POV-Ray : Newsgroups : povray.unofficial.patches : Mini Patch Bug ? Server Time
6 Jul 2026 11:37:28 EDT (-0400)
  Mini Patch Bug ? (Message 11 to 15 of 15)
Subject: Re: Mini Patch Bug ?
Date: 27 Sep 1999 23:29:19
Message: <37f0360f@news.povray.org>
>I also tried making a variety of modifications to media, including evenly
>spaced samples and supersampling, but I couldn't get supersampling to work
>properly either.  I now know what I was doing wrong.  Make sure that when
>you super-sample, you give the super-samples less weight in the average.
>I.E. if you add a new sample between two existing samples, the new weights
>of the existing samples plus the weight of the new sample should still add
>up to the sum of the original weights of the two original samples.  Ok...
>that sounds a lot more confusing than I intended.
Makes perfect sense to me.
A1 = original pixel 1
B1 = original pixel 2
A2 = new pixel 1
B2 = new pixel 2
C2 = supersampled pixel between A2 and B2
A1+B1 = A2+C2+B2
Right?
Date: 27 Sep 1999 23:54:05
Message: <37F03BD1.A374A6C0@enst.fr>
> A2 = new pixel 1
> B2 = new pixel 2
> A1+B1 = A2+C2+B2
> Right?
	Well, not exactly or you wouldn't need the supersampled pixel at all :)
but ideally yes (and as far as weight is concerned, yes)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 28 Sep 1999 00:15:09
Message: <37F03EC1.A53D7734@aol.com>
I think I know what you are saying, but the way I'm doing it fits in with the
new sample_media function, so each time a supersample is taken it's added into
the total emission.  Then later it's divided by the total number of samples for
that interval.
I think I found the problem though.  I was looking through one of the functions
for where the values are added and noticed the variable d0 was still being used
even though I took d1 out of the function.  I can only assume it's value is 0
because I forgot to pass it into the function.  I'm going to try to fix that
and I hope, oh how I hope it works!  I've spent so much time on this and really
haven't got anywhere.
-Mike
Date: 28 Sep 1999 23:40:21
Message: <37f18a25@news.povray.org>
Mike <pov### [at] aolcom> wrote in message news:37F03EC1.A53D7734@aol.com...
the
into
samples for
> that interval.
That will cause a problem, though.  Uneven sampling (which is the result of
supersampling) needs uneven weights for the averaging process.  A simple
sum-and-divide will not give desired results.  I know, since I tried it.
-Nathan
Date: 29 Sep 1999 00:48:48
Message: <37F19823.C105197@aol.com>
I can only assume you are correct since I can't get it to work. I'm still
trying to get a handle on how everything goes together in media.c.
-Mike
