POV-Ray : Newsgroups : povray.unofficial.patches : Diffuse==0 on edges of step functions in isosurfaces Server Time
7 Apr 2026 14:13:49 EDT (-0400)
  Diffuse==0 on edges of step functions in isosurfaces (Message 1 to 10 of 11)
Subject: Diffuse==0 on edges of step functions in isosurfaces
Date: 16 Sep 2000 22:15:54
Message: <39c4295a@news.povray.org>
I posted an image in p.b.i. under  the title of "Lines on isosurfaces."
I asked for help about a trivial problem and discovered a more serious
one.  I am using essentially a step function in an isosurface.  I find
that mega refuses to give me any diffuse reflection for this object.
I was using the cells function, I found a similar problem with my
homemade version using ceiling and noise3d.
#declare celly=function{pigment{cells}}
#declare fnoise=16;//40;
isosurface{
                function{y/160-
                celly((x+1000)/fnoise,y/fnoise,(z+1000)/fnoise)
       accuracy 0.01
        threshold  0.0  //  .03
        contained_by {sphere{0,600}
        pigment{SeaGreen}         normal{bumps}
        finish{ambient 0.2}
Subject: Re: Diffuse==0 on edges of step functions in isosurfaces
Date: 16 Sep 2000 22:20:01
Message: <chrishuff-F22EFB.21215916092000@news.povray.org>
In article <39c4295a@news.povray.org>, "Greg M. Johnson"
I think the most likely explanation is that it can't compute the correct
normal for those surfaces.
Christopher James Huff
Date: 18 Sep 2000 07:52:42
Message: <39C600D1.36F21F0B@my-dejanews.com>
The irony, Chris, is that it fails where the normal calculation is a
no-brainer: you've got a straight edge there.  The "top" surface is AOK; the
edges for these step functions have diffuse=0.
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 18 Sep 2000 08:55:08
Message: <chrishuff-860503.07570818092000@news.povray.org>
In article <39C600D1.36F21F0B@my-dejanews.com>,
A no-brainer for you, but the computer doesn't know it is a surface, it
only knows about a point on a ray and differences in a density function.
If the normal is the main problem, tracing three rays could help
calculate the correct normal. Of course, the normal calculation would be
1/3rd as fast...
Date: 18 Sep 2000 09:30:38
Message: <39C617C3.E9180E3A@my-dejanews.com>
> 1/3rd as fast...
What is the code for that?  I vaguely remember some kind of code that said
max trace 2 or something
____________
Greg
codes at home.
Date: 18 Sep 2000 19:08:52
Message: <chrishuff-91239F.18100218092000@news.povray.org>
In article <39C617C3.E9180E3A@my-dejanews.com>,
It hasn't been written yet. :-)
I was thinking of a possible way to fix the problem, sacrificing speed
to get good normals where they were previously impossible.
Date: 19 Sep 2000 04:46:54
Message: <39C72960.3F78BE9@enst.fr>
	Are you sure? I thought I saw something in the doc about there being
two methods for computing normals in isosurfaces and isoblobs and one of
them looks a lot like what you described...
Date: 19 Sep 2000 08:21:56
Message: <chrishuff-D7A23C.07235719092000@news.povray.org>
That would be the "normal on|off" feature...I don't know the details of
the different methods, but "normal on" is supposed to be more accurate,
though it can't be used with functions using noise3d() or atan2().
Date: 20 Sep 2000 04:59:26
Message: <39C87DD8.1513758B@enst.fr>
	Yes, that's it. I think that "normal off" is less accurate precisely
because it relies on a sampling method. OTOH it works in all cases
whereas "normal on" requires more definitions (in POV's source code, not
in your file) that don't exist for all functions (and maybe can't exist
for some) and therefore is less general.
PS: note that I haven't looked in detail at this part of the code so I
could be completely wrong...
Date: 21 Sep 2000 17:34:45
Message: <chrishuff-688F58.16365021092000@news.povray.org>
> not in your file) that don't exist for all functions (and maybe can't
> exist for some) and therefore is less general.
But what about the speed? "normal on" is slightly *slower* than the
original method...and I don't think tracing 3 jittered isosurface rays
would be very fast.
I had the impression the original method used several (7?) samples of
the function to determine the normal(sort of like the way MegaPOV
calculates the normals for patterns, and the way my displace warp
works). Sampling the *difference in density* in each direction from the
point, which is much faster than tracing rays.
I could be completely wrong though...I haven't even looked at this code.
