POV-Ray : Newsgroups : povray.unofficial.patches : Why does my leopard-Pigment change when switiching to Megapov? Server Time
7 Apr 2026 18:11:27 EDT (-0400)
  Why does my leopard-Pigment change when switiching to Megapov? (Message 1 to 6 of 6)
Subject: Why does my leopard-Pigment change when switiching to Megapov?
Date: 28 Jun 2000 05:10:12
Message: <3959c0f4$1@news.povray.org>
I have a mostly transparent leopard-pigment (turbulence 2, frequency 1.01)
on a cone which gives me some spots. When I render the scene in Megapov 0.5a
I get much less spots then in official Pov 3.1g (watcom-compile). I didn't
change anything (not even the version-setting) in the scene file, just  use
Megapov as renderer. Shouldn't it behave like offical Pov when the version
is set to 3.1?
Marc-Hendrik
Subject: Re: Why does my leopard-Pigment change when switiching to Megapov?
Date: 28 Jun 2000 08:19:28
Message: <3959ed50$1@news.povray.org>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote...
> Hi,
0.5a
use
> is set to 3.1?
If you ever use
    #version unofficial ...
in your scene, then you'll need to use
    #version official 3.1;
to get POV to switch back to the old noise.  Simply using
    #version 3.1;
will not be sufficient.
Interesting... with that indenting, my reply looks slightly like poetry.
Emphasis on "looks".  ;-)
-Nathan
Date: 28 Jun 2000 09:14:19
Message: <3959fa2b@news.povray.org>
But I did not use #version unofficial ... in this scene. I just started
megapov (windows) and it took the scenefile over from the official version.
Anyway ... I changed the frequency of the pigment and the result is as good
as the spots from the official version. I was just wondering what happened.
Thanks,
Marc-Hendrik
Nathan Kopp schrieb in Nachricht <3959ed50$1@news.povray.org>...
>If you ever use
>    #version 3.1;
>-Nathan
Date: 28 Jun 2000 10:54:01
Message: <395a1189$1@news.povray.org>
version.
good
happened.
I really don't know.  It should have been the same.
-Nathan
Date: 29 Jun 2000 01:23:48
Message: <395add64@news.povray.org>
Nathan Kopp wrote in message <3959ed50$1@news.povray.org>...
>If you ever use
>    #version 3.1;
From looking at the source code, the leopard pattern does not use noise3d at
all, so there should be no difference, no matter what #version is used.  The
"spotted" pattern does use noise3d, if this is the pattern you mean.
Mark
Date: 29 Jun 2000 20:59:19
Message: <d2snls4dq3mddgmv74npfl7cvquadp2ahr@4ax.com>
On Wed, 28 Jun 2000 08:14:28 -0400 "Nathan Kopp" <Nat### [at] Koppcom>
  Don't get nutty on us, Nathan <s>.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
