POV-Ray : Newsgroups : povray.unofficial.patches : Iso-equation query Server Time
7 Apr 2026 05:38:40 EDT (-0400)
  Iso-equation query (Message 1 to 10 of 11)
Subject: Iso-equation query
Date: 4 May 2001 08:17:33
Message: <3af29ddd$1@news.povray.org>
In a book I'm reading, there is a nice 3d shape which the book says is the
result of the equation:
x^3 + y^3 = 1
However, it comments "x and y are regarded as complex variables".
What does a complex variable mean in this context and what would be the
iso-surface function for the above?
Many thanks in anticipation...
"To stop children being afraid of the dark, try to fill their daylight hours
with as much terror as possible"
www.tomandlu.co.uk
Subject: Re: Iso-equation query
Date: 4 May 2001 08:48:53
Message: <3AF2A40F.7E249429@videotron.ca>
> x^3 + y^3 = 1
A complex variable is a variable that holds a a number that has the form
"a + bi", where i is an imaginary number defined as sqrt(-1).
I could be wrong, but I don't think isos work with complex numbers and
since both x and y are two-dimensional values, it makes the function
describe a 4D shape, which I know isos don't understand.
Francois Labreque | The surest sign of the existence of extra-
    flabreque     | terrestrial intelligence is that they never
        @         | bothered to come down here and visit us!
  videotron.ca    |                             - Calvin
Date: 4 May 2001 18:34:28
Message: <3AF32D5F.A1E292DD@faricy.net>
Cubic julia fractal?
Date: 4 May 2001 22:05:44
Message: <3AF35FB8.E9903A83@usb.ve>
> x^3 + y^3 = 1
There is too little information to give you an answer. What I see is a
complex function which depends on four real variables with a real
constraint. I can't imagine how this could be used in a iso-surface. Is
there any other information in your book about how the shape was constructed?
If not, you could contact the author(s) and ask.
Regards, Alberto.
Date: 4 May 2001 23:22:15
Message: <3AF371A8.DC10F9BD@usb.ve>
Thinking a little bit further, you can consider that you have a complex
restriction. In this case, your question has many answers. One solution is
 x^3 - 3*x*y^2 - sqrt(3)*z^2*sqrt((-3*x^2*y + y^3 + z^3)/z) +
  ((-3*x^2*y + y^3 + z^3)/z)^(3/2)/(3*sqrt(3)) = 1
Alberto.
Date: 7 May 2001 03:39:02
Message: <3af65116@news.povray.org>
So you can't do iso-mandelbrots?
Nekar
#version unofficial MegaPov 0.7;#local Q=seed(7);#local S=<-2,2,5>;#local
E=<2
,-2,5>;#local B=S;#while(vlength(B-E)>.1)#local
B=(B+(<rand(Q),rand(Q),rand(Q)
>/20));#local B=B-(2*(B-S))*((vlength(B-E)>vlength(S-E)));#local
S=B;glow{//NX
location S size.1 radius.07}glow{location S size.1 radius.07 rotate
z*90}#end
Date: 8 May 2001 04:31:17
Message: <3af7aed5@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:3af65116@news.povray.org...
Well, you can't have iterations in an iso. I've wondered if, provided you
were willing to accept a fairly low number of iterations, it would still be
possible by nesting the iterations (which would no longer be iterations).
Date: 8 May 2001 06:34:48
Message: <3af7cbc7@news.povray.org>
Well, I believe you can trick POV into using recursive functions, you
need to break the recursion using the if() "function". You have to
declare the function as something else first, a completely empty function
will work, then you follow it with a recursive declaration.
Christopher James Huff - chr### [at] maccom
Home Page: http://homepage.mac.com/chrishuff/
POV-Ray TAG e-mail: chr### [at] povrayorg
POV-Ray TAG web site: http://tag.povray.org/
Date: 8 May 2001 08:51:49
Message: <3af7ebe5$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:3af7cbc7@news.povray.org...
Can you post a small sample of this?
Date: 8 May 2001 13:05:43
Message: <3AF82777.39719F7A@comtrade.ee>
If you get last version of POVMan, then you can use specific shader type
iso_function for isosurface potential calculation. Shader language
supports for and while cycles, so it is quite easy write 'recursive'
iso-functions. POVMan documentation contains example of menger sponge,
where you can specify iteration depth by setting shader input parameter
and watch, how sponge disappears...
