POV-Ray : Newsgroups : povray.unix : lilo help Server Time
21 Mar 2026 03:10:38 EDT (-0400)
  lilo help (Message 1 to 9 of 9)
Subject: lilo help
Date: 6 Jul 2002 18:26:22
Message: <ecreiu8d5gmj78jpijkhakm7l541n1544e@4ax.com>
I set up another hard drive with XP Pro. Now I have /dev/hda1 running
Win98SE, /dev/hda3 running Slack 8 and /dev/hdb1 running WinXP Pro. I
put the appropriate 'other' section in /etc/lilo.conf that reads (by
memory)
other = /dev/hdb1
  label = WinXP
  table = /dev/hdb
After running lilo, the partition is listed. It does not boot, though.
I know it's working because I can set my BIOS to boot from that disk
and XP works fine. In fact this post is being written in XP.
What am I doing wrong?
Oh, and BTW, it's the latest LILO, 22.something, just got it from
slackware.com
Any ideas?
Peter Popov ICQ : 15002700
Subject: Re: lilo help
Date: 7 Jul 2002 00:49:44
Message: <3d27c867@news.povray.org>
> memory)
> other = /dev/hdb1
>   label = WinXP
>   table = /dev/hdb
sits the partition table really in /dev/hdb? or maybe in /dev/hdb1?
how do you set your bios to boot from a slave harddisk? do you have a
floppy in diskdrive?
what is on /dev/hda2?
Date: 7 Jul 2002 03:51:55
Message: <3d27f31a@news.povray.org>
  As Marabou mentioned, you can't just have boot partitions on slave disks.
At least not by simply adding the entry to lilo.conf. But it can be done
with a little trick: I've done it in the past. The problem is that I don't
remember it exactly... it was done with the "map-drive" command to switch
the disks. Something like:
  other=/dev/hdb1
  label=WinXP
  table=/deb/hdb
  map-drive=0x80
    to=0x81
  map-drive=0x81
    to=0x80
  Hope this helps...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 7 Jul 2002 04:30:12
Message: <prufiukkfu76kriic39odqetvs68m19dap@4ax.com>
On Sun, 07 Jul 2002 06:50:40 +0200, marabou <not### [at] availablenet> wrote:
I don't know how NTFS works but I'll try /dev/hdb1. For my DOS
partition it's in /dev/hda so I just extrapolated.
I just set "Boot from" to "D, C, SCSI" and voila.
>do you have a floppy in diskdrive?
I think /dev/hda2 is the extended partition which holds the two
logical DOS drives.
Date: 7 Jul 2002 04:32:23
Message: <p0vfiuon8auhhd2ju21j55miofk6udhm5n@4ax.com>
On Sun, 07 Jul 2002 09:57:46 +0200, Jaime Vives Piqueres
Interesting then... how does the BIOS boot from there?
Ah :)
>But it can be done with a little trick: I've done it in the past.
>The problem is that I don't remember it exactly... it was done
>with the "map-drive" command to switch the disks. Something like:
>  other=/dev/hdb1
>  label=WinXP
>  table=/deb/hdb
>  map-drive=0x80
>    to=0x81
>  map-drive=0x81
>    to=0x80
>  Hope this helps...
Ah, so you want me to lie to my computer? WTF, as if I haven't done it
before :)
Thanks, Jaime, I'll look into it.
Date: 7 Jul 2002 09:58:20
Message: <3d2848fb@news.povray.org>
> logical DOS drives.
you really should get more familar with *nix drives. it does not matter if
you boot ntfs, dos, ext2, 3 or (nearly) whatever. lilo is a bootloader, not
an os.
you can n o t give names to your partitions how y o u want.
Date: 7 Jul 2002 11:11:30
Message: <3d285a21@news.povray.org>
>   disks.
>   other=/dev/hdb1
>   label=WinXP
>   table=/deb/hdb
>   map-drive=0x80
>     to=0x81
>   map-drive=0x81
>     to=0x80
>   Hope this helps...
e.g.:
http://www.uni-tuebingen.de/zdv/zriinfo/linux/howto/English/mini/LILO.html
Date: 7 Jul 2002 15:55:31
Message: <257hiu0qcqbo2kv5msomd2jqbeuf8hqeif@4ax.com>
>  Hope this helps...
Works fine now, thanks Jaime!
Date: 7 Jul 2002 16:07:38
Message: <n57hiuc67iu01dvkd9654gfi5ctojl5kmh@4ax.com>
On Sun, 07 Jul 2002 15:59:17 +0200, marabou <not### [at] availablenet> wrote:
>> logical DOS drives.
>an os.
I know :) That's exactly what I want to use it for - to boot a
specific partition which I know is bootable because I can boot it from
the BIOS.
I don't want that... It's how Linux names them. The logical partition
IIRC come after the extended partitions that hold them. I have a
primary that holds my C:, two more DOS logical drives and a Linux
partition. It's just how they are named.
