POV-Ray : Newsgroups : povray.unofficial.patches : interior_texture doesn't work with CSG? Server Time
5 Jul 2026 22:02:07 EDT (-0400)
  interior_texture doesn't work with CSG? (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Do shadow rays take into account interior_texture?
Date: 28 Jul 2000 10:33:49
Message: <chrishuff-235EB6.09343428072000@news.povray.org>
In article <398177f6@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   The subject says it all. It seems to my that they don't. I can post a
> concrete example if someone needs it.
Please do...this might be something that was just missed in the addition
of this patch to MegaPOV.
Subject: Re: interior_texture doesn't work with CSG?
Date: 28 Jul 2000 10:34:01
Message: <39819A2D.C0EF04AB@free.fr>
Of course this code should be surrounded by:
#ifdef InteriorTexturePatch
#endif
> *** Nicolas Calimet
> *** http://pov4grasp.free.fr
Date: 28 Jul 2000 11:01:19
Message: <3981a03f@news.povray.org>
I think that the source code and the image itself are self-explanatory:
#version Unofficial MegaPov 0.5;
camera { location <0,-.5,-6> look_at 0 angle 35 }
// A plane with opaque outer texture and transparent inner texture (with
// slides of opaque to visualize where the plane actually is):
plane
{ y,0
  texture
  { pigment { rgb 1 } }
  interior_texture
  { pigment
    { gradient x color_map
      { [0 rgb 1][.05 rgb 1][.05 rgbt 1][.95 rgbt 1][.95 rgb 1][1 rgb 1]
// A red light source above the plane
light_source
{ <1,1,0>, <1,0,0>
  looks_like { sphere { 0,.1 pigment { rgb <1,.5,.5> } finish { ambient 1 } } }
// A blue light source below the plane
light_source
{ <1,-1,0>, <0,0,1>
  looks_like { sphere { 0,.1 pigment { rgb <.5,.5,1> } finish { ambient 1 } } }
// Sphere above the plane:
sphere { <-1,1,0>, .5 pigment { rgb 1 } finish { specular .5 } }
// Sphere below the plane:
sphere { <-1,-1,0>, .5 pigment { rgb 1 } finish { specular .5 } }
Date: 28 Jul 2000 11:37:02
Message: <3981A8F2.A76B0D14@free.fr>
Strange result, indeed...
	But I also wonder how it's possible even to see the top sphere and
the red light that lit it ? I would expect that the opaque texture blocks
camera rays even if the interior_texture has transparent parts...
	[you should add a "hollow" flag to you plane ;-) ]
*** Nicolas Calimet
Date: 28 Jul 2000 11:50:29
Message: <3981abc5@news.povray.org>
> global_settings { ambient_light 4 }
> camera { location <-1,2,-5>*1.3 look_at 0 angle 35 }
> light_source { <170,200,-50>, 1 }
> plane { y, -1 pigment { checker rgb 1, rgb .5 } }
> sphere
> { -x*1.2, 1
>   pigment { rgbt <1,1,0,.9> }
>   interior_texture { pigment { rgb <0,1,1> } }
> merge
> { sphere { x*1.2, 1 }
>   sphere { <1.2,.5,0>, 1 }
interior_texture is not getting distributed to the spheres, do this:
> merge
> { sphere { x*1.2, 1
And about those shadows, comment out your own interior_texture's and watch
the shadows on the checkered plane get lighter, seems right to me, unless
you meant something else.
Date: 28 Jul 2000 12:48:10
Message: <3981b94a@news.povray.org>
Nicolas Calimet <pov### [at] freefr> wrote:
: 	Strange result, indeed...
: 	But I also wonder how it's possible even to see the top sphere and
: the red light that lit it ? I would expect that the opaque texture blocks
: camera rays even if the interior_texture has transparent parts...
  No, I think that in this case it's correct that you can see through the
plane from inside but not outside (at least this works right). This can
be used for neat effects (like mirrors than can be look through from the
other side, 1-sided polygons and so on).
  The shadowing should work accordingly.
  My original goal was to fix the self-shadowing problem of bump-mapped
surfaces with this trick. I'll post a report when the patch gets fixed.
: 	[you should add a "hollow" flag to you plane ;-) ]
  I intentionally left it out. I _wanted_ the camera to be inside the plane,
and the povray warning just confirms that it indeed is there.
Date: 28 Jul 2000 21:58:51
Message: <chrishuff-5F0E66.20593728072000@news.povray.org>
In article <3981982A.EC976774@free.fr>, Nicolas Calimet
> 	Yes exactly true. Works when adding the following line in Post_Process
> (parse.c) afterwards the equivalent code for Object_Texture :
...snip...
I have added this fix, it will be in future releases of MegaPOVPlus.
Date: 29 Jul 2000 15:17:45
Message: <39832dd8@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: I have added this fix, it will be in future releases of MegaPOVPlus.
  What about megapov?
Date: 29 Jul 2000 18:42:57
Message: <1eek4k1.1bueuqb1taqlquN%smellenbergh@skynet.be>
>   What about megapov?
Added it there also!
Smellenbegh
Date: 2 Aug 2000 02:47:26
Message: <3987c3fe@news.povray.org>
<twiddles thumbs>
Grim
