Giles rendering from 10 years into
the future. (He might be excellent now, but just imagine how great he
will be 10 years from now.) As a small side effect, it also speeds
your rendering time an amount equivalent to the speed increase of
computers in the next 10 years.
Later,
Glen Berry
Date: 4 May 2000 14:52:17
Message: <UcQROZw2W1joV6Ajm0U7uS80aIp5@4ax.com>
>> A better way to increase contrast would be to apply the
>> filter as I've specified it, then apply an S-curve-shaped correction
>> to stretch the midrange.
>I have been thinking about this...is there a "standard" curve used for
>this, or should I just come up with something?
For what it's worth, here is one example of an S-curve:
    Output = 0.5-(cos(Input*pi)/2)
For this to work, both input and output need to be constrained between
0 and 1. It should work with other ranges of values with appropriate
scaling. The angular unit is expressed in radians, in this example.
This generates an S-Curve, but I'm not sure of an easy way to add
additional parameters and make it more flexible, without losing the
"S" shape.
This curve is also very similar to a generic representation of the
response curve of photgraphic film. It would need some modification to
work as a film response emulator, a subject I raised earlier. The
input range would need to accept those unclipped float values, and the
ouptput would need to be constrained to a range suitable for the
output file format. I'm not yet sure how to add the extra parameters
to do this properly.
Later,
Glen Berry
Later,
Glen Berry
Date: 4 May 2000 17:45:31
Message: <chrishuff_99-F97DDA.16484404052000@news.povray.org>
In article <UcQROZw2W1joV6Ajm0U7uS80aIp5@4ax.com>, Glen Berry
> "S" shape.
This is certainly "a" S-curve, but I wanted to know if there is a
formula for one which is considered the "standard", official or not...a
possibly better solution would be a polynomial curve, or something
similar to what I posted in .binaries.images a while back, where you
could change it from an S-curve to a straight line to a
backwards-S-curve, by modifying the exponent. This also makes a S shape,
and the version I posted works with "out of range" values.
This sounds like it would best be done with the "curves" filter I am
planning, which takes a 3D spline or a color_map for the curve...
Date: 4 May 2000 23:46:30
Message: <FUMSOZRek52TE5mBLKHN7VYeCs19@4ax.com>
On Thu, 04 May 2000 16:48:44 -0500, Chris Huff
Splines sound like a good idea. I wasn't sure how elaborate you were
wanting to get. It would be really nice to be able to enter a series
of values (input vs output levels), and have the software generate a
smooth response curve from them.
Later,
Glen Berry
Date: 5 May 2000 08:39:56
Message: <chrishuff_99-59A043.07430905052000@news.povray.org>
In article <FUMSOZRek52TE5mBLKHN7VYeCs19@4ax.com>, Glen Berry
That is what I am planning...but I am debating whether to use an
internal spline(probably a cosine spline, maybe an optional cubic
spline), or to use a color_map(easier, multiple "film types" can be
declared in an include file and used in the "curves" filter, but I
suspect only uses linear interpolation.).
Maybe a "blend_type" option should be added to _maps to switch between
cosine, linear, cubic, etc. This would solve the problem with using
color_maps, and make anything which uses color_maps, texture_maps,
normal_maps, etc more flexible as well.
