POV-Ray : Newsgroups : povray.unix : Porting povray to QNX6 Server Time
27 Jul 2024 22:28:44 EDT (-0400)
  Porting povray to QNX6 (Message 1 to 10 of 11)
Subject: Porting povray to QNX6
Date: 16 Mar 2005 08:56:00
Message: <42383af0@news.povray.org>
Hello, All!
I'm almost done new port of povray 3.6.1 to QNX6 (with Photon window output,
etc) and I want to send patches to developers. Are any of the POVRay
developers here ? :)
Here is my POVRay 3.5 port to QNX6 screenshot:
http://mike.qnx.org.ru/fun/dpovray.jpg
With best regards, Mike Gorchak.  E-mail: mik### [at] malvacomua
Subject: Re: Porting povray to QNX6
Date: 16 Mar 2005 10:02:58
Message: <42384B4E.56E8D23E@gmx.de>
Mike Gorchak schrieb:
> Hello, All!
There should not be any patches required to compile POV-Ray on a system
with a standard conforming C++ Compiler.  If you have trouble with this
it would be a good idea to ask before starting to write patches.
Note this refers to the core code, the Unix frontend might not work
without changes on some systems.
Yes. ;-)
-- Christoph
Date: 17 Mar 2005 00:35:59
Message: <4239173f@news.povray.org>
Hello, Christoph!
 ??>> I'm almost done new port of povray 3.6.1 to QNX6 (with Photon window
 ??>> output, etc) and I want to send patches to developers.
 CH> There should not be any patches required to compile POV-Ray on a system
 CH> with a standard conforming C++ Compiler.
I got numerous warnings and errors with the type casting, the most frequent
is a assignment to int from float and the similar. But need to say, that 3.5
source was nightmare as for type casting :) comparing to the 3.6.1 sources
 CH> If you have trouble with this it would be a good idea to ask before
 CH> starting to write patches.
But anyway I want to port it to QNX6 ;)
 CH> Note this refers to the core code, the Unix frontend might not work
 CH> without changes on some systems.
I've added Photon GUI code (like X11 and SVGA code). I think it would be
nice to include it into the mainstream sources. How I can send the patches
concerning GUI for first time ? Post it here ?
 ??>> Are any of the POVRay
 ??>> developers here ? :)
 CH> Yes. ;-)
Excellent :) !
Date: 17 Mar 2005 01:51:31
Message: <423929A1.F715E943@gmx.de>
These are no errors, just warnings and you can turn them off in your
compiler settings.  Patches are neither needed not a good way to avoid
those warnings.
I am not sure what you are talking about here - does it have to do
anything with photon mapping in POV-Ray?
You can post patches in povray.binaries.programming.
-- Christoph
Date: 17 Mar 2005 04:40:20
Message: <oitng2-0ug.ln1@badulaque.unex.es>
Among other things, Christoph Hormann saw fit to write:
>> patches concerning GUI for first time ? Post it here ?
I'm guessing "Photon" is the name of the graphical server/library in QNX6 or
something like that. And with "GUI" he probably means the display window.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 17 Mar 2005 04:42:01
Message: <423950e9@news.povray.org>
Hello, Christoph!
 ??>> I've added Photon GUI code (like X11 and SVGA code). I think it would
 ??>> be nice to include it into the mainstream sources. How I can send the
 ??>> patches concerning GUI for first time ? Post it here ?
 CH> I am not sure what you are talking about here - does it have to do
 CH> anything with photon mapping in POV-Ray?
Heh :) No.
Photon is a GUI name in QNX6 OS (like X11).
 CH> You can post patches in povray.binaries.programming.
Thanks :) !
Date: 17 Mar 2005 06:22:31
Message: <nupi31tgvdom41mhaop5lksif9qe36rbnm@4ax.com>
On Thu, 17 Mar 2005 07:54:25 +0100, Christoph Hormann <chr### [at] gmxde>
It seems http://www.qnx.com/products/ui/photon.html
ABX
Date: 17 Mar 2005 07:14:14
Message: <42397543.168D73A6@gmx.de>
> Heh :) No.
Well - if it's a proprietary QNX system it will most likely not be
supported in official POV-Ray (we obviously can't support a platform we
don't use ourselves).
That's just my personal opinion of course and anyway it does not mean it
won't be useful to have it as an unofficial extension.  Of course the
use of running POV-Ray on a real time OS is limited in general.
-- Christoph
Date: 17 Mar 2005 08:15:40
Message: <423982fc@news.povray.org>
Hello, Christoph!
 CH> Well - if it's a proprietary QNX system it will most likely not be
 CH> supported in official POV-Ray (we obviously can't support a platform we
 CH> don't use ourselves).
Ok. It's sad. Because I must to port it again and again when next version of
POVRay will be released.
 CH> That's just my personal opinion of course and anyway it does not mean
 CH> it won't be useful to have it as an unofficial extension.
What's mean "an unofficial extension" ?
 CH> Of course the use of running POV-Ray on a real time OS is limited in
 CH> general.
Why you think, that it is limited in general ? I don't think so.
Date: 17 Mar 2005 09:45:09
Message: <423998A3.C84213F3@gmx.de>
No significant changes have been made to the display routines of POV-Ray
for a long time.  Any display functions that have been written in the
last years (i'd say since version 3.1) will still work with current
POV-Ray (and in fact the SVGA code has not been modified since then.
Any modification of POV-Ray that is not part of the official version.
>  CH> general.
The purpose of a real time OS is to have detailed control of task run
times (and the ability to predict them).  This is rather pointless for a
program like POV-Ray since you do not even know how many CPU cycles a
render will take before actually rendering it.
-- Christoph
