POV-Ray : Newsgroups : povray.unix : distributed rendering Server Time
16 Mar 2026 16:51:07 EDT (-0400)
  distributed rendering (Message 1 to 9 of 9)
Subject: distributed rendering
Date: 27 Jun 2005 11:00:00
Message: <web.42c01416bae622d9f47b0bc30@news.povray.org>
Is there any patch for distributed rendering on linux cluster?
I read of SMPOV for windows,but i can't find anything for linux?
Thanks
Subject: Re: distributed rendering
Date: 27 Jun 2005 11:45:01
Message: <d9p6la$9pp$1@chho.imagico.de>
None that offers all the features of current POV-Ray.
> Thanks
SMPOV is a separate program and there are tools that offer similar
functionality on Unix, for example:
http://www.tu-bs.de/%7Ey0013390/povany/index.html
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 28 Jun 2005 04:35:01
Message: <web.42c10ab8377f0478f47b0bc30@news.povray.org>
> Christoph
I tried this povany tools,but i had some difficulties to understand its
uses.
After i completed the installation ( the email communication module doesn't
install for some dependencies reason ) i tried to run the povany_pm and
povany_client but nothing really appened.
Let me explain better: both programs were running (i tried to made them run
again but one warning said it was impossible cos they were already running
but no .run file was generated.I tried to close them but without
success,they were running after a reboot,too.
can you help me?
Date: 28 Jun 2005 05:40:02
Message: <d9r5o1$ojm$1@chho.imagico.de>
> uses.
That does not make sense - the install script does not modify anything
that gets started during system boot and there is no way the tools can
survive a reboot.
Make sure you read the docs before starting the scripts:
http://www-public.tu-bs.de:8080/~y0013390/povany/docu.html
Note esp. the paragraph:
"All tools by default are started in loop mode. With the -c option you
can turn this off to run only once. In loop mode the scripts should not
be stopped by pressing CTRL-C but using the stop mode (-s) of the same
script. This makes sure the script exits in a clean state."
Once the scripts have been started in loop mode you have to stop them
with the described method - otherwise they won't start again - even
after a reboot.
It makes sense to use the verbose mode ('-v') for the scripts when
starting them for the first time - you will better see how the
processing works then.
Date: 28 Jun 2005 06:05:01
Message: <web.42c1209e377f0478f47b0bc30@news.povray.org>
Here is the error line:
POV-Anywhere Version 0.2 project manager already started - Exiting
The same for the client.
When i send the stop signal both client and manager pause their loops.
How can i restart them again?I think i make some big mistake...
Date: 28 Jun 2005 06:15:01
Message: <d9r7uv$p2d$1@chho.imagico.de>
after a reboot.
So if you get the above message (which does not mena the script is
running, just that it has been started but not yet safely exited) use
the stop mode and you will be able to start the scripts again.
When you have started the scripts they will render any project added to
the 'jobs' directory - the project manager will prepare the render tasks
and the client(s) will render them.
Date: 28 Jun 2005 09:20:00
Message: <web.42c14d80377f0478f47b0bc30@news.povray.org>
i read what you wrote and before i read the documentation.
I used the stop mode.
And i when i tried to start the scripts agian i get this message:
Stop signal exsists - exiting
So i tried  to send the stop signal again but the result was the same of my
previous message on this post.
> Christoph
I'm sorry if i'm boring you,but my knowledge of linux is basic.
Date: 28 Jun 2005 09:50:02
Message: <d9rkei$rlq$1@chho.imagico.de>
Well - right, that's a flaw in the scripts then - you have to manually
remove the lock files:
~/.povany/pm_stop
~/.povany/pm_status
~/.povany/client_stop
~/.povany/client_status
Date: 30 Jun 2005 03:00:00
Message: <web.42c397fe377f0478f47b0bc30@news.povray.org>
Thanks,i removed those files and started a newer installation.
Now all look fine.
Maybe i get a bad file from download.
