![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am trying to generate an mpeg animation using mpeg2encode from files I
generated using POVRay. I keep getting this error:
Couldn't create */.Y
Anyone else have this problem. This is the first time that I'm getting
this eror from mpeg2encode. I know my permissions are set correctly. My
machine is running Slackware 8.0
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
11:28pm up 3 days, 2:47, 0 users, load average: 3.65, 3.51, 3.49
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> David
> ICQ#: 118347772
I believe that povray has dropped generation of separate files
for each colour some time ago. I also several years ago started using
this coding to mpeg generation. Since I went to the .ppm format as this
was supported by the encoder.
I have used both mpeg2encode and mpeg_encode. Now I only use the latter.
You should be able to find as mpeg_encode-1.5b*.
cu.
Bjarne
| Bjarne Nygaard at home: bny### [at] post4 tele dk |
| ---this space is not intentionally left blank--- |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Bjarne Nygaard wrote:
> Hi,
I am having povray output the files as .ppm, since, as you said, it is
suppotred by mpeg2encode. However, I have not had this problem when I have
genereated animations in the past under the same conditions. I am sure
there's something I'm missing, but I'm not sure what it is.
David
ICQ#: 118347772
9:17pm up 1 day, 19:31, 0 users, load average: 0.09, 0.10, 0.04
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Hi,
Have you really gotten mpeg2encode to work? I was never able to get it to
generate an mpeg2.
Many others have said they got it to work but when i said "Show me the PAR",
it turns out they were generating mpeg1. If you have a working .PAR file
for an mpeg2, i would love to see it.
If you are generating mpeg1, i think mpeg_encode makes much nicer mpegs.
(I am currently churning a 702x512x3100 mpeg1. http://www.buckosoft.com/bsac/ )
I have also hacked mpeg_encode to accept png as an input. If you like 1.5b,
you should try mine...
http://www.buckosoft.com/gallery/tools/mpeg_encode/
_,--"
dik `-._ ________-_______ "----
_----'--'--------------------------------'--'----_
//_| | \ dic### [at] buckosoft com / | |_\\
(_____|_|__= Guilford Conn +1.203.458.0389=__|_|_____)
_\_____=___ http://www.buckosoft.com ___=_____/_
\/-(o)-~~-(o)-~~-(o)-`------'-(o)-~~-(o)-~~-(o)-\/
Early Net Poetry:
Wustl, Wustl, ERR RIP MIT BOOT, BIND Wustl
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> PAR",
No problem. Here's the par I used(it was generated using GIMP). There's
seems to be a little damage because of word wrap, though.
MPEG-2 stream 30 frames/sec
/home/dsfranks/povray31/scenes/animate/pentmap/pentmap%03d /* name of
source
files */ - /* name of reconstructed images ("-": don't store) */
- /* name of intra quant matrix file ("-": default matrix) */
- /* name of non intra quant matrix file ("-": default matrix) */
- /* name of statistics file ("-": stdout ) */
2 /* input picture file format: 0=*.Y,*.U,*.V, 1=*.yuv, 2=*.ppm */
301 /* number of frames */
0 /* number of first frame */
00:00:00:00 /* timecode of first frame */
12 /* N (# of frames in GOP) */
3 /* M (I/P frame distance) */
0 /* ISO/IEC 11172-2 stream */
0 /* 0:frame pictures, 1:field pictures */
320 /* horizontal_size */
80 /* vertical_size */
2 /* aspect_ratio_information 1=square pel, 2=4:3, 3=16:9, 4=2.11:1
5 /* frame_rate_code 1=23.976, 2=24, 3=25, 4=29.97, 5=30
frames/sec. */
3000000.0 /* bit_rate (bits/s) */
112 /* vbv_buffer_size (in multiples of 16 kbit) */
0 /* low_delay */
0 /* constrained_parameters_flag */
4 /* Profile ID: Simple = 5, Main = 4, SNR = 3, Spatial = 2, High =
1 */
8 /* Level ID: Low = 10, Main = 8, High 1440 = 6, High = 4
0 /* progressive_sequence */
1 /* chroma_format: 1=4:2:0, 2=4:2:2, 3=4:4:4 */
1 /* video_format: 0=comp., 1=PAL, 2=NTSC, 3=SECAM, 4=MAC,
5=unspec. */
5 /* color_primaries */
5 /* transfer_characteristics */
5 /* matrix_coefficients */
320 /* display_horizontal_size */
80 /* display_vertical_size */
0 /* intra_dc_precision (0: 8 bit, 1: 9 bit, 2: 10 bit, 3: 11 bit */
1 /* top_field_first */
0 0 0 /* frame_pred_frame_dct (I P B) */
0 0 0 /* concealment_motion_vectors (I P B) */
1 1 1 /* q_scale_type (I P B) */
1 0 0 /* intra_vlc_format (I P B)*/
0 0 0 /* alternate_scan (I P B) */
0 /* repeat_first_field */
0 /* progressive_frame */
0 /* P distance between complete intra slice refresh */
0 /* rate control: r (reaction parameter) */
0 /* rate control: avg_act (initial average activity) */
0 /* rate control: Xi (initial I frame global complexity measure) */
0 /* rate control: Xp (initial P frame global complexity measure) */
0 /* rate control: Xb (initial B frame global complexity measure) */
0 /* rate control: d0i (initial I frame virtual buffer fullness) */
0 /* rate control: d0p (initial P frame virtual buffer fullness) */
0 /* rate control: d0b (initial B frame virtual buffer fullness) */
2 2 11 11 /* P: forw_hor_f_code forw_vert_f_code search_width/height */
1 1 3 3 /* B1: forw_hor_f_code forw_vert_f_code search_width/height */
1 1 7 7 /* B1: back_hor_f_code back_vert_f_code search_width/height */
1 1 7 7 /* B2: forw_hor_f_code forw_vert_f_code search_width/height */
1 1 3 3 /* B2: back_hor_f_code back_vert_f_code search_width/height */
David
ICQ#: 118347772
12:19pm up 19:30, 0 users, load average: 0.45, 0.20, 0.06
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> David
> ICQ#: 118347772
Hello,
I used the following command:
convert images/xxx*.png xxx.mpg
This ImageMagick tool works like a breese, you only need mpeg2encode in
you PATH.
Regards, Theo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
