POV-Ray : Newsgroups : povray.unix : General linux advice (is there a GUI editor?) Server Time
1 Sep 2024 11:25:43 EDT (-0400)
  General linux advice (is there a GUI editor?) (Message 1 to 10 of 10)
Subject: General linux advice (is there a GUI editor?)
Date: 7 Apr 2006 12:20:01
Message: <web.4436900f985c796440d56c170@news.povray.org>
This is in response to jofg's earlier question.  This is how I run povray:
1) I use "kate" as my scene file editor. It is GUI! :) It gives one the
capability of having multiple scene files open under tabs just as does
POV-Ray for Windows.
2) I also have open a file in the kate editor which is "POVRAY.INI" or
"POV.INI" or "ZINI.INK" or whatever.  In this file, I have put text
equivalents of all those horribly aggravating +/- switch commands.  Here is
a typical one I might use:
------BEGIN ZINI.INK FILE LISTING --------
;Input_File_Name=latest16b04.pov
;Input_File_Name=golfco05.pov
;Input_File_Name=zfixirishd07dc.pov
Input_File_Name=maze10g39.pov
;Input_File_Name=giles_clouds.pov
;Input_File_Name=team03d2.pov
; +W160 +H120 +A0.0 ; Labels are not case sensitive.
+W320 +H240 +A0.0 ; Labels are not case sensitive.
;+W640 +H480 +A0.3 ; Labels are not case sensitive.
;+W1600 +H1200 +A0.3 ; Labels are not case sensitive.
;; File output type control.
;;     T    Uncompressed Targa-24
;;     C    Compressed Targa-24
;;     P    UNIX PPM
;;     N    PNG (8-bits per colour RGB)
;;     Nc   PNG (c'' bit per colour RGB where 5 <= c <= 16)
Output_to_File=true
Output_File_Type=N8             ;; (+/-Ftype)
Output_File_Name=/home/greg/images/
;Final_Frame=110;
----------------END ZINI.INK LISTING-------------
As you can see, I can use this method to tell povray my image size
requirements, my input file name, and even whether I'm doing an animation.
You can even leave commonly used options there on the list, and just
comment them out with a ";" as I have done here. It may seem like an
aggravation to go to the trouble of writing all this until you see my next
step:
3) Have a "konsole"  (command window) open all the time. In it, simply type,
"povray zini.ink" and hit enter.  It will render the scene file you
specified in 2), with the image size and everything.   Now this may still
seem like a pain until the time has come for you to render the SECOND
iteration of your image.  And that is done via"
4) In your konsole, hit <up arrow> <enter>.  Viola! it renders your image
with two keystrokes.   (Honestly, I had thought that linux users of povray
were hopeless, 1992-vintage luddites until I discovered this trick, (and
then grew newfound appreciation again when I was shown bash)).
hope this helps.
Subject: Re: General linux advice (is there a GUI editor?)
Date: 7 Apr 2006 23:15:00
Message: <web.443729ce972a330fb0beb7c80@news.povray.org>
This is always fun. :)  My typical povray session goes like this in a bash
shell:
$ vim tmp.pov
*some editing*
:w
CTRL+Z
$ CTRL+Rpovray+ENTER
$ fg
*repeat*
In other words, open up a tmp pov file in vim -- excellent editor with
syntax-highlighting, textual completion, block select, macros and many
advanced editing capabilities -- do some editing, save the work (:w in
vim), interrupt the editor process (CTRL+Z), search backwards in the
command-line session history for the last povray invocation with my many
default options set already and if i'm not happy with the output, bring
back the editor and repeat the whole process... :)
Though i'm rather new to povray, this is a very productive setup for me.
kate's not bad, it's just not up there yet with vim and emacs... ;)
Date: 8 Apr 2006 04:00:56
Message: <44376db8@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> $ vim tmp.pov
> *some editing*
> :w
> CTRL+Z
> $ fg
> *repeat*
  That means you can't edit while rendering?
Date: 8 Apr 2006 10:40:01
Message: <web.4437ca9f972a330fe31c21340@news.povray.org>
I like povwin for its add-on menu.
Is there something equivalent for Linux ?
milovann.
Date: 8 Apr 2006 15:05:00
Message: <web.443808b9972a330ff70064780@news.povray.org>
sorry, just forgot the & after the povray command, like
$ CTRL+RpovrayCTRL+E &ENTER
:P
still, most of the time i wanna see the result of the last editing before
moving on with yet more editing... i render it just enough to see if the
changes are good, stop the rendering with CTRL+z and then go ahead with
more changes... :)
Date: 8 Apr 2006 16:30:00
Message: <web.44381c20972a330f94c85a980@news.povray.org>
whoa!  and make sure you stop/cancel the rendering with a CTRL+C, i mean! :P
> :P
> more changes... :)
Date: 9 Apr 2006 04:22:28
Message: <4438c443@news.povray.org>
Wouldn't it be much easier to simply have two separate windows, one for
the editor and one for the renderer? Like this:
http://tag.povray.org/povQandT/EmacsPovFrontend.png
Date: 9 Apr 2006 10:50:00
Message: <web.44391e6a972a330f4d69ef0f0@news.povray.org>
....or two tabs in gnome-terminal.  But really, the fg/bg processess
switching works just about as fast and fine to me as alternating to another
window and invoking pov...
Date: 14 Apr 2006 00:35:00
Message: <web.443f25ea972a330f18e619bc0@news.povray.org>
> ;;     P    UNIX PPM
> Output_to_File=true
> ;Final_Frame=110;
> step:
> hope this helps.
Yes,
I read the UNIX/LINUX documentation, and the LINUX downloads.
I got PYVON to work work, It is close enough to the Windows version.
Will try POVLINUX next.
Thanks
Date: 3 May 2006 13:30:00
Message: <web.4458e7cc972a330f4d185c630@news.povray.org>
You might try wxpyvon
at
http://fabienhenon.free.fr/wxpyvon/
It uses wxpython. It is still in beta version ( I have not worked on it for
a while :( : Lack of time ).
Fabien
> > ;;     P    UNIX PPM
> > Output_to_File=true
> > ;Final_Frame=110;
> > step:
> > hope this helps.
> Yes,
> Thanks
