POV-Ray : Newsgroups : povray.unofficial.patches : Bug in isosurface using pigment function? Server Time
15 Jun 2026 03:23:19 EDT (-0400)
  Bug in isosurface using pigment function? (Message 15 to 24 of 24)
Subject: Re: Bug in isosurface using pigment function?
Date: 25 Nov 2000 04:29:54
Message: <3A1F8692.ECF21C45@schunter.etc.tu-bs.de>
Chris Huff wrote:
> A sor should be pretty easy, a lathe shouldn't be extremely difficult. A
> mesh may not be a huge problem either. Simple convex prisms also
> wouldn't be hard, but concave or self-intersecting prisms could be a
> bigger problem.
With linear splines this should be easy too, but the others would involve
some more complicated math that would probably be quite slow when not hard
coded.
> Basically the distance of the nearest point on the surface, with a
> negative sign if inside the object and a positive sign if outside.
> This is what my proximity pattern will eventually do.
proximity pattern is quite slow right now, but for linear spline
prisms/lathe/sor, i could think of a different algorithm dividing space
into segments where proximity only depends on a single plane, that would
use quite a lot of memory, but it would be fast.  Of course this would
also have some problems with concave shapes, but since the isosurface use
only needs good results near the actual surface, this is not that
problematic.
Date: 25 Nov 2000 04:58:35
Message: <3a1f8d4b@news.povray.org>
Christoph Hormann wrote in message
<3A1F8692.ECF21C45@schunter.etc.tu-bs.de>...
> proximity pattern is quite slow right now...
but don't need so much small accuracy and perhaps so big max_gradient
therefore this could be faster than pigment{object{}}
I'll tell you after (ray)tracing
ABX
VooVoo is not VooDoo -> http://www.voovoo.art.pl/
Date: 25 Nov 2000 06:20:51
Message: <chrishuff-8864ED.06212025112000@news.povray.org>
In article <3a1f8d4b@news.povray.org>, "Wlodzimierz ABX Skiba"
In order to get a smooth enough pattern that the isosurface algorithm
can use it, you need to use a huge number of samples. It has been tried
before, but was too slow to be of practical use.
However, I am working on an updated version that has specialized
proximity functions for each object as well as the existing sampling
function...this will be much faster for many objects.
Christopher James Huff
Date: 26 Nov 2000 08:59:49
Message: <3a211755@news.povray.org>
Chris Huff wrote in message ...
sounds great
ABX
Date: 27 Nov 2000 03:25:49
Message: <3a221a8d@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: but
: his color_map is [0 rgb 1][0 rgb 0][1 rgb 0], which looks like a mistake
: to me...it is completely black, with no variation at all
  Did you actually try to render an object with that pigment?
  It's not completely black :)
Date: 27 Nov 2000 03:29:00
Message: <3a221b4c@news.povray.org>
: What are you expecting this color_map to result in? It starts out as
: white, but goes to black in 0 distance and ends in black, basically a
: black pigment...
  Try rendering a plane with that pigment.
Date: 27 Nov 2000 06:46:41
Message: <chrishuff-F1C033.06471327112000@news.povray.org>
In article <3a221a8d@news.povray.org>, Warp <war### [at] tagpovrayorg>
I rendered a unit-radius sphere... :-(
Right...it's a black cube surrounded with white, something that could
just as easily been done using the object pattern with a box. It still
won't work very well for isosurfaces, which dislike instantaneous
changes in value.
Date: 27 Nov 2000 07:13:42
Message: <3a224ff6@news.povray.org>
Well, my original idea was precisely trying to recreate any object with
an isosurface using an object pigment. Seems that I'm not the first to
get the idea.
  And I understand now why it doesn't work.
  So still no easy non-uniform transformations. Sorry :)
Date: 27 Nov 2000 10:37:42
Message: <3A227FD2.280D7793@skynet.be>
> get the idea.
Someone tried it a while ago.  Using "object" pattern doesn't work,
because of the "abrupt changes".  Using "proximity" pattern works
better, but is, as expected, awfully slow...
Fabien.
Date: 27 Nov 2000 11:03:52
Message: <3a2285e8$1@news.povray.org>
Fabien Mosen wrote in message <3A227FD2.280D7793@skynet.be>...
currently I'm trying with specialized patch
ABX
