POV-Ray : Newsgroups : povray.text.scene-files : [Minimum Volume] Bounding Ellipsoid via SVD Server Time
10 Jun 2024 14:15:19 EDT (-0400)
  [Minimum Volume] Bounding Ellipsoid via SVD (Message 25 to 34 of 34)
Subject: Re: [Minimum Volume] Bounding Ellipsoid via SVD
Date: 11 Nov 2019 17:05:01
Message: <web.5dc9da72f7b9a3af4eec112d0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> after posting _that_ I remembered you mentioning your being new to Linux etc in
> another thread.  so some more on command lines etc below.  (I really feel old -
I was new 20 years ago, I just haven't been involved in administration of the
NMR computers or had the SGI O2 to play with for about a decade.  So every
little bit helps, whether it's something I "know" or not.
> and can be just a set of data points, ie no "shape" required?  powerful.
Correct.   Data is data is data.  It doesn't have to be geometric at all.
It could be correlating customer purchases with zip codes or what movie watchers
might also like to watch, or what their most likely preferred theatre snack is,
or just about anything that you can think of.
> > 2D data can be aligned so that the most elongated part is along one axis, and
> > the rest of the data perpendicular to that gets rotated to be in the cardinal
> > plane,
> interesting too but cannot visualise use cases.  when (what kind of data) would
> you use that?
Just search "application of singular value decomposition to ...."  and it goes
on and on and on....
> testing, testing..  :-)
Yeah.   I upped my test case to 400 points, switched over from the "narrow"
version to the "wide" version, found that all of that introduces some problems,
learned a bit more (logical in retrospect) about the resulting matrices, and now
am awaiting some replies from hopefully helpful experts On The Internet.
I used to write shell scripts, and do a bunch of regular expression stuff, but I
have to get back into that - time, energy, focus, round tuits allowing....
Good progress so far, just have to make it past the usual frustrating roadblocks
to reach the end....
Date: 11 Nov 2019 18:15:02
Message: <web.5dc9eaddf7b9a3af4eec112d0@news.povray.org>
Just an interesting aside:
https://blogs.mathworks.com/cleve/2012/12/10/1976-matrix-singular-value-decomposition-film/
Date: 13 Nov 2019 16:40:00
Message: <web.5dcc774ef7b9a3affeeb22ff0@news.povray.org>
hi,
thank you for this link.  watching the film helped somewhat.  (shades of Tron
regards, jr.
Date: 14 Nov 2019 19:45:00
Message: <web.5dcdf3faf7b9a3af4eec112d0@news.povray.org>
You, Sir, are hilarious.
That thing didn't help me a single bit.  :D
Try this.
https://towardsdatascience.com/svd-8c2f72e264f
There are dozens of other pretty decent summaries / explanations.
Now that I have a functional reorientation, I'm waiting on some feedback from
someone, anyone as to a last bit of the puzzle (unconnected to the present
application).
Also going to try to get some c++ code written, and then hopefully the SVD will
be able to be integrated into a easy-to-use POV-Ray workflow.
If THAT works, then I have some other ideas for what to try it on.
Date: 17 Nov 2019 20:25:00
Message: <web.5dd1f28bf7b9a3af4eec112d0@news.povray.org>
So, since I don't code in c++, I'm kinda coding by imitation and trial and
error.
I get the current small bit of test code to compile, but when I run it with my
dataset: "400" followed by 1200 numbers "value\n"
#write (Output, NumPoints, "\n")
 #write (Output, P[PonS].x, "\n")
 #write (Output, P[PonS].y, "\n")
 #write (Output, P[PonS].z, "\n")
I get a segmentation fault.
template<typename Arg = cpp_bin_float_4096>
void generate_matrix(std::vector<std::vector<cpp_bin_float_4096> >& \
 matrix, std::size_t rows, std::size_t cols)
    std::cin >> rows;
 std::srand((unsigned int)std::time(nullptr)); matrix.resize(rows);
 for (std::size_t row = 0; row < matrix.size(); row++)
  matrix[row].resize(3);
  for (std::size_t col = 0; col < 3; col++)
   //std::cin >> ignore(100, '\n') >> matrix[rows][cols];
            std::cin >> matrix[rows][cols];
    std::cout << "Data imported. \n\n";
int main(int argc, char* argv[])
 std::size_t matrix_size = 0;
 std::vector<std::vector<cpp_bin_float_4096> > u, v;
 std::vector<std::vector<cpp_bin_float_4096> > matrix, s;
 std::cout << "Importing data into matrix . . . \n\n";
  generate_matrix(matrix, matrix_size, matrix_size);
  std::cout << "\nA = \n"; print_matrix(matrix);
  //svd(matrix, s, u, v);
  //std::cout << "\nS = \n"; print_matrix(s);
  //std::cout << "\nU = \n"; print_matrix(u);
  //std::cout << "\nV = \n"; print_matrix(v);
 std::cin.get();
 //std::cin.get();
 return 0;
Date: 17 Nov 2019 21:05:01
Message: <web.5dd1fc10f7b9a3affeeb22ff0@news.povray.org>
hi,
> error.
please post a data file.  when you say "400", are you trying to run a 400x400
matrix?  not sure but you *might* hit the limits -- the code's recursive, no?
I'll monkey my version + try the data, in coming days.
regards, jr.
Date: 17 Nov 2019 21:15:01
Message: <web.5dd1fe9ff7b9a3af4eec112d0@news.povray.org>
done.
400 x 3 matrix.   A "vector" data type that uses 400 povray vectors split up
into x, y, and z values.
So I just figured I'd read in the 400 first, size my array according to that,
and then just pipe the whole file into the compiled SVD processor.
Right now I just wanted to see if that worked, so I'm just gonna import the
data, and then print it back out to show that that part works, then copy that
working code into the SVD .cpp file.
This is mid-hack, so it's uglier than usual    ;)
#include <vector>
#include <iostream>
#include <iomanip>
#include <ctime>
#include <algorithm>
#include <boost/multiprecision/cpp_bin_float.hpp>
#include <boost/math/special_functions/gamma.hpp>
using namespace boost::multiprecision;
typedef number<backends::cpp_bin_float<4096, backends::digit_base_2, void,
boost::int16_t, -16382, 16383>, et_off>  cpp_bin_float_4096;
using namespace std;
std::vector<std::vector<cpp_bin_float_4096> > matrix_i;
void print_matrix(std::vector<std::vector<cpp_bin_float_4096> > matrix)
    std::cout << "Printing matrix . . . \n\n";
  for (std::size_t col = 0; col < matrix[row].size(); col++)
   std::cout << std::setprecision(1) << std::fixed << matrix[row][col] << " ";
std::cout << "\n";
 //std::cout << "\n";
    std::cin >> rows;
 std::cin.get();
 //std::cin.get();
 return 0;
Download 'vectors.dat.txt' (12 KB)
Date: 17 Nov 2019 21:45:01
Message: <web.5dd204daf7b9a3affeeb22ff0@news.povray.org>
hi,
> done.
cheers.
first glance -- I'd advise to supply both cols + rows as part of the matrix
data, rather than hardwiring the inner loop.
bedtime now, here.  hasta manana.
regards, jr.
Date: 18 Nov 2019 08:45:00
Message: <web.5dd29f35f7b9a3affeeb22ff0@news.povray.org>
hi,
> done.
hi,
some small progress.  I shortened the data to ten rows, prefixed by cols + rows,
run it with:
  $ tr ' ' '\n' < be-vectors | svd
3 10
0.0883597 -0.326943 -0.337204
-0.405332 0.103699 0.242547
0.421881 0.0228523 -0.10112
0.432184 0.124463 -0.081805
-0.397722 -0.42712 0.00183197
0.176067 -0.254352 -0.364851
-0.0141579 0.454459 -0.317524
0.354473 0.731663 -0.0403544
0.188762 -0.165013 0.215763
0.267797 0.895557 -0.10793
the "bugbear" is that the code expects to see square matrices.  the following
modifications get me to the point where 'svd()' is called in main; I think the
transpose_matrix is next in need of .. attention.
int main(int argc, char* argv[]) {
  std::size_t mncols = 0,
              mnrows = 0;
  std::cout << "Singular Value Decomposition (SVD):\n";
  std::cin >> mncols;  std::cout << "number columns: " << mncols << ".\n";
  std::cin >> mnrows;  std::cout << "number rows: " << mnrows << ".\n";
  if (mnrows <= 500)
    generate_matrix(matrix, mnrows, mncols);
  else std::cout << "Wrong matrix size... (matrix decomposition recommended)";
  return 0;
              << " "; std::cout << "\n";
//  std::cout << "\n";
compare this to the previous, wrt loop (counter) limit.  I suspect all functions
dealing with matrices will need similar change(s).
    matrix[row].resize(cols);
      std::cin >> matrix[row][col];
regards, jr.
Date: 18 Nov 2019 18:30:01
Message: <web.5dd32858f7b9a3af4eec112d0@news.povray.org>
> run it with:
So just replace any spaces with a newline and pipe it to the svd script.
meh.  For the time being we can just create/resize all matrices with the
optional appending of ", 0)" like so:
inv_matrix[index].resize(matrix[index].size(), 0);
I'm not sure what the limit is, but I doubt that you or I would be using more
than 500 points just to do some orienting.  I think right now, just keep it
simple, and get a "flow" working so that we can integrate POV-Ray's .ini and
post-render capabilities so that an object can be "scanned", the vectors written
to disk, SVD can spit out an orientation matrix, and the scene can be re-run: at
which point it checks to see if a data file and/or matrix file has been written,
and then it just skips over to the part where it renders the oriented object.
I'll look it over and see what I can hammer out.   Busy day.
Thanks for the tips.   :)
Having fun with our new friend I see  ;)
