POV-Ray : Newsgroups : povray.unofficial.patches : Announce: SkyPOV 0.1 Server Time
13 Jul 2026 22:12:33 EDT (-0400)
  Announce: SkyPOV 0.1 (Message 21 to 30 of 65)
Subject: Re: Announce: SkyPOV 0.1
Date: 5 Nov 2000 09:20:30
Message: <chrishuff-8FE4AE.09234205112000@news.povray.org>
In article <chrishuff-AE6B1C.09490803112000@news.povray.org>, Chris
Huff <chr### [at] maccom> wrote:
> I will send you the code as soon as it is tested.
I've found a couple more bugs, for example, Insert_Spline_Entry() took a
vector and tried to pass 5 float values through it. I changed that to an
expression... However, it might be a good idea to have separate
Insert_Spline_Vector_Entry() and maybe Insert_Spline_Float_Entry()
functions for ease of use in other code.
I also cleaned up a lot of the code, mostly just reformatting it, but
partly rewriting some functions. And I fixed some typos in the
comments...:-)
I plan on doing more, but I thought you would like to have what I have
done so far. I hope this is helpful in the work you are doing.
The spline code changes are here:
http://homepage.mac.com/chrishuff/mpovplus/splines.zip
I will upload the curves post_process patch soon.
Christopher James Huff
Date: 5 Nov 2000 11:56:55
Message: <3A059156.6903634A@enst.fr>
Mark Wagner wrote:
> Chris Huff wrote in message ...
> >In article <3a03ab54$1@news.povray.org>, "Mark Wagner"
> ><mar### [at] gtenet> wrote:
> >(got a better name for the last one? "all"?)
> "all" makes more sense than "grey".
	I think it depends on what the spline does exactly: is it the same as:
rgb SPLINE, SPLINE, SPLINE
	Or does it only change the brightness? A good thing to add too:
spline-based manipulations on hue and saturation...
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 5 Nov 2000 12:35:37
Message: <chrishuff-2DD880.12353405112000@news.povray.org>
It uses the same spline to adjust each channel. The current value of the
channel is taken as the "t" value of the spline, and the result of the
spline is used as the new value for the channel.
> A good thing to add too: spline-based manipulations on hue and
> saturation...
Not as a special feature of the spline patch...just use a rgb_to_hsl
filter, then use the ordinary curves filter to adjust hue or saturation,
then use hsl_to_rgb to get the corrected image back. More flexible, less
complicated, and you can combine it with other things to get special
effects. And I *am* planning to write these conversion filters...as soon
as I figure out the math. I've found lots of information about
converting between color spaces, but little or nothing about the actual
equations used to convert between rgb and hsl. That, or I'm just not
recognizing it when I see it...
Date: 5 Nov 2000 21:40:13
Message: <chrishuff-D7CD9A.21401305112000@news.povray.org>
In article <chrishuff-2DD880.12353405112000@news.povray.org>, Chris
> ...as soon as I figure out the math. I've found lots of information
> about converting between color spaces, but little or nothing about
> the actual equations used to convert between rgb and hsl. That, or
> I'm just not recognizing it when I see it...
Never mind, I just came across a couple files Nathan sent me which
should do everything that I need. I had set them aside and completely
forgotten about them...
Date: 6 Nov 2000 00:46:07
Message: <3a06459f$1@news.povray.org>
>In article <3a04ed21@news.povray.org>, "Mark Wagner"
>> The limit is 256 points -- enough for most uses, but why have a limit
>> when there doesn't need to be one?
>It looks to me like that was just a stopgap measure...it looks like you
>could implement it mostly by adding code to the Insert_Spline_Entry()
>function.
>I don't have any experience with growing dynamically allocated
>arrays...I tend to use linked lists for everything.
I've already got the code for this written -- it's just a matter of copying
it from my personal version to SkyPOV.
>> >Also, it would be useful if you could access the control points, with
>> >functions that behave similar to the array functions and an array-like
>> >syntax.
>> This might be very difficult to implement -- there are enough
>> problems with the spline syntax as it is.
>I think could get it working with functions, but I have no idea how to
>do the array like syntax...
>INT spline_points(SPLINE_IDENT) Retrieves the number of points in the
>spline.
>EXPRESS get_spline_point(INT_INDEX) Returns the corresponding point on
>the spline.
I think that, usage-wise, it would be better to use the array syntax.  This
would allow points to be changed and read using a single syntax.
>BTW, I implemented the SPLINE_IDENT(T, TYPE) syntax. You can now do
>something like this:
>#declare Spl = spline {linear_spline ...}
>#declare Val1 = Spl(T);
>#declare Val2 = Spl(T, cubic_spline);
>#declare Val3 = Spl(T, quadratic_spline);
>I will send you the code soon.
Thanks!
Subject: color definition (Re: Announce: SkyPOV 0.1)
Date: 6 Nov 2000 04:15:53
Message: <3a0676c9@news.povray.org>
> Anyway, this is the syntax I am planning to use(I am currently working
> on the first form):
don't you like pov schema for color definition ?
> curves {rgb RED_SPLINE, GREEN_SPLINE, BLUE_SPLINE}
curves {red RED_SPLINE green GREEN_SPLINE blue BLUE_SPLINE}
> curves {red RED_SPLINE}
> curves {green GREEN_SPLINE}
> curves {blue BLUE_SPLINE}
ok.
> curves {gray GRAY_SPLINE}
curves {rgb GRAY_SPLINE}
ABX
Subject: Re: color definition (Re: Announce: SkyPOV 0.1)
Date: 6 Nov 2000 07:04:15
Message: <chrishuff-44E1AE.07041506112000@news.povray.org>
In article <3a0676c9@news.povray.org>, "Wlodzimierz ABX Skiba"
> > on the first form):
Uh, POV doesn't let you specify colors with splines. And you don't
specify colors in the curves patch, it simply reuses the keywords as
names for color channels.
Some of those would be pretty easy to do, but they would just be
confusing...since you are not specifying a color. Would you like it
better if it required the "type" keyword before the type?
And anyway, the syntax I use is better suited for expansion to other
color spaces. I plan to allow other color spaces to be manipulated by
adding a filter to convert to those spaces, but a future version of the
curves patch may allow a shortcut for modifying those spaces. Your
syntax will cause confusion("I can modify red and green at the same
time, but not blue and saturation?").
Date: 6 Nov 2000 08:21:02
Message: <3a06b03e@news.povray.org>
yes, I know
but this could be useful - color curves like color_map
#declare Curve=curve{red Spline1 green Spline2 filter Spline3}
#declare Pigment=pigment{pattern color_map{curve Curve}}
therefore I thought about similiar syntax
this also allow extension to other color spaces I think
>color spaces.
but you put sign "=" between meaning of "all" and "gray"
is it true in other color spaces ?
>Your
it depends of implementation in your planned patch :-)
ABX
Date: 6 Nov 2000 16:40:15
Message: <chrishuff-3C7AB3.16401506112000@news.povray.org>
In article <3a06459f$1@news.povray.org>, "Mark Wagner"
> copying it from my personal version to SkyPOV.
>  This would allow points to be changed and read using a single
> syntax.
Arrays don't have any special syntax for insertion...and I don't think
reading the points with [] brackets will be very easy. As for changing
existing points...what would this do?
#declare Spl[2] = 0.4;
Would this set the t value of the third point to 0.4, or would it set
the x value? Also, this syntax would be a problem for using arrays of
splines.
I would suggest using functions for most of these:
Getting number of control points:
Reading a point:
FLOAT get_spline_t(SPLINE_IDENT, INDEX)
Returns the "distance" of the point at INDEX.
EXPRESS get_spline_value(SPLINE_IDENT, INDEX)
Returns the value of the spline at INDEX. I'm not sure how to handle
floats, vectors, and colors...maybe this function will work for all of
them.
Modifying a point:
set_spline_t(SPLINE_IDENT, INT_INDEX, FLOAT_NEW_T)
Changes the "distance" of the point at INDEX.
set_spline_value(SPLINE_IDENT, INT_INDEX, EXPRESS_VALUE)
Changes the value of the spline at INDEX. You can specify a float,
vector, color...
Adding a point should be possible already, it should work fine with the
modifications I made(mainly the fix to Copy_Spline()). Just do something
like this:
#declare Spline = spline {Spline NEW_POINTS}
And one other thing that should probably be taken care of: multiple
points with the same t value should probably not be allowed. New points
with the same t value of an existing point should replace that point. I
don't remember seeing anything about this in the source code...
Date: 6 Nov 2000 19:09:19
Message: <chrishuff-C07E8A.19092006112000@news.povray.org>
In article <3a06b03e@news.povray.org>, "Wlodzimierz ABX Skiba"
I have been thinking the possibility of something like this...I think it
might be useful. But I don't think it applies to the curves patch...
No, it won't. See explanation below.
The "=" operator isn't used in this patch...I don't know what you mean.
> >Your
No, it doesn't. For example, you can't manipulate red and hue
simultaneously, you can only manipulate one color space at a time. This
is because saturation and hue affect red, green, and blue, and the same
goes for the reverse. My syntax will allow the addition of hsl, hue and
saturation modes, yours won't, at least not in a way that makes sense.
However, those shouldn't be necessary anyway, since you can just use
other conversion filters before and after the curves filter to get the
same result. So we are back to whether or not to use the color syntax
for splines.
What exactly is deficient in the syntax I chose? Why do you think
specifying splines representing color channel curves with a color-like
syntax is a better idea than specifying a channel and a spline to go
with it?
