POV-Ray : Newsgroups : povray.unix : QTPOV will not render a scene loaded up into it Server Time
22 Dec 2024 14:43:41 EST (-0500)
  QTPOV will not render a scene loaded up into it (Message 1 to 9 of 9)
Subject: QTPOV will not render a scene loaded up into it
Date: 13 Jun 2005 22:52:23
Message: <42ae4667$1@news.povray.org>
running povray with command :
povray +Ifracpos11a11.pov
Persistence of Vision(tm) Ray Tracer Version 3.5.0c-10 (Debian
i386-linux-gcc)
 This is an unofficial version compiled by:
 Jeroen van Wolffelaar <jer### [at] wolffelaarnl> for Debian (www.debian.org)
 The POV-Ray Team(tm) is not responsible for supporting this version.
Copyright 1991-2002 POV-Ray Team(tm)
Parsing Options
 Input file: fracpos11a11.pov (compatible to version 3.5)
 Remove bounds........On  Split unions........Off
 Library paths: /usr/share/povray-3.5 /usr/share/povray-3.5/include
   /etc/povray-3.5/gini
Output Options
 Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
 Output file: fracpos11a11.png, 24 bpp PNG
 Graphic display......On  (type: 0, palette: 3, gamma:  2.2)
 Mosaic preview......Off
 CPU usage histogram.Off
 Continued trace.....Off  Allow interruption..Off  Pause when done.....Off
 Verbose messages.....On
Tracing Options
 Quality:  9
 Bounding boxes.......On  Bounding threshold: 3
 Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
 Antialiasing........Off
Animation Options
 Clock value....   0.000  (Animation off)
Redirecting Options
 All Streams to console.........Off
 Debug Stream to console.........On
 Fatal Stream to console.........On
 Render Stream to console........On
 Statistics Stream to console....On
 Warning Stream to console.......On
Parsing...Possible Scene File Parser Initialization Error: Could not
find file 'fracpos11a11.pov'
 Scene File Parser Initialization Error: Cannot open input file.
Subject: Re: QTPOV will not render a scene loaded up into it
Date: 14 Jun 2005 13:16:09
Message: <42af10d9$1@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:42ae4667$1@news.povray.org...
:snip:
running this command from inside QTPovEditor? Can you render any scene
loaded in QTPovEditor?
what happens when you run it from a command prompt in the directory where
the scene file exists?
Date: 14 Jun 2005 22:13:27
Message: <42af8ec7$1@news.povray.org>
Can you confirm that that's the outpput of "your" program? Is it possible
I've downloaded too many competing versions of povray and somehow QTPOV is
invoking another?
It does not work with a file freshly created in QTPOV.
Typing "povray FILNAME.pov" however works.
Date: 15 Jun 2005 22:32:01
Message: <42b0e4a1$1@news.povray.org>
Okay, here's the fix (or the workaround required by the way i screwed up my
system).
1) Pick a directory for your files
2) edit as root your  /etc/povray-3.5/povray.ini
3) Add library path
Now as long as you've saved your files to that directory, you're set to go.
Q:  are these properties of your actual system, or have I installed two
things atop each other?
news:42af8ec7$1@news.povray.org...
> invoking another?
Date: 16 Jun 2005 17:49:14
Message: <42b1f3da$1@news.povray.org>
It seems that povray(megapov) installer does not always add the correct
path to you libraries. You mays also have problems if you have enabled
IO restrictions (I still don't understand the meaning of such a feature
on systems with secured filesystems).
If you have an other soucy with QTPE, don't forget to ask on the
official forum (does not require to be registered) ;
http://qtpoveditor.sf.net
Thierry
> system).
> 3) Add library path
>>invoking another?
Date: 17 Jun 2005 03:08:25
Message: <42b276e9$1@news.povray.org>
	This might indeed be the case with 3.50c, although I didn't check it.
In principle installing 3.6 (povlinux or source distro) handles library
paths correctly.  Now Debian won't probably integrate 3.6 in their package
tree before 2 or 3 years  ;-)
> IO restrictions
	True again with 3.5, which I/O restriction feature was awkward.
	The filesystem "security" usually lets you write anything in your
user space.  Meaning it won't protect you from screwing up any user file
unless you manually change its write permission through 'chmod'.  Such
attack is possible via povray SDL when I/O restrictions are not set.
I/O restrictions just try to add another security level on top of the
filesystem permissions.
	- NC
Date: 20 Jun 2005 09:00:51
Message: <42b6be03$1@news.povray.org>
>> (I still don't understand the meaning of such a feature on systems
>     - NC
Ok, thanks for these explanations. Since I'm a single user I have no
need in this sort of securities and that's what make my wrong fealing.
Thierry
Date: 20 Jun 2005 10:34:48
Message: <42b6d408@news.povray.org>
	Well in fact my explanation attempt was a bit unclear and apparently
somewhat confusing, as guessed from your "Since I'm a single user" statement.
Please read again:
http://www.povray.org/documentation/view/3.6.1/794/
which better explains what I meant by "it won't protect you from screwing up
any [...] file" in your user space -- note the correction I make here  :-)
	- NC
Date: 20 Jun 2005 13:12:37
Message: <42b6f905$1@news.povray.org>
I did well understand what you meant, but what I mean is that my usage
of povray won't harm my computer nor my personnal files because I don't
use external files (excepted the ones from Gille Tran and Chris Colefax
wich are known to be sure).
> statement.
> Please read again:
> screwing up
>     - NC
